I'm speechless, Danny, amazing detail work on those chainpumps, I could almost imagine some exhausted sailors turning those shafts B)  Even more amazing is your precise wood details on the capstans, it's amazing how you make such intricate parts using tough ebony wood  :)
Best regards,
Aldo
Currently Building:
HMS Pegasus (Victory Models)-Mothballed to give priority to Triton
HMS Triton (first attempt at scratchbuilding)
Past build:
HM Brig Badger (Caldercraft), HM Brig Cruizer, HM Schooner Ballahoo
Thanks for dropping in, and the nice comments Robbyn, Michael, John, mhegazi, Grant and Aldo - much appreciated.
Horror! Shock!  Danny took a short cut with the rudder tabling! :P  :P  :P
Not the first, and not the last I guess John :D .
Wait until you see his performing wood worms!!! :D :D :D
Not to mention my trained Spiders when it comes to Rigging :D :D .
It just takes practice Aldo - not to mention a few thousand $$$ worth of tools ;)  .
:cheers:  Danny
Cheers, Danny
Hi all,
Work continues on the Rudder. I've cut the tabled and glued-together Main Piece and Blade to the required angle and shape. I've also glued on the Backing Piece and Sole Piece, tapered the assembly from top (14") to bottom (10") and cut in the recesses for the Pintles :
:cheers:  Danny
Cheers, Danny
Thanks once again John :) .
The rudder is "Bearded" on it's inner edge to allow it to turn without binding. I marked out the limits of the bearding and sanded the angles in with a cork block and sanding stick :
:cheers:  Danny
Cheers, Danny
Very crisp and precise joinery there Danny!
PS. I sent you a PM the other day and its still showing as unread.
Thanks Brian and Grant.
Better send it again Grant - it's not in my Inbox :huh:  .
:cheers:  Danny
Cheers, Danny
Very nice work once again Danny,  very clean and well defined edges and bevels.  Now, when you finish with those spiders, reckon they'd survive air transport down my way :)
cheers
Pat
Thanks for dropping in Pat and Adrieke.
Hmm, maybe I'd better send them down to you Pat - I won't be needing them for quite a while, and they're getting out of practice :
I could do a better job on shrouds and ratlines than them now :D :D :D
:cheers:  Danny
Cheers, Danny
Pintles
I made the rudder Pintles from 1.6mm thick brass sheet. First I milled most of the inside, leaving a thin piece at the bottom for strength while the rest of the work was carried out :
Then I cut each piece from the main sheet, sanded the angle at the fore end on the disc sander and drilled the holes for the Pins and bolts :
I filed out the thin centre and silver-soldered in the Pins :
Next job was to mill the rebates for the straps and recess the fore ends. For a Mill Cutter I ground the point of a 1.6mm drill flat - perfect tiny cutter (note - I only left a very short piece protruding from the chuck so it wouldn't snap off). The last two pics are of a dry-fitted pintle :
Then I lightly blackened them to simulate bronze :
And finally another dry-fit :
:cheers:  Danny
Cheers, Danny
Beautiful work on the pintles. Those arachnids sure are out of practice - may need to send them out for an apprenticeship!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Thank you very much David, Wayne and Greg.
Interesting approach to making these
Actually Greg, I came up with the idea when I looked at what sizes of brass stock I had (and I didn't have the opportunity to get anything else yesterday). Everything was too small apart from a big chunk of 20mm x 4mm that I'd scrounged up somewhere. So I decided to mill it to the right size and it escalated from there :D .
:cheers:  Danny
Cheers, Danny
Nice work on the rudders and the pintles came out especially nice.  Did you heat treat the bit after trimming it flat on the end?
Rebates for pintles? Holycow, I've not seen this before! Is this usually done on the real thang? I can't recall seeing modellers doing this. Seems like a reasonable real-world thing to do though.
Brian
"Give you joy!"
Current Build: RATTLESNAKE 1:64 POB (Mamoli)
Kits on hand: "Lexington", Mamoli: "Robert E. Lee", Scientific
Scratch to do: "Fannie Dugan", 1870s Sidewheeler Steamboat
Nice work, Danny.  That's a fascinating way to make the pintles, by the way.
Waht have you been giving the rigging spiders to drink?  Obviously it's far too strong! :D
John
Okay, I have it all figured out now Danny. I am in need of your mailing address. I will just mail you my Syren kit, and watch you build her...that way I will be assured of getting the result I want :P:D
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
Thank you Mark, Brian, John, Druxey, Grant, Randy, Russell, Robbyn, Ben, Geoff and Sherry :) .
No, should I have :blink:  ?
Yes Brian, at least on the Swan Class ships. It created a little less drag in a straight line.
Bundy and Coke - maybe you're right :D .
Whoah Back Robbyn - I already have three other ships I need to finish for someone else :huh::D  .
you could work in my blasksmith shop any time :)
Nah - sounds too much like hard work. Appreciate the offer though Geoff :D .
:cheers:  Danny
Cheers, Danny
Spectacle Plate
The Spectacle Plate holds the two chains to the rudder. These prevented the total loss of the rudder if it became accidentally unshipped, and could also be used as emergency steering if there was damage to the ships wheel etc.
I made this in similar fashion to the Pintles from one piece. Note the thinning of the eyes :
I actually had to make two of these - I measured the wrong part of the rudder the first time and finished up 3mm too short
goof.gif . It took me about 2 hours to mill, drill and file each one.
I also made another lower Pintle - if you look back at one of the previous pics where I dry-fitted the blackened pintles you'll notice that the lowest one is a little short. That's now fixed.
:cheers:  Danny
Cheers, Danny
Wow Danny,
That look tiny….
But again a great job.
I like the idea about the slave into the rudder.
You came up by your self with that or have you seen it some where?
Hi Danny,
I asked about the heat treating since I thought the grinding would cause the bit to lose its temper and not stay sharp.
