If I told you that I have had an indigestion of frames, would you believe me?
Seriously, I just finished building 84 frames with just 4 more to go on the stern. The rear frames were by far the most difficult to remove from the plates, sand, adjust on the keel, fair and verify. Here are most of the tools I used to build these 84 frames:
The Dremel...? Indispensable. Oh and some sand paper to finish before oiling and waxing the wood.
Below is Number #74 to #79:
Then, #80 to #84+
Dry fitting:
Of course, not all frames are perfect. I do have some misalignments and I am hoping that once some planking is in place (inside and outside), things may recover nicely. Also,  there are four gun ports that I did not build yet and I will address these once the deck beams are in place and the hull a little bit sturdier.
Now is time to glue it all and "Commit" !!!
Yves
that all looks very nice and tidy
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
All the frames have been glued and the keelson finalized:
That cradle is quite practical, and it allows me to store the ship away from my bench, quite easily:
It is a large model but nothing comparable to the humongous size of the HMS Bellona.
Happy Holidays to all.
Yves
That really does look excellent, and your work is so clean.
Ongoing:
Thank you James. Coming from you, it means a lot.
Yves
Edited by yvesvidal
Moving on with tedious and extremely delicate tasks. I decided to tree nail the wood pieces. It helps bonding with the frames, as the holes go inside the frame. Not sure I will do that everywhere inside the hull, as it will be barely visible.
There is no way to hold the planks internally and you have to maintain them with your fingers, while the glue dries. Not exactly practical.
The tree nailing is very subtle, which I prefer a lot.
Yves
I am starting to blend Session #1 and Session #2. Like most CAF Model kits, this ship comes in two sessions.
The first session is all about the cradle, the hull and frames, including the stern.
Session #2 is everything else.
I did not complete the stern as it would impede easy access into the hull, for installing, nailing and sanding the inner planking. I will return to the stern (end of Session #1) at a later date.
For now, I am trying to do the following:
As indicated before, it is very difficult as there is no room for clamps, since the hull is stuck in its cradle and cannot be removed, yet. The long timber pieces have to be formed by hand, soaking them in alcohol and them bending them by hand, until they have reached the approximate desired shape. Gluing is then done in sections, using CA glue, and maintained with your fingers while drying.
Below, you can see how the open stern helps with the internal access.
The tree nailing is done as much as possible like on a real ship. The holes are actually crossing all the way into the frames, and the toothpicks soaked with glue are actually connecting the parts. It adds a little bit of bonding into some areas which are not possible to glue easily.
Yves
Edited by yvesvidal
Greg,
So far the parts are holding very well. Oiling and Waxing (combined in one product) are done mostly after gluing. However, some parts are oiled/waxed before gluing and to be on the safe side, I wait a day or two for the wood to suck all the chemicals before gluing. It seems to work fine and it is pretty strong. Thank you for the compliment.
Yves
Working on the bases of the masts. First the main mast. If someone could explain to me what are these small yellow dots on the mast shims, I would appreciate it. The shims have not been sanded and I will finalize the base, when building the main mast.
The base is not glued yet:
Yves
Edited by yvesvidal
Feel like I just took a short nap since last I checked in on your log, Yves - and now look! This is another huge one from CAF....looking really great so far!
hamilton
I just finished installing the third (and last) set of inside planks. Even though the kit calls for 5 sets, I am limiting myself at that point as these are extremely difficult to set correctly, since you have to hold the planks with your fingers while the glue does its job. There is absolutely no room to fix the planks, with perhaps the exception of drilling a small hole and placing a few microscopic wood screws.
Again, all planks were tree nailed, with the tip of the nails protruding into the frames.
The next part of the assembly is very complex, poorly documented by CAF and very tricky. It will drive the rest of the assembly and I hope to not screw up royally on this one.
Yves
As indicated by the picture below (Session #2), I have installed three sets of the 2x5 planks. I am stopping there.
Now, the dreaded prospect of gluing the 3x5 mm planks is coming. There are really no clear indication on how to do that, besides a little tick mark on the frames, that comes somewhat in the middle of the deck beams. It is really not precise at all. In addition, securing the deck beams supports (3x5mm - Green) is not an easy task, because of the lack of access due to the constraining cradle.
Instead, I decided to move on and install the deck beams central support as well as possible, making sure that it lines up with the deck beams and from there, determine where the 3x5mm supports have to be installed. It is going to be tedious but that is the only way I see it possible.
Once this assembly is in place, I hope by positioning a few deck beams, to be able to trace the exact position of the 3x5 supports, on the frames. That central assembly (3F-1 to 3F-15) is super fragile and requires a lot of care.
It is first assembled flat on a bench:
Then, many dry-runs are made to position it in the best possible way. One of the vertical holders is ending right in the middle of the mast base, which is not good. I will adjust this later. The mast base is not glued yet and will be glued later, when some of the major deck beams have been installed. There is a lot of conflicting information between the Monograph, one of the CAF plans and the other CAF plan (!) Not easy to figure out exactly where the main mast should sit.
Finally, the central support is installed and the CA is drying....
Wish me luck.... I really have no idea if that is going to work.
Yves
While working and measuring multiple times for the installation of the deck frames supports (3x5 mm), I have built the ladders used by the crew to reach the lower level:
These parts are funny to build, with a small triangular file. The crew must have been very agile to use this kind of ladder, that literally requires your two hands and two feet to get to the upper deck.
