7 hours ago, wefalck said:
The number and quality of the models and tools on display has gone down considerably. Haven't been to the show since the late 1990s or so and probably won't go again.
I have to agree Eberhard. I went a year ago and was pretty unimpressed. I think the decline mirrors the nations move from engineering to a service economy.
18 hours ago, michael mott said:
tomorrow I am going top purchase a slitting saw that is .064" and 2 1/4 inch in diameter
Michael. I find that I prefer the smaller diameter slitting saws which when combined with a decent thickness seem to run more true and hence are more accurate. Interesting use of Allen key although I think I would prefer to use the slitting saw for this sort of task. I will need hinges at 1/36 scale some time in the future so we will see how the method scales.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hi Keith what sizes and what brand are you using, the ones I looked at on the net that are 1" or 1 1/2 inch diam were $100 -200 which is beyond my budget.
Michael
Michael - yes beyond my budget as well. I buy a lot of my tooling from a British based supplier (Chronos) - but as ever these days much of the stuff originates from the far east. That said I find their HSS slitting saw blades to be of good quality. I think they ship worldwide.
https://www.chronos.ltd.uk/product-category/gear-cutters-slitting-slotting-saws/metric-hss-slitting-saws/
https://www.chronos.ltd.uk/product-category/gear-cutters-slitting-slotting-saws/imperial-hss-slitting-saws/
Of the far eastern manufacturers I find Soba (Indian) equipment to be well engineered and they do make slitting saw blades.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Sorry to read that the Model Engineering Exhibition isn't what it used to be. I well remember being taken by my father in the 1950's and early 60's (OK, so that dates me!)
The mental image of a whirling Allen key gives me the shivers.....
Slitting saws have standardised dimensions, starting with 20 mm. In the watchmaking industry supply, you may also find smaller ones, with 3.5 mm or 4 mm holes, but they tend to be pricey. Thickness starts from 0.2 mm, but some suppliers also have 0.1 mm.
20 mm Ø - 5 mm hole
25 mm Ø - 8 mm hole
32 mm Ø - 8 mm hole
40 mm Ø - 10 mm hole
50 mm Ø - 10 mm hole
63 mm Ø - 10 mm hole
Larger sizes then have 13 mm and 16 mm holes.
Nice re-do on the cabinet woodwork Michael, and they are beautiful just as I knew they would be.  Very interesting discussion on the making of scale hinges, but aren't the screw slots supposed to be horizontal?
Gary
Completed Scratch Builds
Druxey,
It all depends on circumstances, if your father took you as a toddler or a teen ...
I look at it as Allen twirling his keys and it seems less daunting.
Michael,
I was under the impression you knew all about brass, now it seems you have some (memory) gaps in your knowledge!! You still are my #1 when it comes to brass work. Really lovely details, and explanations!
Carl
At the end of the 1950s I was just geeting out of my toddler years and already very much interested in everything mechanical. Unfortunately, there was no MEE in my country. My paternal grandfather (a torpedo mechanic in the Imperial German Navy up to the end of WW1) surely would have taken me there, had there been a MEE and hadn't he suffered from dementia and died too early. My father was into electronics and always a bit ambigeous about my model building activities.
Well Gary not according to some learned members of this site. From a logical perspective though having the moisture, dust , able to fall out via gravity makes much sense to me.
There are some  "known knowns; there are things we know we know" about brass. "We also know there are known unknowns; that is to say we know there are some things we do not know" about brass.
Sorry Carl I couldn't resist.
Michael
I have a dry quirky sense of humor Michael - I was just ribbing you about the screw slot orientation discussion.
Gary
Royal plural, Michael (I couldn't resist it either ;) ) But thanks to let me know about the known knowns and unknowns, it makes even me knowledgeable.
Carl
I picked up my new slotting saw and arbor yesterday I like the way it cuts. I also prefer using the lathe for making the slots rather than the mill The worm on the quill is a bit worn and the very fine depth adjustment is still able to be done but is much more fiddly that on the lathe when making multiple increments for slots on the lathe I just need to index the carriage along the bed. All the same issues really but easier to deal with on my lathe. Ah the joys of backlash on old machines (50 years)
Nice clean cuts these are .057" which is the thickest width on the 2 inch diameter saw with 110 teeth
Michael
Spent a few hours this morning mucking about with turning tool form, working at making minute screws from hard brass which turns  better than the small brass plated pins that have heads that are forged and require some very careful cleaning up in order to create the fake screws. I eventually came up with the formula for the smallest screws they have a .5mm body with a 1mm head.
