Like robnbill I also have a woodworking shop. A Sawstop is next on my list. It is an exceptionally well made saw and cost about the same as a comparable cabinet saw. Contrary to popular belief, the saw does not have to be rebuilt if the cartridge is activated. One other point to remember is to avoid ripping short pieces. I do my jointing, planing, and ripping before crosscutting to length. As several other members said...trust your gut. If you feel uneasy about a proceedure, find an alternative method.
Dave
I don't know why anyone invented it, but I used a push stick that I inherited from my father that was Aluminum - plastic grip - inch scale engraving.  It came in contact with the blade and removed a carbide tooth.  What was a smooth running expensive Freud rip blade was then out of balance.  I had the tooth repaired, but I suggest using Fir or Pine from a scrap 2 x 4 or furring strip to make a push stick. Use one for each hand.
Ripping (resawing) is best done with a band saw.  You can use short pieces of wood, no kickback and the kerf is significantly less.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
For my little table saw, I use a couple of largish chopsticks.  They're dirt cheap, sacrificial, and being bamboo, pretty tough.   For the big saw, it's couple sticks of fir I picked up at Lowe's in the so-called "scrap bin".  Got them for I think 25 cents apiece.
There is also a very nice tool called the MicroJig. It allows the control of both sides of the cut wood all the way through while keeping your hand away from the blade.
Bill
Chantilly, VA
Its not the size of the ship, but the bore of the cannon!
Current Build: Scratch Build Brig Eagle
Completed Build Log: USS Constitution - Mamoli
Completed Build Gallery: USS Constitution - Mamoli
Funny you should mention that Bill.  Tonight I used the Microjig Grr-Ripper for the first time with my Byrnes saw and absolutely loved it.  I am surprised more people on here aren't using it.  It is fantastic - easy to use, keeps your hand away from the blade, and you no longer need to deal with featherboards, etc.  Well worth the money in my opinion.
I used it to saw 0.5mm maple sheets for deck planking.  I was having trouble cutting straight planks due to the fact that the wood was thin as paper and would slip under the fence at times, or even ride up over the blade.  The Micro jig worked like a charm and made cutting straight planks a breeze - and with 100% safety.  I wholeheartedly recommend it.
Here is a picture of it in case people are interested.
Edited by Landlubber Mike
Are there work gloves that would protect my hands from potential table saw damage?
In the past, I have used protective gloves when sculpting with knives and chisels but I am not sure they would offer much protection on a table saw. I understand about using push sticks etc. but I wanted to check and see if anyone knew of more effective protection that would allow me to work without hindrance.
My wife is buying me a mini table saw for my birthday and asked me to check.
Richard,
A piece of safety equipment that I haven't seen mentioned is "hearing protection"; Table saws and similar machines are very noisy and can damage your hearing over time. Safety glasses whether they are goggles, side shields or prescription safety glasses are also very important.
Current project: Retired
www.howefamily.com
Safety Glasses is a big item that shouldn't be overlooked, but it seems most of us do. I been lucky over the years but no one is ever going to be lucky all the time, without your eyes you can't build.
Wacko
Joe :D
Go MSW :) :)
I couldn't agree more. A friend of mine had a near miss using his accu drill.
This, and the fact that it bothered me to always had to make two or three steps to grab my goggles when working with another tool were the driving factors for me to do a relatively cheap but very effective upgrade: every stationary powertool has now "its own" goggles, strategically placed in a way that I can't use the tool without moving the goggles "out of the way - onto my nose".
I got used to this system very quickly and shed live is now much easier (and a fair bit safer). When using an electric hand drill or a hand powered handdrill with very thin drill bits I reach for the goggles of the next powertool and put them back to their place when done.
Edited by nobotch
- Markus
Mike,
    The Micro-Jig looks interesting but appears it is not useful for anything under 1/8" wide cut.
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
I used it to saw 0.5mm maple sheets for deck planking. I was having trouble cutting straight planks due to the fact that the wood was thin as paper and would slip under the fence at times, or even ride up over the wheel. The Micro jig worked like a charm and made cutting straight planks a breeze - and with 100% safety. I wholeheartedly recommend it
Thanks for showing us this Mike. I've just ordered one! :) Edited by gjdale
Mike,
I guess for me, 1/8" or more picks up a lot of wood cuts.  If you wanted something smaller, I suppose you could always run the cut off the side of the blade opposite the fence?
Let us know what you think Grant.  I'm very much a novice at table saws, so I'm sure folks with more experience might be comfortable with featherboards, push sticks, etc.  I just had a hard time getting that to work, so tried this thing out and it's made a world of difference for me.
I should add I have no connection with this company.  Just a very happy customer.
The largest difference this jig has over push sticks and feather boards is the ability to control both sides of the wood through the entire path of the cut. This ensures there is no kickback since the wood does not veer side to side during the cut. It does not allow for cuts smaller than 1/8th but as Mike said, that does leave lots of cuts it does work for. The interior of the jig is movable so it can be adjusted for the various size cuts.
It still can be used to cut smaller thicknesses if you have the cutoff to the left of the blade. The jig would just not straddle the blade and only be used on the part to the right. This still leave you more in control than just pushing the wood through from the end.
I know others have used feather boards for this, but there is a guide for ripping thin sections for the table saw. It rides in the miter slot to the left of the blade. It has a wheel in the end to allow the wood to easily slip past. You set the width of the cut you want ( to the left of the blade) then slid the wood between the fence and the wheel. Make the cut and shift the fence to the left until the wood contacts the wheel again and make the second cut, snd so on.  This allows for consistent thickness cuts to the left of the blade.