Yves
Edited by yvesvidal
Absolutely fantastic work on your chebec, Yves. It looks as if you were building the real thing. I also really like your neat photography and thorough description, which taught me one thing, I´m not up to such a kit right now and I had my eye on La Coureur for a while, but when I feel I am, I will seek out your log as a helpful source.
Cheers Rob
Yves
They were called “ Monkey Ladders” for a reason.
A quick update and a major milestone completed for me: the building of the deck frames supports in the hull.
The central support has been installed:
To position correctly the 3x5mm deck frames support on each side of the hull, I am approaching it in two ways:
1) An approximate marking using multiple deck frames. It gives me some kind of indications.
2) Using the plan, a precise measurement from the base of the cradle:
It is the line marked "4". I am using a measure every ten frames. When happy, it is time to glue, using CA glue and strong fingers pressure, since there is no easy way to position these 3 x 5 supports.
Once glued, I am drilling through the beam and into each frame. A real nail (pin of electronic components - 0.8 mm diameter) is inserted after coating the "nail" with CA glue. Then some sanding, oiling and waxing.
The nails are useful in places where the frames are not touching very well the beam, due to the poor fairing of the internal hull.
This is mostly the case in the stern (see above).
Both sides are now done...sighs. I hope it will be alright. There is no coming back.
Next, I am going back to the Session #1 and will try to finish the stern:
Overall, I am very happy to have this milestone behind me. It was not the most pleasant thing to do.
Yves
Edited by yvesvidal
I was planning to finish the stern (and the Session #1 by the same token), but it is not possible (or practical) because of the cradle.
At this stage, I have no other choice than starting the installation of the deck beams. I know it is hard, but someone has to do it... 🙂
I decided to install the central beams as they are the pivot of the whole deck and it will allow me to position correctly the mast base.
Lots of beams to install (about 58) plus the platforms for the bow and stern. That should be interesting. Once this is done, it may be possible to extract the assembly out of the cradle. We will see.
Yves
Nice progress on this model, you are doing great work. Were you planning to have an interior, if the kit even provides one?? The plans by Frollich I think had some interior, although items like galley are placed on main deck with that design of ship. Also, I couldn't tell from the photos provided but is the central support beam the same width as the keel? If so, that should have made lining up a lot simpler or so would seem.
Brian D :)
You address the challenges of this build well, Yves! This is a great tutorial for anyone building this model in the future!
hamilton
Brian D :)
Brian,
No interior is planned in the kit. Besides, the entire deck is planked, so it will be impossible to see anything inside, even with no hull planking.
The central support beam is 3 mm thick and the keel is 8 mm wide. Lining up was not so much of an issue. What is delicate is lining up the little slots for the deck beams with their corresponding hull frames. The Plan provided by CAF Model regarding that specific alignment, is slightly different than the Monograph. I am following the CAF instructions, as you may easily guess.
Thank you for the compliments.
Yves
Brian,
Regarding your question about the interior of the hull, I have been pondering whether I should show some of the deck beams open (not planked), since the hull will not be planked to display the numerous frames. However, I tend to go with a full planking of the deck as there are a lot of things to install and display on the deck. Leaving a section of the deck un-planked, would restrict the amount of stuff that can be installed on it. In addition, the model is fully rigged and as such there are all kinds of anchoring devices and pulleys that need to be installed on the deck for the standing and running rigging.
Yves
Absolutely yes I would. I really dislike repetitive tasks, though we must often push through them in our hobby.
I am moving along with the installation of the deck beams and the main mast base.
On the picture (above), you can see that the central support has been carefully cut to allow the main mast to be installed. Before cutting, I installed on each side a few more beams to secure the central support. I did not want it to collapse or buckle in any ways.
The main mast fits just right. It is 15 mm in diameter and will probably be slightly reduced when sanded to shape.
After carefully eyeballing the mast to be perpendicular, the mast base can be positioned and glued (See above).
Gluing more deck beams, after sanding slightly the waxed wood and using exclusively CA glue.
A vertical support piece has been added next to the base, according to the Kit plan and Monograph (above).
I know, it is a lot of beams....
Next, I will be doing the same with the front mast. Stay tuned.
Yves
Implementation of the forward mast base and deck beams. Not really easy and requiring a lot of fine adjustments to position it correctly.
I glued the deck beam #3to come as close as possible, before cutting the central support beam. After cutting (below):
I would strongly recommend not installing any more deck beams, as you need the access with your fingers to position the base. The installation of the base must be done after filing the base of the front mast, for a correct and still tight fit:
The base is now glued strongly as much as possible:
According to the Monograph, the front mast is leaning by 20 degrees from the vertical (70 from horizontal). CAF Model does not provide much instructions on this subject.
Pretty close to the 20 degrees. Below, both masts installed:
Next is the big puzzle of the bow deck beams:
Here, a lot of fine adjustments are necessary. I do one side at a time:
Then the other side and the front plate, still checking with the mast and its inclination:
All these beams will be covered by the deck planking. Note that the middle cross-over beam was not fitting in the original position. I re-positioned it a little bit behind.
And a final verification with the mast:
Now, we can proceed with installing all the remaining deck beams in the bow.
Yves
