Those bitts will never move anywhere under the strain of the cables when anchored! Well done: I don't think I've seen this detail in a model before.
Wonderful work, Toni.
You make it look so simple, but this must be difficult parts to make and fit so neat to the beams
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Gentlemen, thank you for your comments.  It was a little fiddley but I am pleased with the appearance.  Druxey, I looked at a lot of build logs and did not see anyone else notch the standards.  Remco, this was nothing compared to the detail work on your Kingfisher.
Toni
Member IPMS
                           Utrecht-1742
The crosspiece of the bitts is comprised of two different wood species.  The fore section is oak and the thinner aft section is elm.  Both of these are light-colored species so I did not want a stark contrast between the two pieces.  I used pau marfin for the "elm".  The crosspiece is attached to each pin with two bolts.  The metal work for the bitt will wait until I have a few other metal projects, although the holes to accept the metal pieces have already been drilled.
Toni
Member IPMS
                           Utrecht-1742
The sixth beam set is relatively straight forward.  The aft bulkhead for the boatswain's cabin was temporarily removed to make installation easier.  The pillar is supposed to go through the hatch coaming.  I cheated and it is simply glued to the surface of the coaming.  There is a tenon on the superior aspect of the pillar with a mortise on the under surface of the beam.
Toni
Member IPMS
                           Utrecht-1742
Beam set 7 includes the opening for the fore hatch.  These carlings are a little larger than the standard ones.  As I am building the lower deck structures as I move aft, it was time to build the aft sail room.  The fore sail room is one of the small rooms on the port side near beam set 4.  This was a fun little structure to make.  The lateral walls have louvers to allow ventilation into the room.  I do not own a mill so the mortises for the louvers were made with an 11 blade.  On Atalanta, the door into this room is a slider, not a hinged door.  Consequently, the door must be made wider than the opening and it will be on the outside wall of the sail room.  There is a pillar on the inside wall precluding placing the door there.  Not having built a sliding door before, I went over to the local stable and looked at my horse's stall door.  The latch is a L-shaped bolt on the door with a U-shaped piece of metal on the door frame to receive the bolt.  The bolt measured 3" x 4" x 3/8".  This would require making a u-shaped channel 0.01" square.  Needless to say, this is well beyond my skill set so I have a flat piece of metal on the door frame representing it instead.  Decking was placed under the assembly on the starboard side.  The last two pictures show the sail room assembly before and after a coat of finish.
Toni
Member IPMS
                           Utrecht-1742
That's looking lovely, Toni. If you felt like it, you could fabricate a wood channel from a flat strip with two square ones glued on top, the door thickness apart.
Druxey, you caught me!  Actually, I wanted the glue on the door to be secure and then put the track on on top.  Going back to my stall door model, there is no track on the bottom.  Was there one on a ship?  Greg, I thought about cutting the mortises on the Preac (and when I do the upper well that is my plan) but I did not have a thin enough saw blade with me that day.
Toni
Member IPMS
                           Utrecht-1742
Toni,
Very nice!
Maury
I imagine there would be tracks top and bottom. Your stalls are land-bound, so doesn't need two tracks, but imagine the door to the sail room banging around in a seaway. The lower track would be two battens nailed to the deck.
A delayed thank you to Maurey and Pavel.  Druxey, the tracks are now installed and, like so many details that we add, are now almost invisible!  But we all know they are there...
Beam sets 9 and 10 are in place.  The only unusual items are the opposed lodging knees at the dead flat.  I did not have thick enough wood with me this week to make them, so they will be installed next week.  They will be identical to the ones on the lower deck.  Look at page 10 of this build to see how they are shaped.
Edited by tlevine
Toni
Member IPMS
                           Utrecht-1742
Looking terrific, Toni. And I feel so much better, knowing that the track for the door is there, even if no-one can see it ;)
Thanks, Ron.  The real fun will happen when I try the louvers on all four walls of the upper well!
Druxey, its people like yourself that keep us striving for accuracy.  I really appreciate it.
Toni
Member IPMS
                           Utrecht-1742
I have made and installed the opposed lodging knees.  Since I did not go into any detail on their construction for the lower deck, let me demonstrate how I made them.  First, I make a template of the knee and saw it out a bit oversized.  The thickness of the blank is about 2.5 times the normal thickness to allow for the curvatures.  I then mark on the blank the areas that will be removed. I use a combination of my Preac saw, Dremel sanding discs and sandpaper to remove the excess material.  The knees are given a final shaping and the bolts are added prior to installation.
post-262-0-21204600-1395190892_thumb.jpg  post-262-0-09627200-1386642589_thumb.jpg
post-262-0-55409500-1386642590_thumb.jpg  post-262-0-63256000-1395190855_thumb.jpg
post-262-0-08565200-1386642594_thumb.jpg  post-262-0-20166000-1395190858_thumb.jpg
Edited by tlevine
Toni
Member IPMS
                           Utrecht-1742
The last two pictures show the knees installed.
Edited by tlevine
Toni
Member IPMS
                           Utrecht-1742
They look very sharp. I am curious as to the reason that they exist, is it simply to deal with the knees coming from opposite ends and this is where they meet?
Michael
Lovely work on the knees and a great tutorial.
Amazing Toni!
A truly inspiring work with the mortises and an excelllent tutorial for that tricki knee... Did you use some kind of jig to cut the mortises on the "pump box"? I mean the pillars with that 11 blade. What stuff do you use to simulate the black bolting on the knees?
Beautiful.
Daniel.
Michael
That's exactly right Michael.
:cheers:  Danny
Cheers, Danny
