mtaylor
Moderators
Everything posted by mtaylor
  1. Matt, Measure the bore of the cannon at the fort. That will tell the size... 4 pdr = 3.0" 6 pdr = 3.4 9 pdr = 4" 12 pdr = 4.4" 18 pdr = 5.0" 24 pdr = 5.5" 32 pdr = 6.1"
  2. Keith, Is there a gap? If so, save the sawdust and make a slurry of 50/50 white (not PVA) school glue and water and the sawdust. Pack this into the gap and when it drys, sand. Repeat as necessary. If the gap isn't very big, brush some of that 50/50 mix into the gap and sand while wet. The sawdust will stick to the glue and the gap should disappear. However, repeat as needed.
  3. ]Andy, Let me see if I can help.... See the attached file....(not to scale). I've not built this vessel so there is somewhat of a guess here.... If I look at the other logs, the wales (they stand proud of the planking) seem to be single strips. So I'm assuming this is the first three strakes of planking. What I've done is overdrawn in red the way the wales (planks) should sit, I believe. 1) Don't worry about the step on the outside... that will disappear when you sand. 2) The inside of the plank should sit on the bulkhead with out any space (not always achievable, but we all try anyway). 3) The green arrows show where you need to bevel the planks Not much there. 4) IF a gap opens up when sanding the exterior, save the sawdust, mix sawdust with a 50/50 solution of white glue (not PVA) and water into a slurry. Fill the gap and when dry, continue sanding. Repeat as needed. There's two ways to do this, sand and bevel what's against the bulkhead or sand and bevel the plank such that it sits flush next to the first one (green arrow area). I think it's easier to lay the plank on the bulkhead and bevel the edges to fit the previously laid plank. There's 3 logs you probably should look at... http://modelshipworld.com/index.php/topic/6794-pride-of-baltimore-ii-by-blue-pilot-model-shipways-scale-164/?hl=Baltimore http://modelshipworld.com/index.php/topic/6631-pride-of-baltimore-2-by-phebe-ms-scale-164/?hl=Baltimore http://modelshipworld.com/index.php/topic/1025-pride-of-baltimore-ii-by-jcoby-model-shipways-scale-164/?hl=Baltimore And also this (there's some good tutorials in there): http://modelshipworldforum.com/ship-model-framing-and-planking-articles.php I'm attaching the cross-section from my current build. If you'll notice the inner and outer are roughly parallel but not completely as sanding the exterior changes that shape. The edges where they touch the next plank are not 90 degrees from the inside or outside of the plank. I hope this helps a bit.....
  4. Popeye, You should be pleased. Very nicely done... I love the map! I guess you'll have tell the Admiral to keep pushing you....
  5. I think breaking frames is part of the ritual.... :D Nicely fixed, I must say.
  6. Nice build, Mike. I won't try an SIB with my fat fingers but I admire them anyway.
  7. Beautiful work, Augie. Coming along nicely. Don't you know that when it gets hot, some of us get to stay in the air conditioning...and.... SHOP TIME!!!!!!!!
  8. I'm hoping it's the matchsticks you want and not the fire.... but one never knows. :D
  9. Thanks for the likes and the comments. Gianpiero, You are quite right. I haven't sanded nor shaped the ebony strip and the thick strip above it (in the picture). This will be taken care of next as I want to have the planking at the gunports done and finish applied to protect them on both sides first. Thanks for being another set of eyes... Edit: I've studied it again on the ship. If I can't fix it, I'll rip it off and re-do it but right now, it looks fixable since it's still rough.
  10. Excellent work, Popeye. I guess a little down time just makes the next time in the shop better.
  11. Steven, I wouldn't use paper. If you don't want to use cloth, use silkspan from a hobby shop that deals with the RC guys/gals. It comes in various weights and you'd probably need to acquire small amounts of several sizes to find which one works best for you.
  12. <jaw drops><picks up jaw> Fantastic relief work, Nenad. And all this time, you are telling us you are not an artist.
  13. Interesting furniture... is that BarcaLounger? All kidding aside... nice work.
  14. Lovely work, Sjors. The deck furniture is coming along beautifully.
  15. Looks good Popeye. Can't even tell you re-did things. As for the ladder... Captain's discretion and without documentation, it's a toss up.
  16. I thought the HMS Victory website had a page for modelers including a paint list. Hmm.... I'm not finding it.... And there is this: http://www.model-space.com/gb/paint-set-hms-victory.html I don't know how correct it is.
  17. The ports should all be the same width and height, Jason. The planking is cut back from the port slightly to allow for the lip. The upper and lower edge of the ports generally follow the gundeck sheer while the sides are vertical (perpendicular) to the keel. Do you have a copy of the AOTS Diana? Excellent resource for this class of frigates.
  18. George, Augie, Thanks. George, She's 24 inches long on the main deck from stem to transom. The table she sits on is 3 feet long.
  19. I guess it's about time I did something.... Gunport stripe (for lack of a better nomenclature) has been sanded, re-sanded, ports cut, re-sanded some more, gaps filled and sanded again... I've applied one coat of wipe on poly to the stripe and to the counter to protect it. Anyway... onward to the port side. Once the port side is finished, I'll add the ebony chain wales and the French version of the billboard which runs from the stem, past the first port to the start of the second port. As always, feel free to enlarge the photos by clicking on them. Any advice, etc. is always appreciated.
  20. Have a safe trip, Grant. The black nails/bolts (call them what you want ) look great. I'm stealing your spale idea.... :D
  21. I figured you didn't follow him exactly from what you said, but I'm certain I'll learn something. And yes, it ain't basswood.
  22. Joel, By all means, let us see them. I remember Clay's practicum online many moons ago but have forgot some of the techniques he showed.
