Posts posted by captain_hook
After the glu has cured I use 120 grit sandpaper wrapped around a round wood to sand and taper the inner side first. Using power tools (i.e. a dremel) might take off to much wood because the cherry wood is rather soft. So I can keep a better control doing this by hand.
I start with an rather wide angle to remove the laser char close to the tapering line.
Then the angle is adjusted to cover the whole surface. The tapering lines are already marked by laser. Half way done..
.. and the other side as well.The last step is to remove the laser char from the steps that will later hold the planking. The steps have to be tapered too but all tapering lines are engraved by laser. I use different needle files, diamond-plated first for the burned surface and steel ones for finish. The finished frame will look like this. Another sanding can be done with 320 grit sandpaper to remove all remaining laser marks and char on the surface. The final adjustment for the steps will be done when all frames are permanently installed to the keel.
Meanwhile I have done 9 frames - about a quarter of all frames to be done.
- HardeeHarHar, PoulD, marktiedens and 13 others
16
Thank you Yves. Construction of the frames continues. The frames at stern and stem require a lot of bevelling. I might show my way to build these. First I release all required parts of a single frame out of the sheet using my bandsaw to carefully cut the holding bridges.
To avoid mixing the parts I use a little box to keep all frame parts together.
Then I sand the heads of the parts prior to gluing them together because these areas are difficult to reach and sand later.
The frame is then glued together (frame 32 shown). I use a cork sheet and pins to secure the parts in place.
Congratulations, she is a beauty!
- FriedClams and JpR62
2
Thank you for your feedback. Yes, the lower one is also my favorite. I‘m going to change the design so the inside of the cabin will be visible through the windows. But I have to consider about how to remove the plywood bulkheads without weakening the structure. I will do that next year. Stay tuned ... and save.
- Edwardkenway, mtaylor and JpR62
3
Nice! I will follow on this. The Winchelsea is on my wishlist too.
As I'm focussing the Coureur at the moment there is little time for the Badger but I will get back to her in January next year (or earlier if I got tired of building frames). I'm currently thinking about a custom stern gallery and have done some artwork with Corel Draw. There are two versions i prefer but I have not decided yet which one I will use. Stay tuned..and save.
- GuntherMT, Gregory, GrandpaPhil and 2 others
5
Thank you for the nice words and the likes. Another two frames done. This building step may take some time and I fear I won‘t have anything new to show except frames within the next weeks. As a few frame parts have very ugly defects (black spots) I am going to scratch-build replacement parts as needed but this will also slow-down the progress. The next frames (12 - 15) will have some slight bevelling that has to be done. Stay tuned .. and save.
I have done the first three frames today. For an easy start I choosed some of the center frames that don’t need any bevelling (16-21). Sanded the heads of all parts with my disc sander first and then glued all parts together using some pins to fix them.
Then I used a needle file and some sanding sticks to get rid of the laser char. Again this took most of the time.
Wanted to do six frames but only finished three then I lost my motivation because - boy, this is time consuming and very monotone stuff. Will finish some more tomorrow .. stay tuned.
Fortunately setting up the jig was easier than expected. I removed all laser char from the side panels (A1 - A7) so the frames won‘t sit in too tight. Then assembled the jig without glue using some wood screws and scrap wood to hold the parts in place. So I am able to remove the jig if that becomes necessary. Now the keel and stern structure is pretty much locked up.
Will start with the first frames next. Stay tuned .. and save.
Very nice solution to replace the casting!
- Overworked724 and Gahm
2
So this is what I have done so far. I don‘t know if the cant frames are to add at this point or later but as there are Position markings inside the jig I assume they have to be added later during the build to the correct positions. So I will set up the jig during the next days after Christmas and start building the frames. Or just relax for some days...
I wish everyone on MSW a merry Christmas and a hopefully better 2021!!
Best regards,
Andreas
Thank you for the nice comments.
@yvesvidal Hm, don‘t know why the extensions are that long. Maybe for better handling while gluing the counter timbers together. They are supposed to be trimmed later.@Ron Burns There is a lot of post-processing needed - even for the CNC-milled parts. And you have to care a lot about not sanding too much substance off when getting rid of the laser char. But until now the overall part-fit is very good.
- JeffT, Rik Thistle, Peta_V and 14 others
17
To assemble the stern and counter frames I used the supplied jig parts as reference. I started construction with the 9 middle stern timbers that are glued together to form the center piece. This piece is glued into the notch already milled into the stern post.
iAs PoulD has pointed out all frames glued together are much too thick so they require some sanding, These stern frames were the first to be installed and then I used the rear jig parts for reference and installed the center horizontal timber.The lower part was done next.
The counter timbers are pre-milled but they still need some post-processing. They come in three separate parts that have to be glued together. After some sanding they were ready to be installed.
The last piece to be installed was the one that sits above the windows. I used some wood blocks to equal the height (8 mm) on both sides.
Then the rest of the stern timbers were added.
- Rik Thistle, GuntherMT, bruce d and 8 others
11
After some recovery I am able to continue the.build. Before assembling the counter and stern timbers the parts have to be released from the trays. Although CNC-milled they need some post processing to get rid from the holding bars. I used different needle files and sanding paper to clean them. The stern timber’s are laser cut, so they have to be cleaned too to get rid of all the laser char (again this took most of the time). The sanding has to be done very carefully as some parts might easily break along the grain.
Now all parts are ready for installation ... which will be done tomorrow. Stay tuned... and save.
Nice perspective photo shots. You can be proud of her.
- WalrusGuy, Edwardkenway and Justin P.
3
Beautiful and inspiring!
- Forlani daniel and mtaylor
2
Thank you all for the nice words. A smaller cyst can be treated with puncture but unfortunately not mine. I have passed the operation yesterday and will return home tomorrow. ASAP I will start with the counter and stern frames. Stay tuned .. and save.
- gjdale, rkwz, HardeeHarHar and 5 others
8
Very nice! Meanwhile there are a bunch of nice medieval kits out there.
Le Coureur 1776 by captain_hook - CAF - Scale 1:48
Posted · Edited by captain_hook
Unfortunately I ran into my first construction problem. I started to build some stern frames which require a lot of tapering. Building instructions of all frames are rare but all parts have tapering lines already engraved - which means you have to rely on the the correct positions of these. There is a tapering line at the bottom of the rear side of the upper futtocks and I read this that the lower head has to be tapered straight from the opposite edge to this line.
But tapering will reduce the width of the part at the lower edge, means the inner edge run from inside to outside. Compared to the plan (side view) after tapering the run of the lower side edge of the futtocks (installed on the frame) matches the plan (although there is a little perspective error). If there was no tapering then the upper futtock edge run would rather look like stairs.
But the topside view of the frames 31 - 34 doesn‘t match the plan. Here are the topside plan and a picture of the prototype:
And here is a picture of my assembled frames 31 -34. Note the run of the lower inner edge of the upper futtocks - they run quite into the opposite direction and I don‘t get the reason why.
So at the moment there are only two possibilities for this that come into my mind. First the tapering angle is incorrect so too much tapering has been made - means the tapering lines were misplaced. And the second is there is no tapering at all and the line has to be ignored. I have contacted Tom from CAF, he has gently replied very fast and showed me some perspective views - but these look like there is no or only some slight tapering at the lower edges of the upper futtocks. But no tapering would hardly match the side view of the plan. Any suggestion would be helpful.
Best regards,
Andreas
P.S. Fortunately these are the only tapered frames I have made so far.
