HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
Since I may be in a position to apply some paint in the coming weeks, it is important to prepare the other/transparent side of the hull:
This is the cutout for the Diesel Engine room. I applied a coat of primer to better see any mistakes or imperfections. Once all the cutouts are done, I may do the oil canning masking, put the hull together and try to paint the whole enchilada.
Yves
nice job cutting the opening....... :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
On post #240, next to last picture it looks like in the dark compartment on the lower left under the torpedo tube there is a gold fish taking up residence!
VERY impressive work, this model is going to truly be a masterpiece and certainly a one-of-a-kind.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
41 minutes ago, lmagna said:
On post #240, next to last picture it looks like in the dark compartment on the lower left under the torpedo tube there is a gold fish taking up residence!  VERY impressive work, this model is going to truly be a masterpiece and certainly a one-of-a-kind.
Yes, I think the artist used that little fish to indicate that it is a ballast tank....unless it is his signature.
Thank you for the kind words. It helps to tackle such long and arduous project.
Yves
No, thank you for allowing me to live vicariously through your build by providing your frequent pictures and updates. As I have said before I am not much of a Type VII fan, but I continue to thoroughly enjoy following your build in every aspect.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Alright, the tedious and risky business of grinding the clear half-hull is over! Phew...
It takes about one hour to open one cutout, grinding slowly, gently, at low speed to not melt the material. It is still very brittle so utmost care must be used.
I hope these openings will be enough to see the interior compartments. It should work. A few PE parts have been glued and the hull is ready for the primer:
That is a major milestone in the construction of that large model:
I like that approach so much more than the clear (and also very opaque) hull provided by Trumpeter. I understand why they did it, as it is an enormous amount of work to cut these openings. With the Trumpeter solution, you put together the modules, glue then in the main hull and slap the clear hull on top....et voila. You are done. Not for me.... And the magnets used to put together the two halves are a life saver. The original plastic pins are long gone......as you can guess.
A few view for the claustrophobia lovers:
DSC03813.thumb.JPG.b724628a052791f69068bb7895eb04a4.JPGEt voila, the enchilada is ready for the painting. For the paint, I have ordered some acrylic Humbrol paints from Europe. Apparently, they have the colors that get the closest to the German colors of early Type VIIc submersible. We shall see!
I think I am going to take a break of a few hours.... It is well deserved.
Yves
Edited by yvesvidal
I am not too happy with the oil canning done with my airbrush. I suppose I do not have a small enough nozzle to draw very thin lines. It is probably okay with the lower section of the hull, since the color is very close to black/dark blue but for the upper section, something must be done:
As you can see, it is not regular enough and I am concerned that it may show up in an unpleasant way, through the light gray. So, another light coat of primer to hide the mistakes:
and of course, on the other side too:
DSC03817.thumb.JPG.f5648f2da987d83c9d4f53485444bfde.JPGUsing a brush and my hands, I have more precision:
I think it may look a little bit better. Maybe not... I am experimenting and not sure where to go or what to do.
Yves
Edited by yvesvidal
It's going to look just fine, don't over-think it. You can control how much gray goes down and it will allow you to give the look you want.
That's just my opinion of course.
To get finer lines, turn your air pressure down and remove the guard off the tip of your airbrush, so that you can see the tip of the needle and seat. Hold your airbrush very close to the line you're painting, and use one hand to help steady your painting hand (holding the airbrush) as you spray on the lines.
I don't have ready access to a video to show you that technique, but just practice it on paper first. You can get very fine straight lines. What is your needle and tip size? If it's .3 or smaller, you'll be just fine.
While waiting for the Humbrol cans to come from Europe, I have decided to start looking into the second module located right after the front torpedoes room.
That module comprises Petty Officers bunks/Beds, Captain Quarters, Tables for eating, Water Closet, Radio room and Listening Room for the Sonar system. It also included Batteries, ammunition supplies and various tanks:
It is a very packed module with the typical Trumpeter shortcuts and simplifications. Here again, the second set of parts will be most welcome to populate a compartment which is somewhat empty as designed in the kit.
One major problem with the kit is the flat bulkhead between that compartment and the Command/control room. It would take a concave part to remedy that issue, which is not possible in our case.
