Licorne 1755 by mtaylor - 3/16" scale - French Frigate - from Hahn plans - Version 2.0 - TERMINATED
   Nicely done Mark,
     Thanks for the explanation on the micro-glaze & glass. Great information.
- Bug
Link to comment
Share on other sites
Nice work Mark!!
It is very coming along nicely.
JP
Jean-Philippe (JP)
Current build: SyrenRattlesnake (Scratch built)
:dancetl6:Please visit and subscribe to my YouTube Channel
On Hold: MayflowerHMS Victory Cross Section
Completed:   Armed Virginia Sloop, Viking ship,  The Flyer, Pilot BoatKrabbenkutterMarie-JeanneSloup, The Smasher
Link to comment
I have never used Micro-glaze Mark,  Usually it was acetate or microscope glass.  Thanks for the tutorial.
David B
Link to comment
It was a first time for me also David.  I've always used acetate and it just never looks "right".
Link to comment
Nice glazing job Mark.  Yeah, acetate works but does not reflect the primitive glazing they used in those days, especially a few hundred years ago, like my VOC ship.
Hmmm, would it be too late for me to change????  :o
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Link to comment
G'day Mark
the widows are so good. Was there any warping  sideway and up and down, or just twisting?
The small size of the timber would almost be impossible to be done without your death star.
Havagoodone mate
Greg
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
Link to comment
It warped the long way, Greg which would be the normal direction as the grain runs from side to side.  If I had turned the wood 90 degrees to cut it, it would have warped sideways.  Then again, I'm wondering if the Euro Boxwood itself.. I have some more and the thinner stuff is warping.
And I agree, cutting the small bits like windows, even the nameplate on the rear would be pretty darn hard.
Link to comment
Thanks for the "likes" and the comments on the windows.  I hope it helps someone.
I would advise that you definitely test on a dummy/scrap window before trying the real thing.
Edited by mtaylor
Link to comment
Mark, if I may add something. Check in a well stocked hobby shop for Microscale Decals Micro Kristal Klear. It can be used on windows up to about a quarter inch. In a pinch, some have used it as a glue for clear plastic, since CA tends to fog up clear plastic. Sells in a 1 ounce bottle.
Ken
Started: MS Bounty Longboat,
Link to comment
Chris,
It was the MM brand of Micro-Glaze.   I don't know if they still sell it.
Link to comment
Ken,
I'm late with this... I'll look into that for the next ship. I'm kinda' locked into this method for the rest of the glazing, I think.
Link to comment
Mark, I put it out for general use by anyone who is trying to glaze small windows, as an alternative to the MM stuff. I didn't see it in the current MM catalog, but it may be on the website.
Keep on truckin' with what you're doing. :)  I am fascinated by the POF Hahn construction. Some day I may do one. :rolleyes:
Ken
Link to comment
It's good to see you back, Sam, even if just for a bit.  Work is hell..  :)
Ken, I think the Microscale needs a topic of it's own out there.  I did some Googling and this might be perfect for many of us.
These pictures are some of "test" shots to sort things out.
The stern now has it's upper molding and the rest planked in ebony.  It still needs more sanding
The main stern carving is a "bad" carving blank which is hitting the scrap box as it's served it's purpose.  I stuck it on with some double sided tape for position and appearance.  I noted that it's too low and needs to be higher to look right.  The real carving is on the workbench and slowly being attacked with various implements of construction and destruction.   :) I think it's a perspective issue when I stuck it on.  The transom being angled, it looks low when viewed head on.
The taffrail... this one's a headache.  I've changed the drawing to reflect where this one doesn't quite fit and also to lengthen the "legs".  I originally designed it as a one piece but the legs are entirely cross-grain which weakens things (I think I've broken about 5 at this point while cleaning off the char). The other is an appearance  that I'm not happy with.  The cross-grain on the legs just looks dirty no matter how much it's sanded/scraped.  I even cut one in half and the cut area looks "dirty".   Anyway, I've reworked it so it's made of three pieces.. a crosspiece and two legs with the grain going in the proper direction.  I hope to cut another later today or tomorrow.
I'm noticing that things are quite perfect still in the dimension area but not much I can do at point, but I'll sort it out and tweak as best I can.  I'm about 1/32" (2") off on the level, left-to-right where the transom meets the counter.  And it's off about the same on witdth.  One side is just a bit wider at the top.   I'm thinking that the beams shifted slightly when I was reconstructing this area.  Nothing serious but I thought I'd point it out.
I do need to flip this beast over and plank the inside of the transom area above the deck beam so I can sand it down and shape before fitting the taffrail.
I'm thinking, right now, the taffrail will be un-adorned.  I tried carving some acanthus leaves for this area, but... I need a lot more practice for some thing that tiny. I keep at it as there's no rush on the carvings.
Comments and critiques are always welcomed and yes, this is to be continued. ;)
Link to comment
No comment or critiques Mark.
Just what Sam is saying.....drooling !!!!!!!!!!
Great job so far.
I'll will be waiting for other results.......
Sjors
Link to comment
Beautifully done Mark,
The windows are well spaced and have even symmetrical shape to them, and
with the glazing it is going to finish very well done.
Chris
Edited by Cabbie
Link to comment
Really well done Mark!  To me, wrongly proportioned or aligned windows can ruin what is otherwise a nice model.  Yours look spot on, very nice job!
I like the glazing you used.  I bought that same stuff from Micromark a while back because I didn't want to fiddle with plastic film or glass and getting errand glue smudges.  The effect is really nice.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
The stern is coming along nicely Mark; keep practising the leaves - you'll get there.
Is it a trick of the light or have your treated the window glazing to create an internal candle glow effect?  Looks great in the photo.
cheers
Pat
Link to comment
Looks Amazing Mark, Beautifully done
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Link to comment
looks really nice Mark.......if you hadn't mentioned the short comings,  I would never had known.   I tip my hat to anyone who can make decorations like that.....yours is just another stunning example!   very nice work!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks for the "likes" and the comments.
Great job so far.
Sjors
That makes two of us waiting for other results, Sjor.   ;)
The glazing is growing on me.  I like the imperfection of it and the longer it sits, the stronger it seems to have become.
cheers
Pat
It actually back lite by shop light, Pat.  I opened the blinds since it was "somewhat" sunny today and killed the flash.  :)  It almost makes want to put in LED's...  A little late for that, I think.
Chris
Thanks Chris. The windows fit nicely on the transom frames.  I think is right.. the window spacing is the "big deal".
And I think I found the problem...  the area highlighted in red.  I'm thinking that the framing underneath is off a bit.  Since the planks edges are flush with that framing..  so it goes.  Sanding sticks at the ready.
Link to comment
  Nothing works like elbow grease Mark.  Nice work. I'm becoming super envious of the laser cutter though.  How long til Father's day when I can make up an excuse to buy something else?  Heh
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