This afternoon assembled the top half of the port side paneling after finishing the forward cabinet door hinges, I glued on the rear vertical supports and boxed out the interiors of the two cabinets. I am still deciding haw to deal with the middle panel. yesterday I picked up some very nice tan material for the cushions.
The insides of the cabinets are recycled extremely fine grained old growth clear fir that came from the redwood garage door The frames around the redwood panes was old growth clear fir.
I put a coat of Tung oil on the maple it has a nice glow.
Michael
Beautiful joinery, Michael -
Love the spalted panel.
Dan
Michael - screw slots look a little wide and deep .............................. only joking - well done.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
I quite like solid brass pins as raw material, because the forging/stamping process hardens the material and makes it easier to turn. However, if you have access to hard brass rods, that is probably the easier option, requiring few machining steps.
What shall I say, I can only join into the chorus of praise ...
Thank you All for your kind comments, and also to those who are following along quietly.
I spent the morning sorting out the forward and aft bulkheads for the dining area had to scratch my head a few times. This afternoon was spent prepping the materials for them. I have decided that the forward bulkhead will be made to include the sides of the seating areas, and will have a location tab at the edges to locate the forward ends of the side panels, the aft bulk head will form as parts of the cooking area and as there is no door they are smaller and will also have a location tab for the aft end of the side panels.
A couple of shot showing today's progress
Michael
Beautiful joinery Michael, a master carpenter couldn't do better.
Those screws look great; any chance of seeing the 'formula' or process you settled on?
cheers
Pat
Michael, have you considered making up a scale bill of sale or papers showing the shipwright, you, and the completion date that you can stick in a cupboard or something in the interior that may be found in years to come. I met a modeller at ANMM years ago that had the pleasure of being part of a miniature camera probe deep into the bowels of some of the original admiralty models at a maritime museum in England and they found interesting things.
Pat Thanks, I will draw up the sequence that I used, it might take a day or so.
Steve funny you should mention that, The very first model that I made when I came to Canada was a silver  plated model of a Sherman Tank that was used in the second world war that helped to liberate Holland I made it for the Sarcee Barack's Silver collection. it was a 1/72 scale model and the track actually worked there were 1571 parts that were made to complete this model. I folded a piece of paper with my name age address and that I made it, and placed it inside the model before it was delivered.
I had forgotten about this until you mentioned the idea so yes I will do that perhaps in the charts locker.
Michael
After watching your construction of the door hinges, Michael, I was holding my breath waiting to see whether you'd be able to fabricate operating latches to scale or have to "fake" them. Your Sherman tank answered that question!
Brass handle combination for small warded lock
Blank key for delicate yacht lock
Cupboard rim lock
For those who are unaware of it, Toplicht is a chandlery firm in Hamburg, Germany, which carries what is probably the most extensive collection of ship and yacht products anywhere in the world. They are in many instances the only source of many traditional yacht and ship fittings left. Their nearly 500 page free catalog is full of photos and engineering drawings for all sorts of bits and pieces of "jewelry" and I'd nominate it for a "must have" in any scratch builder's reference library.  https://www.toplicht.de/en/catalog
Druxey thank you, yes I had hair in those days I was 19 years old.
Bob thanks for the link. I shall sort something out.
Michael
  Patton would be proud of your work. As usual.... the craft was obvious back then...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
5 hours ago, druxey said:
Yes, Michael, we all had hair back then!
And it wasn't gray either.
Well now that we agree we all had hair we can move on. first for Pat the sequence for making the screw like pins
then mounted in the pin vice to cut the slot.
I spent the afternoon fitting the rails and stiles to the plan I used the shooting board a lot to trim pieces to length.
Then prepared some more salted maple for the bulkhead panels, some trimming still need to be done to bring the panels to the correct widths.
This is the material I picked up for the cushions.
And this is the way they will look with the buttons , these are cotton seat cushions from one of the garden railway carriages.
That's all for today.
Michael
All I can say Michael is WOW !
Jack
Current buildUS Constellation