The upper/central level will be detailed later on. First, I will focus on the lower level of that compartment: Tanks, batteries, Magazine. The following picture summarizes what can be found in that section:
Battery banks #2, the waste water tank #2, the ammunition magazine (for the main gun on the deck and machine gun on the conning tower) and the Fuel Oil inboard tank #2, located inside the pressure hull. We also have a fresh water tank #3. The following are excerpts from "The Manual":
Ammunition.
    Total amount of ammunition that can be carried:
    8.8 cm munitions: 205 rounds HE shell C/35
    MG C/30 munitions: 1500 rounds
    Of these in munitions magazine in officers room between Frames 50 ½ – 53:
            177 rounds 8,8 cm HE shell C/35
            1200 rounds MG C/30
Ready-use ammunition for the S.K. C/35 is stored in pressure-proof canisters [one shell to a canister placed in a rack] in the upper deck just aft of and outside the operating circle to both sides of the conning tower:
            28 rounds 8.8 cm HE shell C/35
    3 ammo clips with 20 rounds each are stored in the conning tower.
    The munitions magazine in officers room is connected to the flooding and drainage installation.
Battery.
The auxiliary and main power supply of the boat consists of two separately arranged storage batteries.  Battery 1 is located under the petty officers room and battery 2 is under the officers room.
  a) Technical and performance data.
Type: 33 MAL 800 W
Cells: 2 x 62
Number of negative plates: 34
Number of positive plates: 33
Cell weight: 493 kg +/- 2%
Total weight of batteries: 61132 kg +/- 2%
Capacity at 20 hour rate 9160 Amp hours
  b) Construction and maintenance.
The cells of every battery are set up in 6 rows on step-shaped iron stands.  Over the cells, there is an extractor duct that moves gases into the main exhaust trunk.  Each cell is connected to the duct by a rubber tube.  The U-tube manometer located outside of the battery room indicates the amount of suction in the extractor duct.
    Between the single plates of each cell are insulators.  The negative plates are equipped with hard rubber feet and stand on the box bottom, while the positive plates hang in the box itself.  Plates of the same polarity are grouped together, both groups form a package.  This is covered with a glass plate for protection against foreign objects.  The plates of each group are connected by terminal strips.
Each strip has 5 terminals, which are passed through the box cover.  Cell connectors (leaded copper rails) are screwed onto the terminals; the lid of the cells is double-walled and has 3 openings:
Extraction opening
Air entrance opening
Operation opening
The air entrance opening is designed in such a way that during a boat’s inclination up to 35° in any direction no acid is spilled from the cell.  The cell case is made of hard rubber and so strongly constructed that the ready-for-operation cell is easily transported using eyelets.  The joint between the box and the lid is filled with a sealing compound.  The sealing compound can be melted by means of a wire inserted into the groove of the joint by connecting the wire ends to the terminals of the cell.
Each cell has a rating plate with data regarding type, manufacturer's number, manufacture date of the positive and negative plates and details regarding repairs and maintenance of the battery.  Operating life of the battery depends on careful maintenance.
Maintenance includes cleaning of the upper surface of the cells.  Foreign bodies or contamination should not drop into the cells through the operation openings.  Particularly dangerous is sea water containing chlorine, which destroys the positive plates.  An external inspection of the battery must be carried out frequently.  All suction pipes are to be regularly inspected to ensure they are working properly.  A defective ventilation system may cause a battery explosion.
An examination of all cells must be performed every 4 weeks in conjunction with recharging.  This includes compensation of acid levels by adding distilled water, the measurement of the acid density, temperature and the voltage of the individual cells.
So that stands, and the pressure hull are not corroded by acid which spills into the battery rooms, the bilge water is to be examined frequently.  Both battery rooms can be rinsed with slaked lime and are connected to the draining system.
  c) Capacity, discharging, final voltage.
    The capacity of a battery is mainly dependent on the discharging current and the cell temperature.  The following capacity values are at a reference temperature of 30° C.
    Type 33 MAL 800 W
Discharge current
Duration
Amp Hours
Final Voltage in V
Amps
Hours
Ah
Cell
1/2 Battery
3630
1-1/2
5450
1.63
101.06
2960
2
5920
1.67
103.50
2200
3
6600
1.71
106.02
1480
5
7400
1.75
108.50
838
10
8380
1.78
110.36
458
20
9160
1.80
111.60
196
50
9800
1.80
111.60
The information listed in the preceding table about the capacity refers to discharging with a certain current, without interruption up to the final voltage.  However, if discharge is stopped before battery exhaustion and is continued again later, the total capacity is greater.  The battery has the ability to recover in the rest state.
  d) Charging.
