I am guessing, but it appears to me that the pipes go from the galleries and down into the ship at the point of joining the pipes.  The pipe on the left of the picture appears to have a slope of approx 3-5 degrees, which is the slope recommended for draining.  So I would gues that these pipes are used to capture rain water, thus increasing the water availability for say personal grooming during long voyages?
Heghlu'meH QaQ jajvam
Slainte gu mhath
L.H.
Port side catwalks. I’ve added details like microphone boxes and speakers, with controls for the arrestor cables, fire hydrants and gasoline stations to be added later after painted off ship. I’ll probably do the gasoline pipes on this side next before moving to starboard as they have some somewhat “complex” radio towers which I need to figure out how to sling outboard. These is a LOT of detail to go yet.
Edited by RGL
Greg
6 hours ago, RGL said:
The level of detail is somewhat limited by how much reference I can find.
that's the problem with some projects.  but we all know that your microscope dials in more than most ;)   with what your adding right now.......it's the most impressive model I've seen!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Now, after much consultation I believe the next bit is gasoline lines. The kit gives a half baked attempt at them, so a little bit of plumbing work ....
Edited by RGL
Greg
Starboard side aft radio array, the Pontos stuff is lovely but does not factor in that they need to be lowered for flight ops. Not overly accurate but a small piece of plastic under lets it sit properly. 4485CACD-6225-47A8-BC42-A706C016D92F.thumb.jpeg.6df21036756aa1830971b0537ea08023.jpegB7ED0C7E-9F37-4335-9ABB-0EE8B059A4F3.thumb.jpeg.d0b1e031956b4e6cf0f7b2a031273b8a.jpegDB1AD1FE-9ED7-4518-AF86-FDF94630C021.thumb.jpeg.f367934d06643073402fcde6e405b857.jpeg
Also these photos from life magazine show them down as well as a shot of the Essex fully loadedCC5142A7-C51C-4739-A12C-82223E8E652B.jpeg.77534577978a8808bc92ee62874bbcb0.jpeg1D761640-F107-419A-AF8F-A2E6DD4C12C9.jpeg.750ed805a847e76a20f75f0c6e95c36f.jpeg6248F93C-3284-4050-A942-04A8B3ADF178.thumb.png.af7dfb2af6015762adfd85afc221461c.pngA0BEDC43-A582-40BE-8DA7-EA38B2C58D00.jpeg.005f691bc5a578a3172867376e01c79b.jpeg
Greg
Finally finishing the catwalk structures. Every platform has individual gussets beneath. Whilst there are lots of ladders and other details such as floater baskets to be added to them, these are now  good enough to stick on the sides of the flight deck. My intention is to prime them first to look for glaring errors then paint them off model so as I can add as much detail as possible then, as the deck will of course be a nightmare to stick on so I don’t want to have to do it with all this tiny fragile stuff.
Greg
WOW, the photo etch on this kit seems to be a gift that keeps on giving. I think I would be totally cross eyed by now! It almost seems amazing that you are able to keep track of it all.
Edited by lmagna
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Looks like a bad place to get a bout of sneezing! :(:omg:
Dumb question I suppose, but do you intend to fill them with float nets as well?
Enjoy your drink. I think I would be well through half a six pack by now!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Here are a couple of possibilities out of several:
https://freetimehobbies.com/1-350-white-ensign-photo-etch-us-stowed-floater-nets/
https://www.whiteensignmodels.com/p/WEM+1350+US+Stowed+Floater+Nets+PE+35110/5179/#.XfbNbOhKi1Q
But it might be just as well to put some glue globs onto lengths of thread, or wire and when dry paint, cut, and stuff into the baskets. But even empty, that many baskets will be impressive.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
The crimping wire may be the fastest, (Other than buying something commercial) Possibly you could just make a top layer rather than fill the whole basket? 54 is A LOT of nets!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
As part of my USS Kidd project I looked into a number of commercial items available to load the floater net baskets. The commercial items were all PE thusly very thin and required some creativity to make the basket look loaded. None of them worked for me even though I only had seven baskets to fill. Pictures of the real baskets show the gear was usually a lot of different stuff without much uniform distribution.  I just cut up some plastic rod of what appeared to visually simulate the basket's contents, painted some items slightly different colors, and loaded the baskets. I don't know if that would satisfy your well known desire for accuracy, but from a normal viewing distance, I'm happy with the overall impression.
Your idea of crimping wire is certainly worth a try IMHO.
Great work on the Essex.
Harley
Cheers, Harley<p
Under Construction:    USS Yorktown CV-5 1/200 by Trumpeter
Completed:              USS Curtis Wilbur DDG-54 1/200 by ILoveKit
                                USS Atlanta CL-51 1/350 by Very Fire
                                Liberty Ship John W. Brown 1/350 by Trumpeter
                                HMS Spiraea K-08 1/350
                                 USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                 USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                 USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                 USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                 USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                                 US Brig Syren 1/64 Model Shipways, Wood
Started, On Hold:  Frigate Confederacy 1/64 Model Shipways, Wood
