Thanks Bob.  Was just wondering if there was some "Admiralty Rule" buried in a text from 1790.  I could never really find anything on that.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Beautifully done, Bob! But by now I am not expecting anything less from you . . .  :)
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
I love that boat Bob,
That dull black color is just right, looks great...
Nils
Current builds
-Lightship Elbe 1
Completed
The longboat installation is now complete. I first added boxwood chocks to the beams. I then made up and installed brass ringbolts on the beams. Next, I made up some oars from very small dowel and boxwood strip and placed them in the boat. You will probably notice that I only added 4 oars, which is certainly too few. It just seemed a shame to cover up all of the interior detail in the boat with a larger pile of oars.
After gluing the boat to the chocks, I made up 2 lashings through the ringbolts to hold the boat. I'm quite pleased with the way it looks in place and am now debating with myself whether to add a second boat of some kind from the stern davits, at some point in the future.
Work is now underway on the hammock cranes.
Bob
Great work, Bob.  This boat looks so good, I'm definitely in favor of seeing you add another!
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
I agree. A stern davit boat is most definitely in order.
(By the way, good call on just the four oars for your mid-ships boat.)
Edited by CaptainSteve
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Really a nice, clean assembly all around.  Love the oars!  And the black hull picks up the other accents.
Augie
Previous Builds :
Thanks so much guys for all the very generous comments and the "likes". The boat was one of those fun things that makes some of the more tedious tasks worth doing.
Bob
The boat looks terrific Bob. And you should definitely make another to fit the stern davits, if for no other reason than I'd like to see you scratch build a POF boat! I know it would be awesome and as you have observed already, making boats is an enjoyable and interesting diversion from some of the more tedious tasks. :) No pressure, of course ;)
There is not much I can add that was not already said. Your Essex is just a fantastic sight!
Thomas
Bob,
next to your excellent HMS Essex, that  boat lashed to the supports Looks so great and admirable, it realy is inspiring for me to do hopefuly alike for my HMS Pegasus, at least I left an adequate space in hight for it under the main stay sail. Your boat has all it takes to look like a propper work- and traffic boat, no fancies, but Color, Wood tones, Fitting out and the general apeal are just wonderful
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
just caught up with your log Bob, she looks fantastic, the ships boat looks great - well done
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
A quick update. The hammock cranes have been installed. This work went surprisingly quickly and easily. I used the kit photo etched brass parts which are nicely done. These were glued into holes drilled into the rails. Rather than using rigging line for the guidelines at the top of the cranes, I use wire to provide added strength and stability. After the wire was glued in place, the assembly is remarkably strong.
Now for the fun part  :P -- fitting and attaching the netting in the cranes.
Bob
The wire looks good. It probably puts a lot less torsion on the photo-etch as line would. Superb as always!
- Tim
Nicely done Bob, I also used wire for the Agamemnon and it works very well, it also makes it a lot easier to attach the netting.
Good luck with that mate.
Be Good
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Thanks so much Tim, Augie, Sjors and Mobbsie and also the"likes". I've used the wire before and it works much better for me.
The netting is going in now Sjors.
Bob
The hammock netting has now been installed in the hammock cranes. The netting is the veil material from the kit. After cutting into oversize strips, I steamed it with an iron to remove the kinks and soften it. The strips were then glued to the crane bottoms and the wire at the top on each side, using medium viscosity CA. Final trimming was done using a small scissor and a razor blade.
With completion of this item, work on the hull is now finished for the time being. The remaining hull work ( head, lantern, anchors, stern boat ), will be done during, or at the completion of, the rigging. I am about to begin the standing rigging.
Bob
Hi Bob,
Great job on those finicky hammock cranes and netting and I never thought to iron the netting.
Gotta remember that one. B)
Rusty
"So Long For Now" B)
Current Builds: Speedwell
