lovely work Rusty,
well built, clean and crisp, a delight to look at...
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Pat and Nils and thanks for all the likes too.
Michael I will leave them natural.
I did apply one coat of wipe on poly to seal them though.
Edited by Rustyj
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Hi all,
I've completed the Bowsprit Guys. The thimbles are made from Albion Alloys thin walled brass tubing, 1.6mm.
The guys are .025" rope served with #100 thread.
As you can tell photography is not my strong suit. Need to work on it more!
Next up is setting the mast and hanging the boom and gaff.
Rusty
Thank you Mike, Chuck and alde and all the likes.
With the pictures I just take them on whatever surface the model may be at.
I don't set up a dedicated area to take them. Maybe someday I will. :)
Rusty
Thank you for the kind words Joe.
Rusty
Thanks Derek!
Rusty
Hi All,
Bit of a catch up here. I've set the mast and have rigged the gaff and boom.
For the parrel I too used left over beads I had on hand. Mine were black though.
IMG_2474.thumb.JPG.494c61ddd2f31be0ed93cdb6f2071493.JPGIMG_2472.thumb.JPG.90fa9863a588efe9a49c3db93971d4e0.JPGIMG_2482.thumb.JPG.0d376793df80d2014e65b972fb6ea376.JPGIMG_2480.thumb.JPG.3e79268d482af8a3ffa046e4ae429e3e.JPGIMG_2479.thumb.JPG.bc9407b6996eade11807496c1ae818a5.JPG
So far so good and still having fun!
Rusty
Thank you alde, Ryland, Pat and Bob for the kind words and all of the "likes" too!
Rusty
Thanks Ben.
It's been awhile since I've rigged something so it's taking a bit of time to get back in the swing of it!
Rusty
Thanks druxey.
I sure hope not. I'm following Chuck's and Mike's order so I should be good. I'll know real soon.
Rusty
I've installed the Burton Pendants. They are served their entire length with a single block seized on the end.
With the shrouds the forward shroud is served its entire length.  The rest of the shrouds only have the portion around the mast head served down to just below the cheeks.  The serving was all done on the Syren  "Serv-o-matic".
The deadeyes were turned in and light brown rope was used for the lanyard. As recommended the lanyards were just tied off so they can be re-tensioned later if needed.
Rusty
Rusty, in looking back at your photos, I just noticed that you had the shrouds wrapped around the the top mast, rather than the head of the lower mast. Sorry, but I don't believe that can be right.
Bob
Thanks Ben,
Hey Bob don't be sorry! That would have been a really big oops to put it mildly.
I look and look at the plans and it never sunk in. I was just getting ready to add the backstay
so your timing was perfect. Thanks!!!!!
Rusty
Unlike away druxey cuz I sure don't like it.
Hey Dubz deconstruction is way to common here!
Rusty
