Everything posted by mtaylor
I'm making frame blanks for a Hahn method build using 3/32" thick cherry that's 1" wide. I edge glue the pieces for both layers and then after that dries, spread a thin layer of wood glue on one blank, put them together and press between two sheets of glass to keep everything straight. What I'm seeing is sometimes the wood warps and the bond isn't made at the edges. Is there a cure for this? Am I doing something wrong? Just hits me as very strange.
Looks good Jason. You are moving along quickly. Did you try soaking and applying heat to bend the planks? AL's wood isn't the best but it will bend with water and heat.
- 116 replies
- constellation
- artesania latina
Wonderful... fantastic looking artillery, Piet. I hope you had a great birthday party.
Beautiful work, Garward. Will these be entered in a contest? They should be as they are that good.
- 50 replies
- cannon
- le fleuron
Or, you can use fabric glue. Both seem to work.
what is the ideal modelling table?
mtaylor replied to AON's topic in Modeling tools and Workshop Equipment
Rich, There is a topic for this: http://modelshipworld.com/index.php?/topic/3869-so-where-do-you-do-yours-then-model-making-that-is/ -
Hi Ulises, You're doing a great job on her. I think you hit it dead center on why there's not more builds of her... cost and let's add size.
- 786 replies
- Royal Louis
- Finished
I'm looking for ring pins. Ideally, the Billing Boat's ones: http://www.billingboatsusa.com/149-bf0285-eyebolt-6mm.html However, after hitting about 15 webshops and no one has them in stock... I'm considering these: http://www.agesofsail.com/ecommerce/fittings/eye-4005-04-brass-ring-bolt-4mm-10.html They are photo etch and I'm wondering how they look installed. Has anyone used them? If those don't work, I guess I'll order these: http://www.castyouranchorhobby.com/item--Ringbolt%20-%203mm--ms0430 Or check my supply of eyebolts and split rings. Worst case... make some.
A flame???? Nooooooooooooooooooooooooooooooooooooooooooooooo.................... <runs away screaming> Measure twice??? I thought it was cut twice. Oops... Indeed it was. And beer when I finished, even more so.
Let me add to the chorus.... great looking rudder, Augie!!!!
- 2,191 replies
- confederacy
- Model Shipways
A good plan, Kats. I use a similar thing to raise the work area.
- 237 replies
- cutty sark
- revell
Beautiful work, Garward. It's good to see you back posting.
- 50 replies
- cannon
- le fleuron
Lovely work on the taffarel, cap rail and all the fiddly bits, Danny. That is an interesting method.
Doğan, Please use Google and translate into English. This is an English forum.
