looks great Bob!
Completed.... Charles W. Morgan,Sea Horse,USS Constitution,Virginia 1819,San Fransisco II, AL HMS Bounty 1:48
L'Herminione 1:96
Spanish Frigate,22 cannons 18th C. 1:35 scale.Scratch-built (Hull only)
Cutter Cheefull 1806 1:48 (with modifications)
Current Project: Orca (This is a 35" replica of the Orca boat from the movie Jaws)
Your Winchelsea is a beauty! A pleasure to follow your build log!
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Thanks so much guys for the comments and the "likes".
Chuck, I feel stupid and careless, but it's on pretty good with CA and probably not worth the risk of trying to get it off.
Bob
Bob CA Debond will work. Just let it soak take a sharp #11 blade and slowly ply it off. Start at the top slip blade in and drip in more Debond, let set,repeat.
Regards,
Jim Rogers
Damn the Torpedoes , Full speed ahead.   Adm David Farragut.
I was fortunate enough to get part four parts from the first batch. They arrived three days after ordering, on my birthday (81, for anyone interested). A nice birthday gift to myself. I was eager to go and have done the following so far: the sub-deck planking; the beams and carlings; the false deck; and the first layer of the bulwark planking. I also made up the two coamings that go over the sub-deck openings, just to see how they looked.
Although my installation of the false deck doesn't look particularly neat, all of the laser etched lines and the center line match up perfectly, and there should be no problems later on. I've also tested the deck clamps for the future fit of the deck beams and they should be right on. Now, it's on to the cabin paneling, the   second layer of bulwark planking and the bulwark painting.
Bob
Long time no speak  - thats splendid work you are doing Bob.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Looking great Bob. You sure didn't let any moss grow!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
I've been continuing with the part four work. First, I did the cabin paneling, using the laser cut parts. This required some fiddling, but I believe turned out okay. Then, I added the second layer of planking above and below the ports. Lastly, I painted the bulwarks red, using Modelmaster Insignia Red acrylic. On reflection, I wish that I had changed the sequence and done all of the planking and painting before the cabin paneling. I found the masking for the painting to be unexpectedly difficult.
I did one other item: I completed and mounted the quarter gallery roofs.
Next, I will do the margin planks and the inner counter planking.
Looking real nice Bob. Thanks for the advice to paint first!
Rusty
Superb work bob  - really tidy  really nice to watch.
OC.
Current builds
Completed works.
Thanks so much Rusty, OC and the "likes". I appreciate the generous thoughts, but more and more my struggles with Winnie make me feel that my best modeling is behind me.
Bob
Bob
I'm not seeing that Bob.
OC.
Current builds
Completed works.
I have now added the inner counter planking, using the laser cut pieces, I then made up the margin planks, using the templates and cutting in the scarph joints. After mounting the margin planks, I made up and mounted the waterways, using square strip wood sanded to a quarter round shape. Lastly, sanded the checkerboard floor to size and shape and glued it in place.
Next, I will do the coamings and gratings and the other deck parts.
Bob
Very nicely done Bob!
Rusty
Superb work, Bob. You are always an inspiration for me !
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • HMS Winchelsea 1764 - Syren Ship Model - 1:48