The Type 33 MAL 800 W charge begins with 1650 A (1st, charging phase) which is reduced gradually to 415 A (3rd, charging phase).  Charging with low current is allowed.  Cell temperature should not exceed 45° C.
In special cases "fast charging” is done by doubling the 1st, charging phase, the charging time is shortened by about 1/3.
2)  Wash water installation.
    Wash water is stored in the following tanks:
            1 wash water tank (listening room)
            1 wash water daily supply tank (aft W.C.)
    Wash water tank and wash water daily supply tank are connected to the fresh water filling and extracting line.  Tanks are filled through the intake at the upper deck.
    The hand fresh water pump is used for filling the wash water daily supply tank from the wash water tank.  A hand wash water pump provided in the forward W.C., to which a suction line can be switched by the selector cock to the wash water tank or to torpedo compensating tank 2.  Extracting the wash water from torpedo compensating tank 1 takes place by means of compressed air.
3)  Fresh water installation.
    Fresh water is stored in 3 tanks (3.870 m³) situated in:
            Fresh water tank 1: Galley, port, under the floor
            Fresh water tank 2: Control room, port
            Fresh water tank 3: Officers room, stb.
    The fresh water tanks are connected to the filling and extracting line through the fresh water selector cock.  The line leads through the hull valve at the upper deck and inside the hull branches off to the emergency drain connection.  The hand fresh water pump in the galley takes suction from selected tank and discharges through the control valve either directly to the tap in wash sink or through the filter.
    The water supplied by the distilling unit in the control room is collected in the distillate tank and is moved through the control valve either directly or through the filter to fresh water tank 1 in the galley.
    All fresh and wash water tanks have sounding pipes and dip sticks.
Finally, a picture showing the internal partitions used to build the Fuel Oil tank from the Battery compartment:
And a picture of the compartment under study (tube to the right):
Yves
Edited by yvesvidal
the viewing ports look very uniform.........looks great!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
As previously mentioned, I am now working on the Officers Quarters, starting with the Battery compartment, underneath.
The Trumpeter approach is somewhat simplistic, once again:
The amounts of batteries does not match what was installed in the original boat. As you may recall, this section includes batteries but also ammunition, waste water tanks and fresh water tanks.
Here is a cutout drawing of the compartment, looking towards the bow:
- To the left is a fuel tank, included inside the pressure hull.
- In the middle, the ammunition magazine and the waste/fresh water tanks.
- To the right, another fuel tank, slightly smaller but still located inside the pressure hull. The Port tank is bigger because they used the space under the officers' beds to increase its size. On the starboard side, there was the radio and sonar rooms.
DSC03823.thumb.JPG.7897311987ac589bc12bf2b28723122a.JPGYou will notice that the bulkheads are also cut to represent the outside saddle tank ballasts. Of course, the Trumpeter kit totally ignores this aspect, even though it is clearly visible from the outside. So, we have to open some cuts, at least on the starboard:
Matching cuts will have to be done on the other bulkhead, in the control room (left on the picture).
I have decided to improve on the Trumpeter implementation and make that compartment a little bit more interesting and descriptive. Therefore, we are starting from this:
And adding the representation of the fuel tanks, on both sides. To allow a peek into the battery room and ammunition magazine, it is necessary to "wave" the starboard tank wall:
It is starting to come together:
and with the waste tanks and fresh water tank as well as the magazine:
I started designing and cutting some parts to close some of the pressure hull and represent the Fuel tank:
But I realized that I had some spare parts and decided instead to use the ceiling of that same compartment to represent my external pressure hull section. After cutting it to size, this is what we have:
It is a lot more prototypical than whatever I could have done and come with the internal ribs of the pressure hull. Once painted, the result is not too bad:
All the batteries (3 rows) in this compartment have been painted. I will need to dry brush them to represent some connections and the sulfate on the connections. The fourth row of batteries will not be represented for the reason that you will see later....(surprise).
Note that I have exhausted almost all the batteries included in the kit. It is a good thing, I have another set for the rear compartment.
Yves
Edited by yvesvidal
Small progress on the battery compartment with a spin....
The batteries on the Type VIIc were connected in series/parallel to obtain up to 110 Volts DC:
Below is a schematic of the Batteries wiring. In this module, we are talking about Battery #2 (Battery #1 is located towards the stern of the boat). The switches are in the large electric frames sitting above the electric motors (see previous module for details).
