No major milestones but time for an update.
Planking continues.  The mishap with the flying paint jar on the port side was eradicated by removing most of the planking on that side, including 2 of the simulated sheaves, and starting over:
The starboard side is at the same point.  All of the sweep port openings and gun deck gun ports are completed:
I'll be working my way up to the forecastle and QD with the planking.  Then a good sanding before I add the second layer of planking to the main and channel wales.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Good pics Augie, she looks crisp and clean....I know from reading ahead on the Syren the gunport thing is much more complicated than what I am used to. Expect lots of questions when I get there!
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
Looks like a success Augie.  How did you remove the planking or get the glue to desolve without damage?
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
super update Augie.....the planking looks great.  you recovered quite nicely ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Augie, Yes practice does make one better doesn’t it! Sorry you had to do the
“do over” but it came out so very nice. Well done. :)
Rusty
"So Long For Now" B)
Current Builds: Speedwell
That latest update shows very clearly your skill and craftsmanship Augie! She is looking just fantastic. And others have said, practice obviously makes perfect ;)
Well played Sir!
Gee, maybe I should rip it off and do it still again!!!!  No, I'm tired of notches.  I know Wes mentioned in a recent update (on his beautiful hatches for his Connie) that he had cut some slivers down to 1mm.  I got a couple at 0.8 :D  :D
John-  I'm a thick CA guy when it comes to planking.  Easy to handle, neat and doesn't penetrate right through the wood (in this case, basswood).  Holds like iron after 30 seconds so there's no fooling with clamps.  One or two copious applications of acetone will soften it enough to remove a plank.  Then a sharp exacto blade, a little sanding, brute force and superstition and you're back to square one.  Oh, make sure to extinguish the 'smoking lamp'.
Thanks for all the well-wishes.  Hoping to get back to a normal pace now.  Frankly, November was a month I'd just as soon forget.
Augie
Previous Builds :
Augie,
Have you ever tried hot melt for planking? I know that sounds goofy but it is what I used for my Victory bow section. They were shorter planks for the most part but if one can stand the heat(the glue does burn fingers for a sec.) it certainly holds .....
Thick CA is also in my array of adhesives.
Your humble acolyte,
Jim
Completed      Robert E Lee, Misisssippi riverboat
Completed,  HMS Victory Bow Section
Completed,  Wells Fargo Stagecoach...Picasa album....
Completed,  Lackawanna tugboat converted to private yacht...
Completed:  Sopwith Camel, 1:16 Scale, Model Airways...at another location...
Completed:  1961 Ferrari F-1 Sharknose
Completed: (sorta)  OcCre BR-18 Locomotive
Completed: 1/35 Pz.KPfw.III
Completed: Allerton Steam Pumper circa 1869
She looks awesome Augie. I may have to switch from PVA to CA for planking based how well you like using it.
Take care and let's put this month behind us.
Regards,
Larry
Current Build
US Brig Niagara
Completed Builds
George W Washburn - 1890 Tugboat
Future Builds
18th Century Longboat by MS
HM Cutter Cheerful
Wappen Von Hamburg by Corel
If your not making mistakes, your not challenging yourself – my life has been full of challenges :)
very nice recovery Augie :)
i tend to use too much glue and PVA wipes of easy, but it would certainly cut down on the waiting game with the thick CA :)
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
I only mentioned the thick CA because John asked.  Like anything else, be VERY sure to try it first before you commit to using it on your pride and joy.  And remember you need to have your subject plank pre-bent and spiled (if necessary) so that it is really ready to go.  There is zero time available for playing around.
One last thing (and here I risk an avalanche of 'heresy' comments), I really believe the thick is less volatile and emits less fumes so it might be less irritating for those sensitive to CA vapors.
Augie
Previous Builds :
Thanks for the advice on the thick CA Augie. I generally avoid using CA at all if I can, as I'm one of those affected by the fumes. I might try giving the thick stuff a go to see if it makes a difference (fume-wise).
Well done, Augie.  And good advice on pre-bending the planks.   Ok.. Novemeber is like over in 30 some hours so you only have to hold out for a bit longer.  December will be better.
Very nice Augie. I always learn something from your post ;)!
Bill
Passion is Patience...and I am a carpenter in any scale.
Current build;  Endurance - 1:70 scale, Occre
Current build;    H.M.S. Surprise - 1796, 1:48 A L
Hmmm thick set CA.....I know I am hyper sensitive to the stuff and try to avoid it all costs because I know I will be down for 2-3 days after the first whiff of fumes. I did break down and purchase a painter's respirator mask with filters for chemicals....I am guessing that the reason behind the CA is you can move rather quickly on the planking?
I am not sure I am confident enough in my planking abilities to give that a try....yet :P
Robbyn
Current builds
AL San Francisco II
Completed Builds
In the closet
Battle Station
PVA is a lot easier to work with Robbyn.  And more forgiving.  I'm just used to using the CA's from my airplane work.
Augie
Previous Builds :
Augie,
The planking is looking really good.   One thing to watch is when you are ready to place the second layer of the wales (both of them) on top of the first layer.  If your planking run isnt identical at the stern where the planks run off the hull,  dont just follow that first layer with the wales.  Make some adjustments on one side or the other so the wales are even port to starboard.  Should they not be even it will cause you some problems when trying to get the quarter galleries built and the PE decorations on.   The same is true at the bow when it comes time to make the headrails much later.
Try and measure down from the cap rail on both sides after taking the measurements from the plans.  You have a bit of wiggle room there if you need to adjust them to make them even.  Just giving you something else to worry about!!!! and I hope you find it helpful.
Chuck
Thanks for the advice, Chuck.  Always appreciated.  Took me a second to understand it but thinking of a stern-on or head-on view makes it clear.
Augie
Previous Builds :
Thanks Augie, I appreciate the explanation, always learning.....didn't know how to disolve CA.......
John
Hi Augie:
Great work - the sheaves look particularly good.
hamilton
Thanks, Hamilton.  Planking up there is almost done now and they look even better.  I can't take credit for the idea...that was Chucks.  But Mobbsie did something similar on his Aggie and it's really a nice touch.
Should have an update in a day or 3.
Augie
Previous Builds :
