Nicely done, Rusty. You'll never want to go back to forcing plank strips again! And the result looks lovely.
Fantastic planking Rusty.
If someone hasn’t tried it they can’t believe how much nicer it is to plank this way
Couldnt agree more. It just looks soooooo much better this way. One thing I am struggling with a little bit is getting a smooth curve on the curved planks. Any pointers you'd like to share? :)  or is it just a question of experience. I am using walnut mind you and it's not the easiest of woods to cut (well that's my excuse and I'm sticking to it :D :D ).
Nick
I'll just add my voice to the chorus of praise Rusty - a very fine looking planking job indeed.
Ditto to all the above Rusty. That's reaaaaaaaaaaaal nice.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Thank you for such kind words.
Nick. Practice, practice, practice. When I first started I rejected as many as I was accepting. I would
think walnut would also be a bit harder to get a smooth run. Also I use a sanding block whenever possible.
It helps me keep a clean edge.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Hi Greg and Ben,
Oh I've used the white glue sanding trick many times. There were only a couple of spots where I needed to do that. The joints that bother me the most were ones that weren't a tight as they should be but were filled with glue and dry before I saw them so there was no sand n fill possible. Oh well trying harder on the port side.
Chris, I could see where doing that with tung oil would work. Not so with the poly as it dries real fast.
Thanks everyone for stopping by and the like. Continuing to make progress.
Rusty
Hello all,
Well I’m happy to say I’ve completed the planking on the portside too. No stealers or drop planks this
side either. All that is needed now is a good deal of sanding and then some wipe on poly. I have to say
planking this way is more time consuming but it works so much better and the run of the planks is much
easier to maintain. Definitely the way I will plank from here on out!
One thing I want to point out is that I handle a model a lot when I’m working on it.
Because of this I would inadvertently rub off some of the pencil marks. To make sure
I didn’t lose the main belt line mark I used a sharpie to mark them. Then if I accidently
rubbed off any markings I could go back to the main mark and redo them.
After I check the hull over and make sure it’s all set I will move on to the stern. :)
Rusty
Sweet planking.
Thank you all for the kind words and all of the likes. It is very much appreciated.
Well I’ve started chapter 6 now and started working on the stern. To start I have to cut the transom out of
 some 1/32” plywood. I pasted the plans on and then cut it out with the scroll saw getting it close. I then
used various sanding tools to get it close to shape.
The windows were cut out using an x-acto and finished with files too.
Then the assembly was glued to the frame work.
That's it for now!
Rusty
That is one nice looking piece.  PLEASE use caution around those 'wings'.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Oh yeah I see major potential for an oops moment!
Rusty