Depending of the type of accumulators, there could be 5 or 6 parallel connections between the cells, as shown in the following pictures:
The cells provided by Trumpeter are slightly over sized and as such we can only represent 4 rows instead of 6 that were available on the prototype (the fourth row has been omitted to allow a peek into the  compartment. Note that a detailed PE set could have been made to represent the connections bars between the cells. That would have been quite impressive.... to build and to display.
DSC03835.thumb.JPG.7cff1370468250158b08e1d1f8cc129d.JPG These cells required a lot of maintenance (we are in 1939-40) and did not perform as well and as reliably as modern car batteries. A sliding platform was designed to allow a brave sailor to glide over the cells and keep them in good shape, by checking their electrolytes and cleaning any sulfate deposits on the connections:
Let's keep in mind that the voltages could reach 110V DC with a total current capacity of 10,000 Amps. Touching the electrodes and connections was fatal in most cases as DC current burns irremediably. On my module, I tried to represent this interesting (although painful and tedious) aspect of the life aboard:
The fellow uses the rope on his right side to move along the banks of cells. As you can see from the Trumpeter assembly plan, this is a little bit more involved and prototypical. It is always fun to try to improve on an existing kit.
Yves
Edited by yvesvidal
2 hours ago, RGL said:
And there lies madness Yves with that level of detail......
Thank you Guys. It is fun to improve on this kit. Lots of possibilities if you do a little bit of research on the Type VIIc.
I wish there was a PE set for batteries connections. That would have been insane....
I am trying to replicate some more details on the bottom section of that module. More to come....
Yves
you'd need a diagram of the shunts and leads to map out the series.   yes....that would truly be insane :o   awesome job!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Another small piece of details, in that compartment: the ammunition magazine !
The kit is very crude of course and I added another stack of ammunition boxes and a ladder to go inside the magazine:
Not much will be visible once the floor is in place, but the satisfaction to know it is there is enough to justify a couple of minutes spent on that small room.
Access was through the floor and some removable plate. Same for the battery room access done through another plate, in the floor. Apparently, the ammunition magazine could be flooded to prevent explosions in case of fire on board (I still have to find definitive explanations about that one - It would have been a controlled flooding (spray like) and the water would be removed via the bilge pumps).
Yves
Edited by yvesvidal
I have been doing more reading and studying the plans of the Type VIIc and there is no way I can accept the crude implementation of "the Trumpeter" for my model. So, we are going to do some delicate surgery to open the bulkhead and represent the Fuel tanks in the correct way: Basically a "U" shaped tank located under and around the batteries and slightly under the control room.
Tank-1.jpg.f4c10b1662293055b7515b6f75333c07.jpg Tank-2.jpg.f99ab8936a9a50b1673bba178ddc9013.jpg
Below is the bulkhead between the Battery #2 compartment and the Control room (in the process of being cut):
After cleaning the opening:
Similarly the battery compartment is opened to match the contours of the fuel tanks on each side:
and...
I still have to cut the openings for the saddle tanks.
More details will follow. I need to fabricate a round shape to implement the end of the fuel tank. There is a big mistake (not the first, and not the last) in the Trumpeter kit and it has to do with the floor of the control room. The kit provides a flat control room floor, where in fact the main platform was concave with just a flat plate in the middle. It is just impossible (at least for me) to modify the kit and that would prevent the observer to look into the control room and appreciate all the details of that very complex room. So, it will remain flat.....
Yves
Edited by yvesvidal
The insanity continues. I have decided to show some fuel (Diesel) in the tanks:
This is done with Automotive Clearcoat (not pulverized/sprayed) and therefore a lot less toxic. Diesel fuel being transparent, epoxy resin did not fit too well (at least I do not have a clear resin at hand). We will see how it goes and if it finally dries as there is a thick coat in that tank.
Next is the support for the canon, on the deck:
Please someone calls the "White Coats"......
Yves
Edited by yvesvidal
no coat are coming for you Yves........can't prove you lost it yet.   to be certified,  you need to insist that the changes in your behavior is normal........and that everyone else around you are strange.   secondly........your aware of the changes,  and that would indicate that you still have sound mind.
nice try........keep modifying  ;)    nice work by the way!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
We are coming to an end for the lower section of that Officers/sub-officers compartment. I have spent enough time on that little area of the ship, which will be barely visible from the outside. Again, it is just the pleasure to know that it is there, as it should be.
