Hi Augie,
Just got caught up and you are doing a great job. Just wonderful. I too am eagerly awaiting
your planking but I am also very sympathetic too! Don’t fret it though. It may be a large task
but your methodical approach and attention to detail will serve you well!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Just getting a few minutes to get caught up Augie, I see planking in the near future....looking nice....lot's of work in the framing.
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Not exactly record breaking progress this weekend.  But Chapter 4 has been completed.
There are a series of sheaves, 3 per side, that pass through the hull.  Confed has simulated sheaves that add some nice detail.
Additional framing was installed to serve as a backing for the sheaves both inside and outside the hull.  Then the laser cut 'shells' were fitted with small slivers of wood to simulate the sheave itself.  These assemblies were glued on to the framing and #68 holes drilled through the hull.  The inner sheave assemblies will not be placed until later after the inside bulwarks are faired.  The sheave shells or housings are 1/16" thick and will match the eventual hull planking.
The first photo shows the assembled sheave glued to the new framing.... the through hull holes are drilled:
In the next photo, I've laid a plank on top so you can see the effect we'll achieve once the planking is in place:
As I've often said, the smaller things get, the longer they take :D  :D .  Overall, I'm pleased with this detail.
The next task will be to plank above the wales.  But, in order to delay that as long as possible, I plan to play with some paint first to see where I'm going on the bulwarks colorwise.  Plus, since it's been almost 2 years since I've planked a hull, I need to psyche up and try to recall how I did it the last time (haven't a clue).
In the meanwhile, I wish my English and European friends all the best of luck in weathering the current storm.  Batten the hatches and stay dry!
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Them thar sheaves look very realistic, Augie.  Nice work on them - and look forward to the next teenise fiddly bit!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
And these small details add up in the end! Looking good Augie!
hamilton
Augie - a lot of folks think I made little video snippets and detailed photos to document for others how I proceeded on my build (which is the case) but truth be told I also did it so I could later remember how I did a step or two (make a rope coil, make a hook, strop a block, etc, etc, and of course, etc.....). I've had to scratch my head a few times already. :)
Nice, Augie.  Now write yourself a note and pin it to your work board - "Don't forget to add the inner sheave assemblies when inner bulwarks faired!" :)
John
Very nice Augie. I certainly know the feeling of "Now how did I do that last time? No, not that last time, the last time that actually worked!"
John
Thanks everyone.  I also need to credit Mobbsie who actually came up with his own version of the (almost) functional sheave on his Aggy.
JOHN-  I'm sorry but I can't resist.  I'm up to page 33 in Chuck's practicum at this point.  But if you flip to about page 94, you'll find a handwritten notation:
'Inner sheaves are in magnetic ashtray ---- put them in NOW!
Augie
Previous Builds :
as others have mentioned.......any progress is good progress  :)   looking forward for the first planks  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Ahoy Augie :D
Two years, Wow. I find your progress on this kit and this new level of craftsmanship of yours very inspiring.
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Hi Augie,  You’re moving along nicely. The planking of most of the hull is straight forward.
Just remember to pre bend the planks at the bow and stern like Chuck describes and you
won’t have any problems. Might take a looooong time but no problems. ;)
Adrieke, The practicum it around 170 pages.
Rusty
What a pleasure to follow! This will be my first build. Just waiting on the mail! Will be watching closely ;)!
Passion is Patience...and I am a carpenter in any scale.
Current build;  Endurance - 1:70 scale, Occre
Current build;    H.M.S. Surprise - 1796, 1:48 A L
Excellent framing job, Augie! . . .  as expected from you  :)
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Just caught up with your progress Augie, what a great job you are doing with her, and what a fine kit Confederacy is. I love the separate framing of the transom, and gun ports, I am very much drawn to Chuck's kit.
B.E.
It is an excellent kit. I can't wait to start my own. I think it's a worth while follow up to anyone who's built a Fly/Pegasus or Syren kit... or any other kit, for that matter...
After seeing what you've done to your Pegasus.. I'd be amazed to see what you could to with a Confederacy..
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Blue Ensign -  I appreciate you stopping by and your kind comments.  Your efforts on Pegasus make me shake my head in awe of your talent.  I would love to see what you could do with this kit.  As you can see, Andy agrees!  I can envision 2 more Confederacy logs, fully rigged versions, gracing the pages of MSW a year down the road :)
Bill -  You've picked a challenging, but spectacular kit for your first build.  Chuck's plans and instructions are first rate all around.  My first was his Syren.  Those plans and instructions, as well as input from many here on MSW, got a complete hacker through it and resulted in a creditable job.  You will not be disappointed.  I look forward to your log.
Augie
Previous Builds :
Augie the framing looks awesome, but then again what else would I have expected - it isn't me building it :D .
I actually totally get your love of blueprints etc,  I always love looking at the structure, the nuts and bolts etc and while planking looks great from a full ship point of view,  it always seems a shame to cover up all that work! That happened with me and the willie, put all that into the frame and loved it - decked it now :angry: .
But, tis the price we pay for building such wonderful ships.   They wouldn't exactly float very well if I left them where i wanted to :o
Anyway, wonderful job and am sure it will look fantastic with the planks - but that is gonna be a lot of planks!!!
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
A little diversion prior to activating the sawmill for planking.
I developed a red color for the bulwarks using acrylic paints and some voodoo incantations.  I like the color and it's dead flat.  Here, 7 coats have been applied:
A sufficient quantity has been prepared to serve the whole build.
I always hate these photos as it appears that mankind has not yet invented masking tape :D  :D
Planking will begin shortly starting with the counter at the stern.
I wish everyone a great weekend.  And for those in the USA, don't forget to turn your clocks back Saturday night so we can be back in synch with the rest of the world !!
Edited by Augie
Augie
Previous Builds :
The rumours that I created this color in celebration of Halloween are grossly exaggerated.  Actually, it's quite a bit redder than it appears in the photo.  It is a combination of Model Shipways bulwark red and black under a coat of Model Master flat clear lacquer.
Augie
Previous Builds :
