mtaylor
Moderators
Everything posted by mtaylor
  1. The problem with laser cutting is the manufacturer, not the process. If they take the time to check the settings and calibrate it can be very accurate and relatively clean. Chuck (Syren Model Company) and some other companies are proof of this as are some of us who own lasers. CNC can only go so small due to the mechanical needs of the cutter. Both CNC and lasers are far superior to the old die-cut methods. The burn that you see isn't burn at all really. Some is smoke, some is char. With good drawings and care in cutting, a light sanding will remove the char and not change the dimensions. Yes, there is always some fitting to be done because it's wood. With some manufacturers, it's a problem of redrawing their drawings and investing in the cutter as well as the person(s) who will run the machine so they stay with die cut. Others have gone to CNC but from a manufacturing standpoint, it takes a lot of time to CNC as multiple passes must be made so as not to have tear out. I'm tickled with my laser as I can cut parts incredibly small that I couldn't cut using a scroll saw or a CNC.
  2. Allan, What about fabric glue? Some of them are waterproof and pretty durable as well as remaining flexible.
  3. Mike, Do the plans show a stern view? If they're rounded out like what Alistair did, I'd think you'd see a bit of them outside the taffrail. Maybe.... On your plan, I don't see anything to indicate the shape that Alistair used. The drops below the windows appears to be a different story. Due to the shape of the transom, those should be visible on the drawing if they're rounded outwards. At this point, either way could be right.
  4. Congrats on passing the test and becoming licensed, Ben. That's a big step.
  5. Thanks as always for the likes and comments. If I stare at something long enough, I'll usually realize what it is... It's my mistake.... the last beam I have is 2-1/2" long. On the drawing it's 3-1/2" long. I think the drawing is looking from waterway to waterway which, if the beam is tapered or faired into the frames properly it would go past the clamp and end up being 3-1/2" long. Not the end of the world... I may just shim out that area when I do the waterways and plank or I'll redo them. I'm leaning towards a rework. I'm having my moments here wrapping my head around some of this. In my crude sketch... the black beam is how it looks now. The red is how it should have been faired into the frame.]
  6. John, Continue the tic marks forward and aft. You've established that you need 28 planks. Use Chucks fan-tool to get the widths of the planks as you move forward and aft. I'd use the second set with the battens for this. I think in the long run you'll be happier. I would lay out and install the wales and probably the planks above them first to establish where you need to plank between the wales and the keel and then line out the hull. The wales give the ship it's distinctive look.
  7. Thanks for the "likes" and commentary... Making progress. The beams are in for the lower deck. There's probably another couple that I'll need to put in once I figure out the shape at the bow and stern. The bow, not so much, but the stern looks different on the drawing than it does looking into the hull. i think it's not at deck level... just has me scratching my head as I know the beams are all at the right height. Anyway, I'm checking fore and main mast locations and then I'll be dropping a bit of string down the centerline to double check and pin down where I'll need the mizzen mast step, the three hatches, and the bowsprit step. I'm also plotting out the walls and cabins but won't get to far into that until the deck is planked. Which... I'm hoping to get started on this week as soon as I can get the planks cut. The actual next step with the waterways. The wood has been selected (cherry) and the appropriate sized pieces selected. Here's pictures. Feel free to point out any stupidity or errors on my part.
  8. It's great to see you back, Dave. And good luck and wishes for the show. The SoS is coming along beautifully.
  9. If you use balsa for the blocks, hit them heavy with PVA and water mix or even thin CA. It'll toughen the surface up a bit.
  10. It was good to hear from you Kees. I'm sorry things didn't work out at the hospital. Well be here, waiting patiently and hoping for the best for you and your family.
  11. I wonder if the port lids were removable? If we look at the split lids used on many American ships, the up lid was. Also, the French on their frigates late in the 18th century had lids that were only used during foul weather. No hinges on those though. There's precedent but I'm not sure if it applies.
  12. That is a breathtaking display, Siggi. A feast for the eyes.
  13. Beautiful work, Keith. Patrick is right, she is a work of art.
  14. Tough question.... holly, boxwood, pear, silver maple (I've not tried other species of maple) look good depending on the effect you're looking for. As for finishes... Wipe-on-poly, varnish.. there's a bunch. I'm a Wipe-on-Poly guy but other finishes look excellent from what I've seen on MSW.
  15. Carl, Short answer.. no. The gun room was (at least on English ships) where the chief gunner kept his stores (spare tools, locks, flints, parts, etc.) and possibly the Marines kept theirs including extra pistols, long guns, as well as tools. One source maintained that even swords and pikes were stored there. The powder room is even lower near the keel but I'm not able to figure out where exactly nor it's shape.
  16. Adydin, Save the sanding dust from the second planking. Then mix water and white glue together in a 50/50 mix or so it has the consistency of milk. Add sawdust to make a paste (more like a slurry than a paste though) and put it in the gaps. Let it cure and then re-sand. You might have to do this a couple of times. Do it before putting the epoxy on the planks for sealing.
  17. Those of you who do the PE thing on ships have my undying admiration. I get a headache and eyestrain just looking at the pictures.
  18. Between the brass pulleys and the red trim, she's starting to pop right off the screen, Denis.
  19. I'm re-reading this tour-de-force of a build and am still in awe after reading it again . I love the details like the way you made the doors, Alex.
  20. I'm looking forward to your article, Dick. Looking over your build log says you'll do a great job on it.
  21. This maybe an unusual way of framing a hull, Amalio, but the result show that its a good method.
