Everything posted by mtaylor
ancre Chebece 1750 by Jeronimo - FINISHED
mtaylor replied to Jeronimo's topic in - Build logs for subjects built 1501 - 1750
I love the rework as it looks great. Those carvings are just beyond belief. Amazing. -
Nice work Patrick. You have one great power of deduction. I do have a question... first picture, by your thump is an rectangular opening. What is that for? I don't recall seeing it in the pictures of the "large" version.
i'm with the others... that could have been a lot worse. I'm glad the damage wasn't more severe on this beautiful ship.
- 692 replies
- eagle of algier
- chebec
Hi Andrew,
I've found the only way to get rid of bowing was to overbend in the direction opposite the original bend and get the wood wet. Worst case.... cut new decks out of unbent wood. Having said that, she's looking good. Have fun on the hunt.
- 37 replies
- eagle
- constructo
That should have worked, Darrell. You might try pre-bending using a curling iron after soaking. I'm using the curling iron method and it usually takes two sessions of soak and heat to get the curve I need for the frames to not want to spring back out. But I'm using boxwood for the framing. Might need to do a combination of things as others have suggested.
- 648 replies
- niagara
- model shipways
Congratulations, John. I really can't add anything that hasn't been said. She (?) is one unusual and wonderful model.
Darrel, Did you steam the planks and bend them before installing them? I'm doing my ship's boats now and I've found that's only way to keep the hull from deforming.
- 648 replies
- niagara
- model shipways
bending planks
mtaylor replied to bluenose2's topic in Building, Framing, Planking and plating a ships hull and deck
Old wood is probably pretty brittle and mahogany isn't known for it's bendability anyway. What you can do build up what you need is layers by rip[ping it into thin blanks and then shaping and pre-bending each piece (layer). Make a jig to match the bend required for the bending part. Then stack the pieces together for the final bending. Glue them together and put back on the jig to dry. -
Now why did you make the warning after I sprayed coffee..?? I think spilling paint is a rite of passage or maybe just experience. I'm trying NOT to use paint to save the carpet.
- 171 replies
- krabbenkutter
- authentic models
I'll pull up a chair and watch from the cheap seats while munching on some popcorn. This should be interesting to see how you each interpret and proceed on the builds.
- 1,090 replies
- showcase models
- vendetta
It's an interesting build, Archie. Something out of the norm and you're doing a great job. What's not to like?
- 37 replies
- eagle
- constructo
Great work there, on those fiddly bits. Yancovitch is right. I'm not sure if all the aftermarket PE people pay a royalty or not.
- 2,696 replies
- heller
- soleil royal
(and 9 more)
Amazing optivisor light
mtaylor replied to Kurt Johnson's topic in Modeling tools and Workshop Equipment
No need to drive, Kurt. There's always shopping on the Internet. Where I am, it's about the only way to get any thing for this hobby, except wood glue, sandpaper, and the like. -
Just... what? More than amazing and stunning. I'm printing those last ones out and will hang a couple in the workshop for inspiration.
- 1,035 replies
- royal katherine
- ship of the line
He does make a horizontal machine.. https://shipworkshop.com/products/tools/ropewalk-planetary-3.1 I have the older model which is excellent and also the parts to convert it to the "newer' model for 3 strands and a center one but haven't set that up yet.
Most, of the Lumberyard offerings are only timbering kits. However, the Oneida appears to be a complete kit as is the Caustic. A quick email to The Lumberyard will verify this.
OC, Dafi has hooks and other assorted goodies (etched brass) for the Heller 1/100 scale Vic. I bought the hook sheet and it's working for me at 1/64. Have a look here: http://www.dafinismus.de/plates_en#anker7
- 455 replies
- slightly modified
- greyhound
