Very nice work Danny, especially noting the scale you are working at.
cheers
Pat
Dan,
I could use a few on my plastic build ...  very meticulous work on that searchlight. Suddenly you are going fast with the super structure ... looking good. I added some glue on the rungs/steps of the ladders on my build, they tended to break of when I touched them again by accident - may be for a next time ....
Carl
Thanks very much CDW, Pat, Carl and Jan.
9 hours ago, amateur said:
Long time ago we had a member named martanek. He did wonders with paper, and always used a tictac as a reference for size in his pictures.
With that search light, I missed the tictac, I'm afraid the thing is even smaller than I dare to imagine :)
Jan
Jan, it's a little bit smaller than a Tic-Tac ;). If I had one I'd put it up against it, but I keep eating them - I can't stop at one :D.
BTW - martanek is on the Paper Modellers site. He still has his Tac-Tacs (I'm sure they are plastic ;):D).
:cheers:  Danny
Cheers, Danny
I've been putting off building the Main Mast until now, because I thought it would be one of the most difficult parts of the build. It turned out to be fairly easy :). CA glue was used for all the metal joints. I taped the legs of the mast to a block of MDF for stability while I glued all the other parts to themMain Mast (1).JPG
This part (I don't know what it is, perhaps a "Crow's Nest"?) proved to be the hardest thing to make. There are 6 pieces to it, and it's a multi-angled shape :
Now to spray paint the whole thing.
:cheers:  Danny
Cheers, Danny
Looking good. I like your make shift jig to hold everything in alignment.
Cheers
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
Thanks Slog, Greg and CDW :).
Here's one of the smallest assemblies I've had to make, a Windlass. There are 15 tiny parts in it and it's only 4mm long :
I'm not sure what the function of these parts is, it seems to be some kind of covered entryway. I made the actual units some time ago, and now it's time to fit them :
It's also time to fit the Bridge :
The last major sub-assembly to fit is the aft superstructure :
A couple of overall progress pics with the major assemblies fitted. I'm leaving the last three turrets until later as there are a lot of small parts to be made and fitted around them first :
:cheers:  Danny
Cheers, Danny
really nice progress Dan.....love the way the super structure is shaping up   your embracing this medium in a big way...becoming quite good at it in a very short time! very well done! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
15 tiny parts in it and it's only 4mm long ...
can't see it on the ship :wacko: !!!!!!! where did you hide it. 15 parts on 4mm length .. you are definitely pullin' me leg!
Carl
Sorry Carl, here it is - at the tip of my (blunted) Xacto knife ;):D :
:cheers:  Danny
Cheers, Danny
Danny you have really mastered this building medium very quickly; very nice work and great detailing at that scale.
cheers
Pat
Thanks Carl and Pat. Yeah, I'm getting the hang of working with paper :). I now have the confidence to tackle the Bismarck, which I'll start in about another week or so when I've finished Amatsukaze :).
Here are a couple of pics of the fitted Main Mast :
There is another large Winch on the aft deck. This one has 25 parts, but is quite a bit bigger than the Windlass. A pic of the Supports under construction, and another of the rest of the parts :
The winch finished and fitted to the deck :
:cheers:  Danny
Cheers, Danny
Brilliant work Dan the 1/70 SD14 is just waiting to be built by you
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thanks Kevin. Not in this lifetime I think :D.
I've been busy making and fitting some of the smaller deck pieces. Here's the Aft Deck at the moment :
I have no idea what this structure is (something to do with the Anchor Chains?). This part of it consists a lot of small discs - I'm so glad I bought those punches :) :
Most of the fore deck fittings in place, apart from those on the edges of the deck. I'll fit those after the Railings go on :
Speaking of Railings - I've made a start. A bit of paint touch-up will be done when they are all on :
:cheers:  Danny
Cheers, Danny
Thank you CDW. You'll find the Hole Punches to be very useful. I've got both the small ones and the large ones, and use them both a lot.
There are 16 Bollards to be made. The tubes are solid rolled, these took me nearly an hour to make - quite an improvement on the first few I tried :). Here's a few pics of how I handled these very small parts - note the double-sided tape and the moistened Q-tip I used to pick up the tiny tops and bottoms (the Hole Punches were a great help here) :
There are two more Paravanes near the stern. I used a rounded dowel to help with gluing the ends :
The paravane Cranes were part of the PE set I bought earlier :
There are six Depth Charges held in housings in the stern. The ends of the housings were the smallest parts in the whole ship :
Finally for now I fitted the Anchor Chains. There was no indication in the instructions about the size of the chain, but by counting the links in one of the pictures I came up with 27 links per inch :
:cheers:  Danny
Cheers, Danny
WOW!  very nice work Dan! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Dan, I really had to say what a wonderful model you are making and, and as such
makes me want to get going on my Batory.
Thank you for all the hints and tips you have given.  Very inspirational,  kind regards, Nick.
Current Build: M.S. Batory, Polish Transatlantic Liner  - Card.
That is some very fiddly work and you have achieved mastery over it Danny - very clean and precise.
cheers
Pat
Thank you for the kind comments Carl, Popeye, Nick and Pat. Always appreciated :).
All the Railings are now fitted. They turned out quite well despite being very fragile, and I'm very happy with the way they turned out :).
There was a slight problem on the Foredeck where the deck has a dip in the middle (it's supposed to be like that). Trying to fit a 2-rail railing in the dip is impossible without cutting one of the rails as it wants to bend in or out. Sort of like trying to bend a piece of planking sideways :
The top rail cut and CA glued back together :
A tip for drilling holes for railings. I CA glued a 0.3mm drill bit into a piece of 0.3mm ID tubing, and then glued that inside some 0.6mm ID (0.8mm OD) tubing. I left about 1mm of the drill bit protruding. This has two advantages. First, it strengthens the small bit enormously - I drilled about 150 holes and DIDN'T BREAK ONE :). Second, you can only drill to the depth of the protruding bit, so there is no sudden downward movement of the drill if you drill right through a deck - another major cause of drill breakage, and also possible damage to surrounding parts :
Mounting the Motor Launches to their davits proved problematic, as they wanted to fly all over the workbench (and floor) at the slightest touch. To fix this I spent some time making a jig. This also helped a lot in getting the boats to sit at the right height and level :
Rather than just using a piece of wire for the "tackle" I made up some doubled "line" and "blocks" from 0.2mm wire and 0.4mm ID tubing :
One of the launches in the jig, almost ready to fit to the ship :
And both launches fitted :
:cheers:  Danny
Cheers, Danny
The last pieces - the Entry Steps :
And some overall pics. Only the Rigging left to do :) :
:cheers:  Danny
Cheers, Danny
...and your almost finished!   that's amazing!   great idea with the davits.....but it must have been a little tough to line up the davits to the deck slots...wasn't it kinda flimsy?   fantastic job Danny........your more than ready to tackle the Bismark :imNotWorthy:
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
