Everything posted by gjdale
Nice work Jerry. Pity about the kit quality disappointment, but you're making a fine job of her regardless.
That's quite a milestone Augie! And your model shows the care and effort you put into every single one of those hours. Just beautiful!
- 2,191 replies
- confederacy
- Model Shipways
Well done with the hammock cranes Boyd. The material you refer to is called Tulle. What you have pictured has a 'honeycomb' pattern - I believe a 'diamond' pattern would be more correct. If you have trouble finding some, I have about 50 lifetime's worth of the stuff (used on my Victory). I'd be happy to send some to you if you wish - just PM me with your postal address if you'd like some.
- 413 replies
That looks pretty good to my eye Mark (though I've been known to be wrong before.........)
Great to hear your fix has worked Jesse. Looking forward to the next instalment.
- 1,306 replies
- syren
- model shipways
Fantastic job you've done there Mobbsie, she really does look terrific. I hope you gave the Museum a couple of "before" and "after" photos to show the extent of your work! Well done mate - now get cracking and catch up on your cross-section!!!
- 62 replies
- harwich bawley
- fishing boat
Thanks again folks for all the kind words and the "likes". Just a small update today. I have completed preparations for the Upper Deck framing. The next step was to make the Upper Deck Clamps. These comprise an Upper and a Lower Clamp and I opted to include “iron bolts” using copper wire blackened in situ using Liver of Sulphur. To make life easier, I prepared a card template for the bolting pattern and inserted the bolts prior to installation on the model. Here are the clamps ready for installation (the bolts to the right appear not to be blackened, but this is just a trick of the light in the photo): Clamping them securely was a little tricky and I was grateful for the mini Spales I had made previously: The final preparations prior to moving on to the Upper Deck construction were the Mortar Pit Support Standards (knees) and the Centreline Stanchions. The knees were easily cut on the scroll saw, ensuring the grain was oriented on the diagonal, and then given their final shape using the spindle sander and disc sander. The Centreline Stanchions introduced another timber – Walnut. These were turned on the lathe. My extremely limited turning abilities managed a reasonable approximation to the stepped shape at either end of these. The Walnut is not a particularly good wood for machining, but it was finished up by a series of increasing grit sand paper, to an almost polished finish prior to being coated with Wipe-On Poly. During the turning process, each end of the columns were drilled to take a 1.5mm brass locating pin. Here are the Stanchions and Standards (Knees) in place, along with a view of the completed Deck Clamps. The Stanchions are only temporarily placed for the photo – they will be permanently fixed once the Deck Beams are ready to be permanently fixed in place. I have now started work on the upper deck beams, but have discovered a possible error in the drawings. I have sent a message to Jeff Staudt for confirmation before proceeding.
- 456 replies
- finished
- bomb ketch
scroll saw proxxon ds 460
gjdale replied to michael101's topic in Modeling tools and Workshop Equipment
Would the Dremel Moto Saw meet your needs as a relatively low cost option - it costs about US$100 here in Australia? As you already have onr Dremel tool, I assume you can source them easily in your country. https://www.masters.com.au/product/100882549/dremel-scroll-saw-moto-saw-ms20ne.jsp -
Hey Jack, Good news about the opportortunity for some extra play money! It's a pity that it means a break from the shipyard, but your cross-section will still be there waiting patiently for your return, as will we. In starting work on the upper deck framing, I discovered an error in the plans yesterday (I think), and also in a couple of my spreadsheet dimensions. I'll post a PM to the group later today with the corrections.
- 60 replies
- granado
- bomb ketch
Thanks Jerry, Isn't it great to have an understanding and supportive Admiral? The Chris Craft is still going, but all modelling paused while I had my hip replacement surgery. Still recovering from that - another two weeks before the Doc will let me go back to work, but am allowed small stints in the shipyard. Focus has been on the Bomb Vessel Cross-Section lately while I waited on some bits and pieces I needed to make mods to the Chris Craft. Expect a return to that build very soon. And perhaps the start of a third project - something completely different!