The diesel fuel has been completed (at least for that section):
This is done with three heavy coats of automotive clearcoat. It is actually pretty realistic and depicts the clear diesel fuel sitting at the bottom of a somewhat dirty tank. This fuel will also be present under the next module (control room).
To help the observer and draw his/her attention to that specific location, I have installed two LEDs: one for the battery compartment and one for the ammunition magazine. The magazine will have a fellow sailor, resting one hand on the ladder, while inventorying the ammunition.
From the outside, not much will be visible and you will have to twist your neck and strain your eyes to perceive the essence of that section:
One last picture before we seal the battery compartment for ever....
From left to right, ammunition magazine, wasted water tank (middle), two fresh water tanks and a large Battery bank #2. On each side, fuel tank #2, merging under the control room (module located to the left). The second half of the fuel tank (port side) has not been represented. Enough insanity like that.
Finally, the module in place in the hull:
Next:
- The gun stand
- The officers and radio compartment. Lots of wood simulation for that one.
Yves
Edited by yvesvidal
We are now moving to the top floor of that section of the ship. Let's present the challenges with a few plans:
Offficer-compartment-1.png.9d0a22873e68f0dd092899a365856c6e.png       Offficer-compartment-2.png.dbe2368c62ec6ff3ca6c3f26265ca677.png
From the right (bow) to the left (stern), we have:
- Toilet room with a small lavatory (port side)
- Groceries/Food closet on the other side (starboard)
- Four bunks for the less ranked officers. That included the chief mechanic and Engineers. A table is permanently erected to allow them to write or take their meals. This area is located between Frames 71 and 74.
- Four other bunks for the main officers. Usually there were only three of them in service and thus one of the top bunk was always folded against the wall. On the starboard side, there is a tank with fresh water that will not be represented on this model. Space is between Frames 71 and 68, approximately.
- The captain quarter: only one to have some kind of privacy with a curtain, a small table and a bunk covered with leather (and not fabric like all the other bunks).
- On the starboard side, we have the listening room (hydrophones and early Sonar systems) and then the Radio room.
- On the Port side, there is an electrical closet where all the wires from Battery bank #2 are terminated and switched.
- In the hallway, there are three openings: one to access the ammunition magazine (left side), one opening to access the waste tank and one opening to access the battery bank #2 (center). These are used to replace cells or to allow a technician to perform the maintenance of the batteries on the little sliding tray, suspended to the ceiling.
The doors to the radio and listening room are missing from the Trumpeter kit. The doors that are currently on the U-995 have been installed to prevent the public from tampering with the delicate and precious radio and electronic equipment (left picture). In fact, when looking carefully at the plan and from archive pictures, the doors were likely made of two panes such as below (right picture):
6928403_orig-417x640.jpg.79a7e80c1cfd3959d7b10c4f6291d4b7.jpg    1489838274_detail_uxxi_13(1).jpg.3329f20a2cc95987eb6f2d7573604e96.jpg
The final drawing from U-Historia clearly shows the internal arrangement:
Below is the Trumpeter rendition of the compartment under study:
Lots of work and details in perspective.....
Yves
Edited by yvesvidal
And so it is....
DSC03857.thumb.JPG.2feec91cf9ed1d5dea99d9002b63d30e.JPGThe wood effect is created by first painting all the parts flat white. Then with Burnt Sienna acrylic paint, do a very light dry brush with a flat and wide brush. Go gently first, and then increase as you wish. Finally, a coat or two of ClearKote to varnish the whole.
Personally, I do not want my woods too shiny. I doubt that during the war, they had perfect and highly polished sheets of wood installed on all these submarines.
Beds are done with micro-bubbles plastic sheet (the one provided in the Kit, to protect the sprues) covered with real fabric, neatly folded and glued. The last bed is the Captain's bed and I need to find something that will mimic the leather.
Yves
Working on the Officer's quarters. I am no longer following Trumpeter's guidance, because of the arrangement done underneath. In the official manual, you are not supposed to glue the final bulkhead until the end. My approach is a little bit more complicated and delicate. Nothing near the bulkheads can be installed yet. The main floor will slide into the pressure hull from behind:
And the toilet facility:
Yes, real paper....
Yves
