Mobbsie,
Ditto what Sherry said about "keep up the good work".  Looks great.
Mobbsie,
Took my shades out ... she looks brilliant!
Carl
Fabulous.  I really like the look of it.
One question.  On the rudder.  Was there any mention on the plans of beveling the leading edge of the rudder to allow for rudder throw?
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Now thats some fast plating, but again not to be unexpected. Your not using Gnome labour are you?
Beautiful as always?
and as Augie asked, shouldn't the rudder be fitted/shaped before plating? Heck its probably already done and the other side half plated. Wish I could be faster except I like taking my time too much. :dancetl6:
looks fantastic - well done
lol - took me 150 hours
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hi Guys & Gals,
Thank you very much for the vote of confidence and your constructive comments and as a result changes have been made.
Ben made a very good point with regards to the rudder pintle's, the recess's have been squared and the all the copper plates removed, the platres have also been removed from the stern post so hopefully making it a better fit when the time comes.
The stern post and leading edge of the rudder have been painted copper.
Augie, there is no mention of bevelling the rudder but it does need to be tapered along it's length from 5mm down to 3mm, this has now been done and coppering will commence once again.
Keith, I also like to take my time and I think I do, it's just that when you get into a zone all else is forgotten and you end zipping along, it's just the way I am I suppose.
As far as the time taken is concerned I didn't put a clock on it but from dead reckoning it must have taken me about 25 to 30 hours for the starboard side. I will record the port side a little more accurately if I remember.
OK onwards an upwards, I hear the sound of copper plates calling me, time to go slightly insane.
Again thanks for all your very kind remarks and comments and thanks for putting me right on the rudder.
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Nice work in progress over there !!,  copperplating looks really great, your "Aggy" starts to become a real gem.
 keep up the good work and picture coming !!
Greetings ,
Martin
awesome job there....Mobbsie!  you've done it like a pro! ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Never in the history of mankind has one man brought so much pleasure to so many others. :)
Augie
Previous Builds :
I'll drink to that!  WHOOOOOHOOOOOO! :cheers:
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Mobbsie
                  Coppering looks great I am at a similar point with my Diana and the coppering patten looks about the same, its a bit scary where to put the gore line as you do not know if it is right untill you have completed one side. I have found the Caldercraft plates fix very well, and cut well, second side should be a walk in the park, all be it a longish one.
Regards Ray
Ray
 Current build A set of HMS Diana`s boats @ 1/48
 HMS Royal Marine a Military class Trawler
 Completed  HMS Diana
Completed build The Lady Nelson
Completed Build HMS Pegasus
Wow Mobbsie! You weren't messing around! That would have taken me forever to complete and it wouldn't have looked half as good as yours! Very well done!
hamilton
Hi Mobbsie
Not only the copper shines, but also your workmanship.
And reworking the rudder is a very good point, almost always neglected in kits instructions (and promptly forgotten on my build).
Take care
Peter
Hi Guys,
Thanks for looking in and the good words and encouragement given, it does really help. :cheers:
A quick progress on the coppering, IT'S FINISHED, the port side took me about 25hrs to do with a few fopars along the way. :)  :(
The last couple of days have been almost a nightmare for me, I've had the droppsies which, when you think about it doesn't seem so bad, a bit frustrating perhaps, but I'm talking blades here, I have picked up a few cuts along the way, nothing serious, some I didn't know I had, a bit scary though when you see a craft knife falling and heading for the bulbous belly, this happened a few times, picked up a few puncture wounds with that. :o  :o:angry:
Tweezers with very sharp points sticking in the palms of my hands, my thoughts at that time were similar to " blast that really shouldn't be happening ". ^_^
The final straw was the Aggy falling from it's foam matt onto the floor, not too much damage though, just a little crushing of the stern post and a few popped plates, the stern post just needed to be trimmed and the plates stuck back on. :angry:  :angry:
I had to pull a few plates of the bow as they were not following the correct line, the old glue then had to be scrapped of and the plates replaced. :)
The rest was pretty well straight forward with no major problems.
I have learned one lesson though, when I next plate a ship I will be overlapping slightly, Caldercraft plates have rounded corners and as you can imagine these leave an unsightly gap. :huh:
OK I have a few pics.
The offending area that needed stripping and replating
Stern view.
Portside view
Now the fun begins, cutting in the waterline
More cutting in
The finish
So there we have it, all done.
Next step is to place the rest of the trim on and complete painting her.
mobbsie
Edited by mobbsie
mobbsie
Next Build :-