Anyway, both of these jigs/guides make my life easier and a bit safer. As Mike said, I don't have any interest in these companies other than I use their products. If you are interested both of these are available for a number of different sources on line.
Edited by robnbill
Bill
Chantilly, VA
Having watched the demo videos (of the Microjig Grr-Ripper), my opinion is that this will get a lot of use in my workshop.  True, for widths smaller than 1/8" a different method will be needed, but there's still an awful lot of cutting to do at wider widths.  The fact that it can be used equally on the Byrnes saw or a full sized table saw (not to mention band saw, router table, etc) is a huge bonus.  I think this will be money well-invested, and being a safety item, there was no problem in gaining funds approval from the Admiral ;)
Edited by gjdale
Come to think of it, I don't do MANY cuts under 1/8".  I look forward to hearing more.
Chuck Seiler
Bill,
I like the idea of the Thin Rip Jig but am using the Byrnes saw which has 1/2" wide by 1/8" deep slots. Based on your jig, is the slide easily changeable?
Richard
Richard
Member: The Nautical Research Guild
I have seen the results of accidents caused by inattentiveness caused by repetitive operations. That is when making multiple pieces. After 8-9 cuts ones motion tends to get a little automatic and thats when carelessness gets involved. BILL
Bill, in Idaho
Completed Mamoli Halifax and Billings Viking ship in 2015
Next  Model Shipways Syren
I use a shop made jig/fixture to cut repeated widths of thin stock.  The clamp is an old Xacto clamp that has been narrowed to fit into the slot of the Byrnes saw.  A mill is not needed - I used the carbide blade on the Byrnes saw to make the rabbet a close fit to the saw's miter groove.  The wooden jig piece needs to have the ends thicker then the center area to fit to the clamp.  I will be remaking the wooden piece from Plexiglas as this was just a test jig to get a job done.  Now that I know it works for me the upgrade to Plexiglas will follow.  The fixture is moved back, closer to the operator, when making cuts.
Kurt
Edited by kurtvd19
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Bill,
Richard
That might be a bit of a challenge since it uses a double acting bolt. When you tighten the knurled knob on the top of the jig it swells the fitting riding in the miter effectively locking the jig in both directions. It could be replaced but it would require some ingenuity.
Bill
Chantilly, VA
For UK readers,
The thin rip guide featured in this thread is available in the UK from Axminster Tools who list it as the Axminster thin rip guide! It sells for £21.96
Mike.
Previous Build: LA gun deck cross section.
Previous Build: Lancia Armata. Panart 1:16
Previous Build: HMS Pickle. Jotika Build.
HMS Triton cross section 1:32.
Shelved awaiting improved skills:
Chuck"s Cheerful.
Current build.
Tender Avos.
HM cutter Alert.
  • 7 months later...
I've found after many years dealing with slow witted apprentices that K.I.S.S(keep it simple, stupid) works best.
So I just used to tell them "keep the soft fleshy bits away from the hard sharp bits. Works for any tool especially the thick ones...
Ongoing builds,
SCutty Sark Revell 1/350 (Mini Nannie)
Cutty Sark Airfix 1/130 (Big Sis)
Will (Everard) Billings 1/65 but with wooden bottom, because I can
Hi All,
I read through this entire topic and I don't have much to add, except one of the first posts in the topic said to stick with hand tools if your frightened. While that's probably sage advice, after 40+ years around power tools, I have to admit, that after some of the things I've seen, I'm ALWAYS a bit afraid around table saws (large and small), band saws, lathes, and routers. I think a little bit of fear keeps me on edge and very focused on what I'm doing. Anyway, it works for me.
Best,
John
Edited by Landlocked123
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
  I call that respect for the danger and power they have and the damage they can do if you are not paying attention.
David B
Edited by dgbot
See enough blood and it becomes hard to forget.
John
Member:
Model Ship World
That is the reason I upgraded my table saw to a SawStop. I hope never to test it, but I think it still provides more margin of safety than any other saw out there.
Bill
Chantilly, VA
Used all different types and sizes of power tools all my life, and knock on wood, only got wounded from one once. A nail-gun double-tapped on me while I was on a ladder and reaching up to nail an up-right 2 x 4 to the top header of a wall. Run the nail into the side of my finger just missing the bone. Never had a problem with any other tool. You just have to maintain the appropriate amount of respect and caution when using them. H--l, a car will kill you if you don't use your head, just like anything else.
GEORGE
A while back, I saw those youtubes you mentioned. It is really an amazing technology! Does it add a lot to the cost of the machine? I would think that if it does, after a while it would even out as lawsuits against manufactures who don't provide it would add up. I can picture a lawyer in court asking a saw manufacturer "why is it sir you did not incorporate this safety feature in your product?"
Best,
John
Member:
Model Ship World
The cost is comparable to other saws of it's type. It is a damn good table saw on it's own. I really have enjoyed using it. Having a good, well tuned table saw and a sharp blade makes a world of difference.
Bill
Chantilly, VA
There isn't a tool manufacturer out there that can build a "fool-proof" tool. It's a "buyer use at your own risk" type of thing if you hurt yourself. Provided, of course, the tool doesn't fly apart and works as it was designed to.
GEORGE
