day 4 keel assy
good evening everyone
where do i start
all the keel pieces have been glued and have set
i have tracing paper over the plans held in position
but i now need to make it all fit,
do i make up the false keel as per the plans, mark it off and build upwards, i presume like a real vessel,
Everything is over sized lengthways by about 1mm, i presume i hand sand it down to remove the burn and slight angle from laser cutting,
yes im concerned i am going to mess it up
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
"WOW"  mate  this  is looking to be a Superb  build   - so love  seeing a proper scale replica  come together, something special  watching  frames  fitted and a hull  come togther like the  ship builder used to build them.
Following with kean interest.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
31 minutes ago, Kevin said:
Everything is over sized by about 1mm, i presume i hand sand it down to remove the burn and slight angle from laser cutting,
That is strange. I would get in touch with CAF and ask them.
Could it be the plan which is a tad too small?
Will the frames fit if you sand everything down by 1 mm?
How does it fit into your building stand?
This seems like a lot of sanding to me....
Yves
Yves
i believe this is the way on purpose, i should ne more precise in my statement, everything is about 1mm to long, sorry for the confusion, i will change what i wrote
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
OC.
Thank you OC
very different to any thing i have done before, but very enjoyable, how ever it will be very hard to hide mistakes, and i keep changing my mind about how to do things, bit like the chicken or the egg, are you and family well?
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
11 minutes ago, Kevin said:
Thank you OC
Yep were ok,  I am sure you will  make a Superb project out of this  - combining all your different  build skills  - they say we  all improve  in every new project we take on - learning bits from previous.
Really looking forward to it my friend.
OC.
Current builds
Completed works.
day 4 keel assy
well i made a start, all the ummm;s went out the window, and well two pieces have become one  and lots more looking like they will fit ok, sanding by hand is not working for me as it is rounding off the edges so i will use the desk sander tomorrow in the garage
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
day 5 keel and a frame 16
well after a slow start, i am getting a bit more confidence now, i have made a few mistakes, and as a result the gaps look wider than they are due to sanding with paper and not the bench sander as a result the edges are rounded off, but surprisingly it is all very tight and square
IMG_7571.thumb.JPG.5261644c3134fe05d2df66db2ee6d394.JPGIMG_7572.thumb.JPG.e5dad2e3931e44a7bfff26ada7f642e8.JPGIMG_7573.thumb.JPG.f77c73af7bf2c7b332c5eb67e558fca4.JPGIMG_7570.thumb.JPG.f8c9a52fd89a92f0507271aac72e75b2.JPGIMG_7571.thumb.JPG.9d1d66409d82091dba8dbc1f2db85a4b.JPG
i looked through the wooden bulkhead sheets and picked number 16 at random
looking through the drawings i identified all frame 16 parts, as they possibly have a couple of bits from the previous frame (15) and possibly from the next(frame 17) and marked with item number
all mating surfaces went against the bench grinder
Parts A and B were separated
found the corresponding paper plan, tracing paper laid on top and secured
all B items were turned upside down,
in this case item B4 was secured to the tracing paper with UHU glue stick, the rest of B items had wood glue added to mating edegs and again had UHU added to keep them in position
then all A items were laid on top in a overlap
IMG_7561.thumb.JPG.f91aeca9582aa22b2e47c9ae3651a1d3.JPGIMG_7562.thumb.JPG.cb9a0bbab1604b9357f5f1c8e9fd1682.JPG
weighted for a couple of hours
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
You should add some Marines to your build  28mm  British marines would look superb when painted😉
OC.
Current builds
Completed works.
OC.
lol i will build it, and they will come (or words to that effect)
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
1 hour ago, ASAT said:
Kevin, looks challenging - the jig looks absolutely huge on that padded bench seat, what are the dimensions of the finished hull?
Morning ASAT
its fun though, no longer will i be able to moan about not being right, if it wrong, its got to be me
https://www.cafmodel.com/hms-enterprise-1774-p0034.html
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
thank you for comments and likes
Day 6 keel and frames
i have a little routine going on now
all the frame parts have been identified and bagged
doing a few at a time they have been removed from the frets and the ends have met the bench sander
as required the required plan is found and frame built up
so far 6 have been completed
the top two in the photo are going back uder the weights as they are just out for the photo
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
I've just now found and wandered into the shop....   The jig alone is a project.   Looks like everything is going well, from here.   I'll get a seat for this.
"Cough cough  - and the popcorn"😉
OC.
Current builds
Completed works.
not many seats available, in fact there are two and one of them is for me, I never expected anyone to follow, its free popcorn, coffee and bar over in the corner
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
wondered where you were mark, your welcome
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
7 hours ago, clearway said:
<<<<<pops head round door takes one look, shakes head and books you in for some serious therapy🤣
can you make it for 5 weeks on Friday, i will have most of the frames done by then
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thank goodness you’re here Mark - I’ve been waiting for you to arrive and open the bar! I’m over in the corner with Sjors and the popcorn machine.
On 8/19/2020 at 10:33 AM, Tankerman said:
Kevin, I am a few stages ahead of you on the construction of this kit and have been hoping to find time to start a build log here soon. I am sorry to read that you are having problems with the building jig as I found that once I had sorted out what goes where from the instruction illustrations all went together as intended. The tabs and slots are a tight fit and work with a file is required to remove the char but as the jig will form the basis for an accurate hull nothing can be loose.
I have studied your photos carefully and cannot see how things went wrong, the photo below shows my jig in the same area.
I can assure you that you should not have any problems with the fit of parts as your construction of HMS Enterprize progresses. It is a superb kit but just requires a lot of concentration and pre-planning so do not be dis-heartened, you will enjoy it.
I see you too, are in Somerset. PM me sometime and we could probably manage a "socially distanced" meet up.
Chris
chris wrt the bevels on the futtocks, are the frames made up the same way as those without the bevels or are they offset?
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Kevin, I believe when it's time to fair you will see that the fore edges of the fore cants and frames will disappear while the aft edges will require little if any sanding. The same will hold true with the aft cants and frames except in reverse. The mid frames should require little if any fairing. If the kit has the actual bevel lines etched on I would strongly suggest you leave them on the full side until fairing. One over-bevelled frame can distort each frame around it.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Thank you Greg, which of coarse makes sense, what does not is why put them on there
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Kevin, the frames where bevels are marked were built with futtocks placed squarely on top of each other. You already have it correct by placing the B futtocks face down on the template, add the A futtocks on top and when you lift the assembled frame from the template you have the bevel marks visible on both sides. I use the Proxxon Micromot power drill with sanding drums to form the bevels and stop just short of the engraving marks. When you finally remove the hull from the jig there is only minimal sanding then required to fair up all the frames.
Going up to Bahrain on the Caltex Cannonball
Day 8 keel and frames
thank you for the comments and likes, very much appreciate,
well the bar was open today and everyone was very good at social distancing, wel to be honest no one turned up so me and dobs hit the popcorn
im think i have made a mistake, but cannot find one, , im not 100% sure of myself to have got it right first time
15 frames are made up, of which two are under weights, also the keel was extended today
in the photo the frames are just resting on the keel
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Looking good, and what a great idea the frames being pre beveled  - very very clever.
OC.
Current builds
Completed works.
OC.
OC the frames have laser markings where the Bevel should be, (photo shows it quite well), the frames are all made the same regardless if they are double, triple or quads
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
7 hours ago, yvesvidal said:
Kevin,
You wish you had a "James H." ahead of you, with his wonderful pictures and instructions. It looks right from our perspective.
Yves
agreed, i dont have the space for the decent camera shots, I will try to do better though)
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
