An extraordinary beautiful work. I also admire the way you use the electrical tools. I have a question if you don't mind. What kind of milling cutter is in the photo and what is its advantage? I apologize if this question has been asked and answered before. Thank you in advance.
Just found this log by a master. As a mere maker of kits with hand tools only, your work is humbling and awe inspiring. After that I am lost for words. Incredible won't even do.
Cheers
Alistair
Current Build -
Thank you guys for compliments. To mtbediz - This is a normal slotting cutter, with only a reduced diameter of the shank to be used in the Proxxon milling machine. (https://www.uni-max.cz/produkty/drevoobrabeni/stopkove-nastroje/drazkovaci-frezy/dvoubrite-kratke/drazkovaci-freza-2br-6-19-8-mm)
I continue with the second - bigger boat. Here I decided to make the frames from one piece only, because in the end the connection of the individual parts of the frames will be hidden under the floor and will not be visible.
On 11/9/2018 at 11:10 AM, marsalv said:
Thank you Albert😉.
I continue with making of stern parts - filling transoms, wing transom, fashion pieces.
I would like to know where you buy the adjustable table that connects between the clamps and the work surface of the mf70, thus allowing milling at a variety of angles Thank you very much for your help
Well done!  Absolutely beautiful model, superb workmanship: you should be proud of this one.
I learned a lot., thank you.
STAY SAFE
current builds:
The case is appropriately austere, so that the model can really shine.  It has been a real pleasure watching this beauty take shape.  I’ve said so before, but one of my favorite features of this model is your particular treatment of the stylized cut-aways; it is unique to you, and really shows the interior to great advantage.  Congratulations on the excellence of your achievement!
What might you have in mind for your next project?
Edited by Hubac's Historian
Very beautifully made, well done,
Kevin
Current projects:
Incredible work! Congratulations on completing a beautiful model! It’s been a pleasure watching this build as well as a great learning experience. What’s next?
JJ
             Portland Scale Ship Co.
Beautiful model.
Robert Chenoweth
In the research department:
Nothing at this time.
Just beautiful and incredible to my eye.  I hope to follow along on your next model.
Congratulations!  She is amazing.
Toni
Member IPMS
                           Utrecht-1742
Congratulations, this is a fantastic ship model. I had a lot of fun following its construction.
Thank you for sharing your tips and tricks. It's a great help.
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • HMS Winchelsea 1764 - Syren Ship Model - 1:48
