Sassafras 12 by ccoyle - Chesapeake Light Craft - FINISHED - 1:1 scale canoe - you read that right
Ugh. Tightening the stitches has so far been much easier said than done. First of all, I have broken a fair number of stitches during the process and had to replace them. Second is the issue with getting panels to seat into their rabbets properly. Here's one side of the canoe showing properly seated and stitched panels.
The exact opposite side of the boat refused to cooperate. I eventually hit upon a solution, but it involves removing about a half-dozen stitches and re-doing them. The unstitched panels want to create a roughly 1" wide gaping maw between them. I can squeeze the panels together -- I just can't stitch them at the same time! Which is what I attempted the first time around, and of course it didn't go to plan.
To finish this correction, I'm going to have to wait until an extra pair of hands becomes available this evening. Much of the problem with the bending is due, I believe, to the stiff 1x1 rub rails. In retrospect, I think it may have been better to stitch the panels first, then install the rails, but hey -- I followed the directions.
Cheers!
When you have to shoot, shoot. Don't talk.
- Tuco
Current builds: Brigantine Phoenix, Hawker Hurricane
Link to comment
Share on other sites
Hang in there CC!  Just wondering (not wanting to continue the painful memory) if the stitches with the provided kit, or your purchased material, broke more or less.  I have no idea why that seems so important when the more important point is that you are doing a great job, and have done well considering having only two hands (and two feet, just saying....).  😃 Good luck soon to be paddler.....
Link to comment
Too late now, but using safety wire pliers would be a good answer to tying off all those "stitches".
Link to comment
I probably should have said this earlier but a lot of stitch and glue builds use cable ties. Easier to tighten than twisting wire.
Link to comment
Yep, this I knew -- we call them "zip ties" in these parts. I thought about these many times while twisting various wires. Of course, using them would have required drilling out all of the holes larger.
- Tuco
Link to comment
nice progress Chris...will you have to calk in the seams?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
The seams will be epoxied inside and out. The entire hull also gets coated with unthickened epoxy resin inside and out, and the bottom panels will also be fiberglassed inside and out.
- Tuco
Link to comment
So, I made further progress, but you don't get any pictures -- because I botched it. 🤨 I thought I had the consistency of a batch of epoxy correct, but in reality it was too thin. Made a bit of a mess, and I have to re-do part of the task. Pics later ... maybe.
- Tuco
Link to comment
Hang in there Chris, hope it all works out.  So far looking very good!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Not gonna like it  Chris, but you will sort it.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Been epoxying seams -- first step is to "tack weld" between the stitches. Instructions said to make the epoxy the consistency of hollandaise sauce -- big help. 🙄  First batch was too thick, second was too thin. Still have about a third of the tack welding left to do, but I ran out of steam for the evening.
- Tuco
Link to comment
It looks great.  When I was building the Pygmy kayak I usually made the thickened epoxy about the consistency of peanut butter.  The problem is the bigger the globs the more you have to sand/carve the extra off.  With a clinker hull that would be harder to do.  I ended up using one of these things and it worked out pretty well.
Link to comment
Looking good  - The "Pointy" end is looking  well - Pointy     - you are doing fine work  Not easy at  Full Scale   all your hard work will be worth it in the end.
As an example of a "Not"  very good project  - my late farther once built me a square wooden  paddling pool  -  it didn't work  fell apart  but the good news  - atleast  it watered the plants in the garden.
OC.
Current builds
Completed works.
Link to comment
I forgot to edit my post last night -- I got up a second wind and whipped up a last batch of resin. It was like a Goldilocks moment -- it came out just right. Let me just say that getting the right consistency made a BIG difference in both the speed of finishing the task and its neatness. So tonight I get to have a clip-n-pull party for all those stitches, oh boy! Then we'll get to see what it looks like without the "porcupine" visual effect (or "cactus," as someone at work called it).
- Tuco
Link to comment
Stitches and temporary bulkheads out now -- kinda looks like a real boat. Next step: prep for fiberglass -- say hello to Mr. Sandpaper.
- Tuco
Link to comment
Sand paper is your friend, for now but you'll come to hate it.
One tip I learned part way through sanding epoxy is use wet&dry with a little water and once the "dust" becomes paste it really starts cutting well
Link to comment
It's a neat little boat, Chris. You're doing a bang-up job. How did you overcome the gap issue?
Link to comment
looks great Chris.......inside looks really good :)   must have been fun plugg'in all those holes  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Progress continues, but it's not terribly exciting. The next step of the build is to prepare for fiberglassing the inside of the hull. The major component of this prep is to sand smooth the fillets around the bulkheads and to clean up the messy spots.
This is one end of the hull finished up. I did about five hours of sanding last weekend, but I didn't keep track of how much total time the job required.
The other end of the hull is about half done. Here's one side, on which sanding has barely started. You can see it looks pretty rough and there's a lot of slop to clean up.
And here's the other half, which was today's task and is about 95% done. Lots of fine dust all around. I had to stop for the day because the sandpaper was wearing my fingertips raw.
That's all for now!
- Tuco
Link to comment
  • 5 weeks later...
Milestone: Yesterday I finished sanding all of the interior fillets and assorted oopsies. I also cleaned up the puzzle joints. Ridding the hull of all the fine dust posed an interesting problem, because I do not have a suitable vacuum for the task. However, I hit upon a nifty solution. After using a whisk to get most of the dust out, I took the canoe outside and blew the remainder out with my leaf blower. It worked a treat, too! Now, unless I missed something in the instructions (I will double-check, of course), we should be all set for interior fiberglassing.
- Tuco
Link to comment
Chris,  Very Nice work!
A suggestion-  I assume that the bulkheaded ends are for flotation.  A number of years ago I built a similar canoe from Tom Hill plans using the glued lapstrake method,  the same idea as your stitch and glue but a different process.  Anyhow, I filled the chambers at each end with urethane foam; the same stuff used for weatherproofing buildings.  If the canoe ever swamps, you don’t want to find out that a pin hole leak has allowed the flotation chambers to flood.
Link to comment
Coming along nicely and looking good.  If I lived anywhere even close to a lake I would definitely want to build something like this.  Would be a great way to get some exercise paddling around a lake!
Link to comment
This is so cool! The leaf blower was a really good idea, I wouldn’t recommend it on smaller models though lol!
Bradley
Current Builds:
Flying Fish - Model Shipways - 1:96
Future Builds:
Young America 1853 - Scratch Build - 1:72
Completed Builds:
HMS Racehorse - Mantua - 1:47 (No pictures unfortunately)
Providence Whale Boat - Artesania Latina - 1:25 (Also no pictures)
Lowell Grand Banks Dory - Model Shipways - 1:24
Shelved Builds:
Pride of Baltimore 2 - Model Shipways - 1:64 (Also no pictures)
Link to comment
 I quit vacuuming the inside of my truck years ago, no carpet, just a rubber mat sill to sill. I use the leaf blower, much simpler.
 Nice job on the canoe, Chris. You have many leisurely days out on the water to look forward to.
Edited by Keith Black
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
