2 hours ago, Dave_E said:
Are all those ribs card? They look like wood.
Yep, they are all card. They are part of the laser-cut frames set, cut from what the Poles call "beer mat" stock -- it is the same stuff used commercially to make disposable coasters.
On to skinning the spine. The kit includes joiner strips, which is nice -- I would have made them myself but the kit spared me the effort.
I glued the first four pieces together using their joiner strips, then glued the entire piece first along one side . . .
. . . and then along the other. The color registration is good.
I got a bit of a seam gap on the other side, which I'm going to try to remediate. We'll see how that goes.
I'm interested to see how that seam gap is remedied.
Here's the patched-up seam. I first filled it without about three passes of canopy glue, then applied a thin wash of appropriate edge color, followed by a shot of matte clear spray to take the shine off the filler. It doesn't look too bad -- certainly not the Polish Touch, but better than the untreated gap looked. Naturally, bright lighting and closeup photography makes it look worse than it does at normal viewing distances and lighting.
And here's the rest of the spine.
I cant get my nut round  what you  do with  paper/card.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
6 hours ago, Dave_E said:
Did you say once you got from Hobby Lobby?
Yep the brand they sell is known as Formula 560....
A go to glue for many thing....
Quote:
A bit more progress. I needed to take a slight detour and make the rudder so that I could confirm the positioning of the vertical stabilizer skin. Unlike many kits, the rudder has no internal framing.
And then the vertical stabilizer was skinned.
And that's it for the moment. Next up will be the wings' internal framing, but first I need to take a break and watch the Champions League final (I'm strictly a neutral for this match).
First step in making the wings was adding the remaining internal frames.
Each skin is a single piece, shaped, folded, and glued with the help of a joiner strip.
Each wing structure is then slipped into its finished sheath. No fillets have been added yet.
That's it for now.
This looks amazing, Chris!  I'm really glad to see this kit.  Based on seeing your other card airplane models, I bought a Halinski P40 kit with the laser cut frames and the canopy option.  But when I opened it, I was totally intimidated by it!  I love watching you build yours, though.
HMS Winchelsea 1:48 (Group Project)
Completed Builds:
Virginia 1819 Artesania Latina - 1:41
Hey, Halinski still intimidates me, and I have many finished models under my belt!
BTW, which version did you get, Flying Tigers or RAF North Africa?
Mine is the Flying Tigers version.  My main airplane interest US WW2 fighters.  I have a couple of plastic kits on the shelf.  This kit looks great and I’m thinking about ordering one.
Completed Builds:
On 6/5/2023 at 2:06 PM, CDW said:
When canopy glue came out it (a long time ago) was used to glue clear canopies to R/C aircraft models. I learned quickly I had to literally tear/cut a model apart to break the bond between canopy and airframe once it set and cured. A very strong glue and it dries clear.
I am also a big fan of canopy glue, but use CA for almost everything else. However, I've never built a card model. Do you use canopy glue or something else for most of your construction? How do you hold the parts together while the glue dries?
I've taken to using canopy glue as my all-purpose glue for card modeling. It sets quickly, so holding or clamping is not an issue.
Update: Fillets are done. These are always a tricky part of any airplane build, and these were even trickier than usual because there is a cutout for the wheel wells that leaves a strip only about 1 mm wide at that point for attachment.
And now we go back to the empennage. So far, I have only finished off the internal frames for the horizontal stabilizers.
That's all for now!
This is  Crazy  good   -  looks  just like  the  skin of the  real plane.
OC.
Current builds
Completed works.
It helps when each stabilizer skin is a single piece -- no seams! Also, Mr. Dworzecki is a master graphic artist.
Uh-oh -- progress may be slowed in the short term. My boss, a former A-6 driver who shares my affection for military aviation, surprised me at work today by loaning me his copy of Dead Reckoning, an account of the P-38 mission that took out Admiral Yamamoto. I haven't read a good history book for quite some time. Of course, I told him he'll be to blame now for my increased felt need to acquire a P-38 for my stash, a purchase I've been avoiding due to the finished model's size in 1/33 scale. And no, I won't build anything in a different scale, so don't ask. 😁
You've always wanted to, admit it, just haven't convinced yourself yet... {chuckle}
Quote:
