Licorne 1755 by mtaylor - 3/16" scale - French Frigate - from Hahn plans - Version 2.0 - TERMINATED
Thanks for the likes and comments.
At this point, I'm happy I have a stash of wood.  :)  I have the top transom shaped on one plane, a notch milled in to fit over the top of the deadwood and high hopes.  As I tell my Admiral, high hopes and low expectations will keep you sane.  :D   I'm going to try bending it but we'll see.  I may toss it and cut and shape the whole thing on the scroll saw and bench sander.
Link to comment
Share on other sites
Hi Mark, won't bending it change the shape of the notch?  Perhaps that is recoverable though as if it is in the centre there should not be much bend there?
cheers
Pat
Edited by BANYAN
Link to comment
Bend it ... Did(/could) the old masters bend such a piece? Maybe better to find a nice piece of wood with a stunning flowing grain, like a 'trained' tree ...?
Carl
Link to comment
I now an old fashion way and I don't know if it is works for you.....
Bend it on your knee...... :P
But watch out, otherwise you broke your knee !
Sjors
Link to comment
I sense a redo coming up - don't even try to bend it, cut a new one from thicker timber and shape it in both planes. Much easier.
:cheers:  Danny
Cheers, Danny
Link to comment
Wood is patiente, Mark ...
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Link to comment
Thanks again for looking in and commenting or liking...
Danny,
You're right but not for the reason you think.  I boiled it  for about 30 minutes (literally....) and it bent.  I got into the jig and when it dried , it warped.  I thought that since old shipbuilders steamed and boiled planks etc. I could do it too.   Oh well..  I'm digging through the wood pile to find something in the right size to cut.  I'm out of large cherry but have some other types.  Back to sawdust.
Link to comment
I had a stern piece that I could not bend to shape,  Too thick, it either broke or warped on me so I made up  fixture and laminated several layers of cherry together and I used epoxy to hold it together. Cheating I know but I did not wish to take the time to do it the so called correct way.
David B
Link to comment
Mark,
I built my transom out of some really hard wood. I spent all day filing the curved top to shape. Took a break and came back to put it in the vise to work the sides. I tightened it so tight in the vise that I straightened out the curve.
I have enjoyed following your build.
Good luck,
Larry
Link to comment
Finally... happy dance time again.  At least a small one.. post-76-0-71123600-1416950944.gif
It took me several tries but the top transom is done and in place along with the stern timbers.   I used some pen blanks as I didn't have any stock of cherry, boxwood, or pear thick enough.  The final ended up in yellowheart.  Thankfully, it will hidden by the planking.  :)
I cut the curve (which doesn't quite match the deck camber per the plans) on the top and bottom.  Spot glued the waste back on and then the cut the curve of the stern.   A soak in alcohol and the piece emierged.   Notches were cut into the timber for the deadwood and frame timbers.  Everything was then finessed into postion per the plans.  The photos I contrast corrected helped a lot.  Then the stern timbers were cut and matched to size and finessed into position.   The further outboard the timbers go, the longer they get.     I've checked and rechecked as these two bits are critical to the stern being right.
I still have a lot more work in this area, but at least I know I won't be scrapping this one out because the stern was a hopeless cause.  Just a small amount of fairing needs to be done before planking but I feel the rest of the framework should be added first to give it some strength.  Those timbers are bit fragile as they are now.
Here's the pics.   Sorry, I forgot to take pictures of the process.  As always, you click on them for enlargement.
Link to comment
Looks good, Mark.  Smooth and symmetrical.
Dan
Current build -SS Mayaguez (c.1975) scale 1/16" = 1' (1:192) by Dan Pariser
Prior scratch builds - Royal yacht Henrietta, USS Monitor, USS Maine, HMS Pelican, SS America, SS Rex, SS Uruguay, Viking knarr, Gokstad ship, Thames River Skiff , USS OneidaSwan 42 racing yacht  Queen Anne's Revenge (1710) SS Andrea Doria (1952), SS Michelangelo (1962) , Queen Anne's Revenge (2nd model) USS/SS Leviathan (1914),  James B Colgate (1892),  POW bone model (circa 1800) restoration
Link to comment
In progress:
Content of log :
Past build:
Link to comment
I'm with Dan.  And get some support in there for strength....ASAP
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Link to comment
Ahoy Mark :D
Nice :)
She is really starting to take shape
I know it works for the shipwright and can effect spelling but what does this do for the wood
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Link to comment
Brilliant work (as always) with the transom ...
... and, I do believe, Congratulations are in order on your recent promotion !!
:cheers:
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Link to comment
Looks good Mark. Ahhh the sweet smell of success. I know the feeling. What I want to know is where you got that cool little happy-dancing emoticon?  :D
Cheers  :cheers:
GEORGE
Link to comment
Very nice Mark, she's shaping up
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Link to comment
Thank you for the "likes" and the comments.
I'm working on it, Augie.
Ahoy Mark :D
Nice :)
It softens both the glue to remove the glued pieces and also softens the brain of the shipwright. :D
Cheers  :cheers:
PM sent.
Mark,
That looks like it was more than a little bit fiddly, well done!
Sam
Fiddly I think is an understatement, Sam.
Link to comment
So when do you get your 'journeyman' papers Mark - nice bit of work there!
cheers
Pat
Link to comment
Journeyman???  I'm just a mere apprentice still.
After singing a chorus of "Alice's Restaurant" yesterday and a Thanksgiving meal that couldn't be beat... I got to spend time in the shipyard.. yippiee.
I've cut, shaped, and installed two more timbers.  Seems that all the curved timbers from port to starboard have different curves and one is canted at about 45 degree angle from the waterline.  I'm not sure why.   The two finally fitted are for the upper and lower sills for the lights. The top sill timber is also the last deck beam for the quarterdeck.  The lower sill is hidden behind the planking.
I still need to fair these two before I go much further.   There's two more sets of timbers, one is for the counter and the other is for the taffrail to sit on.
Anyway, here's the picture I took for my checking as the camera shows more than the human eye (to me anyway).  I'm pleased with these two timbers and well turn to on fairing them in and trimming down the lower sill timber.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