Be grateful that the Admiral didn't have you turned to scrubbing the decks as well Jerry! Adding the crossbars to the deck really makes a difference. Looking good!
Very neat work producing that bell Ian. I really do admire your machining skills and especially your ability to think through the "how" of manufacturing new parts like this. It may seem simple to you, but I learn something from every new description you post. If you lived in my neighbourhood, I'd be banging on your door begging for lessons!!! I think you might have some difficulty using walnut for milling the belfry - my experience (albeit very limited) is that it doesn't machine very well. I've got a ton of swiss pear scraps, and possibly even a bit of boxwood scrap you'd be welcome to if you lived a little closer. Come to think of it, Mobbsie also has a ton of scrap pear and he does live a little closer. Maybe you could work out a deal...........
Jesse, Bad luck with discovering the warp now rather than earlier. However, as you've used a PVA glue, if your attempted fix hasn't worked, you still have the option of de-bonding all the glued joints using isopropyl alcohol and starting over. I would be careful about soaking the plywood too much in straight water as it may start to delaminate. The alcohol will evaporate quickly, so is less likely to cause this. In the end it's your choice on how to proceed, but speaking from experience, if you take the time to fix something properly now, you will be very glad you did so further down the track. Remember, it's not a race, so take your time and make sure it's to your own satisfaction before moving on.
- 1,306 replies
- syren
- model shipways
That's a neat innovation! It looks great.
Okay Kevin, That's enough slacking off on other modelling projects for now. It's time to get back into the shipyard and get on with Miss Vicky.
- 1,319 replies
- caldercraft
- Victory
Just got caught up on your log Per. Nice job. I look forward to seeing the rest of your journey from here.
- 335 replies
- 18th century longboat
- Finished
Thanks Augie and Mark. Mark - apart from the limited amount of planking that has already been done on the inside, it will be fully planked internally above the upper deck (ie bulwarks etc).
- 456 replies
- finished
- bomb ketch
It's been a while since the last update. Recovery from my hip surgery has certainly slowed things down a little, but I have managed to make some progress. The next stage was construction of the Mortar Pit. Construction of the Mortar Pit Construction of the Mortar Pit commences with the six Mortar Pit Deck Beams that sit atop the Shell Room. These were cut from 1/4" Pear stock. Six rectangular blanks of identical size were cut and then spot glued together. A single paper pattern for the beams was then glued on to the gang of blanks and the notches for the Shell Room headers (5/16”) and the Mortar Pit Boundary Timbers (1/4”) were cut on the mill to take advantage of the still square faces. The round-up of the beams was then shaped using the spindle sander for the inside curve and the disc sander for the outside curve. After test fitting, the Deck Beams were used as additional support to ensure the Shell Room was squared up for final fixing. Once the Shell Room was securely fastened, the Beams were given a coat of Wipe-On Poly and glued in place. The Mortar Pit itself is fairly straightforward construction, consisting of two Boundary Timbers of 1/4” x 5/16” Pear, a Primary Layer of planking (3/16” Holly) and a Secondary Layer of planking (1/8” Holly). I decided to use pencil along the plank edges to simulate the caulking with these decks, rather than the black paper used on the deck of the Shell Room, partly because I was concerned about glue adhesion, and partly because I wanted to see what it looked like. Once again, the “drill and fill” method was used for simulating treenails. In retrospect, I should have sealed the Holly before applying the filler for the treenails as some of the filler has gotten into the grain of the deck and slightly discoloured it. Here are the component parts prior to receiving a couple of coats of Wipe-On Poly. The Primary planking has a 1/8” brass spigot inserted – this will locate the base of the turntable in a later stage of construction. The Secondary planking has a circular cut out for the turntable. This was formed by cutting roughly to shape on the Scroll saw, and then finishing on the spindle sander. Once both decks had been completed, it was a fairly simple case of finessing them to size to fit the space defined by the Boundary timbers. Here are a few pics of the completed Mortar Pit in place: Next up, fitting of the Upper Deck Clamps and preparation for construction of the Upper Deck. Stay tuned.....
- 456 replies
- finished
- bomb ketch
