Hello Albert,
Thanks,
and everyone else for the LIKES.
Meanwhile, I made the futtock shroud plates for the tops of the foremast and the mizzen mast.
The difference between the deadeyes of the top of the foremast and that of the mainmast is barely recognizable (0.2 mm), yet it is important to me. IMG_0497_wett.jpg.bdecdc50e95c0d7dcba1b471b9a52f26.jpg
The difference between the deadeyes of the top of the foremast and that of the mainmast is barely recognizable (0.2 mm), yet it is important to me.IMG_0501_wett.jpg.5d998a0b5c1adf00bf03862e9506ad88.jpgIMG_0505_wett.jpg.050560aa0f345dc201cb553ed1743cb1.jpgIMG_0510_wett.jpg.7955083c086bb11bf482db7149dde1b6.jpg
Furthermore, I produced the royal cross trees for the formast and the mainmast.
I hope the pictures explain everything so far.
IMG_0513.thumb.jpg.918dbfdb1e014aa65f760328cbe31450.jpgIMG_0514.thumb.jpg.6a04f30871fa57488221ad35861e042f.jpgIMG_0518.thumb.jpg.9bfcbf56e26e924e82b7533d7938e57c.jpgIMG_0519.thumb.jpg.b77263d67ac99075b93b03a4c0fbf8c5.jpgIMG_0522.thumb.jpg.90d055a4112d129e674708e5cc2137fe.jpg
Johann ~ as always, I'm staggered by the quality of your work!
I've just been doing some futtock plates and I have copied your design. (Well, at least I've done my own version of your design.)
I 'trapped' the deadeyes in the metal strop before soldering the strop to the plate. I see you must put the deadeyes inside the strop AFTER soldering. Do you have to squeeze the metal strop a little to keep the deadeye from popping out?
Jim.
I cut it twice . . . . . and it's still too short!
HMS Leopard 1790; scratch build 1:80 PoB
Cross Section - HMS Leopard 1790 - 1:44
excellent metal work Johann,
those silver soldered cross trees look look lovely...
Nils
Current builds
-Lightship Elbe 1
Completed
Stunningly beautiful work, Johann.
Hello,
thanks to all, for your attention.
After finishing the tops, I continue with the royal masts.
The French Corvette had a weathervane on every royal mast.
Here are some pictures:
IMG_0536.thumb.jpg.818df35f130333f2a656ddce521fc5dd.jpgIMG_0540_wett.jpg.c0157166ddc134acd6b7a9bb68cba766.jpg
Whether this corvette also had lightning conductors is in this context
quite a legitimate question.
594246fb0d2e3_Figuier_-_Les_Merveilles_de_la_science_1867_-_1891_Tome_1a.thumb.jpg.899562cf9a45ff116cbd7fbb09e34668.jpg
Astonishing detail ... although we expect it, it is extraordinairy Johann
Carl
Your craftsmanship in both the wood and metal fabrication is just fantastic!!  Unfortunately the workmanship you employ is well beyond most of us, but just gazing at the results is something to behold!!:cheers:
Dave
“You’ve just got to know your limitations”  Dirty Harry
Current Builds:  Modified MS 1/8” scale Phantom, and modified plastic/wood hybrid of Aurora 1:87 scale whaling bark Wanderer.
Past Builds: (Done & sold) 1/8” scale A.J. Fisher 2 mast schooner Challenge, 1/6” scale scratch built whaler Wanderer w/ plans & fittings from A.J. Fisher, and numerous plastic kits including 1/8” scale Revell U.S.S. Constitution (twice), Cutty Sark, and Mayflower.
                  (Done & in dry dock) Modified 1/8” scale Revell U.S.S. Constitution w/ wooden deck and masting [too close encounter w/conc. floor in move]
Hope to get to builds: MS 3/16” scale Pride of Baltimore II,  MS 1/2” scale pinky schooner Glad Tidings,  a scratch build 3/16” scale  Phantom, and a scratch build 3/16" scale Denis Sullivan.
Hello,
It always makes me happy when I notice your interest in my report.
Thanks everyone
In this context, the lightning conductor on the main mast should not go unnoticed.
On the original model (yellow arrow) the lightning conductor can be seen.
I assume at least that this is so.
Hello,
the continuation of the report is about the fittings for the topmast caps.
The iron bands must be fitted with bolts and square nuts.
IMG_0548.thumb.jpg.e9a053a8ba69d7a48242dcec0110a4f6.jpgIMG_0551.thumb.jpg.a8bd6667be64020f0bb6268191220787.jpgIMG_0552.jpg.2a2c3b830436d43836c2abbb6fc36015.jpgIMG_0556.thumb.jpg.e07095479d7ba8359d76e2aea8cef782.jpg
To make this detail with 0.75mm / 0.75mm square nut and a 0.4mm diameter bolt, I chose the following method as shown in the pictures.
IMG_0559.jpg.2a13d778b97e923fb9b2381a9ffe5fab.jpgIMG_0567.thumb.jpg.b09f15a9313ef642144ad5396808c928.jpg
Hello,
thanks for the nice comments and the LIKES.
My previous interpretation of the weather flags and the lightning conduction for the La Creole is completely wrong.
Our forum colleague Dirk @ Dubz showed me a picture from the book "Modeles Historiques" by J. Boudriot from the top of the main mast of the Paris model of La Creole.
I also want to make this beautiful detail for my model.
For this I use the etching technique.
I have already drawn the necessary template.
Your metal work really is top notch Johan. :) That is something I need to work on myself and learn to do on my own builds as it adds some wonderful details to the build.
"A Smooth Sea NEVER made a Skilled Sailor"
- John George Hermanson
-E.J.
Current Builds - Royal Louis - Mamoli
                    Royal Caroline - Panart
Member : Nautical Research Guild
55 minutes ago, archjofo said:
The etching parts for the weather vanes have not yet arrived.
Meanwhile, I continued with the fittings for the topmast caps.
IMG_0593_wett.jpg.953f0739813e3cc26337372b7db0d1ff.jpgIMG_0597_wett.jpg.652879c6bdf5e5bac0aaf7acd9b8d111.jpgIMG_0600_wett.jpg.1eb584c998246854e3e150fccc44712b.jpg
.......wow..........mind blown........micro magnificence
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel), Le Renommee (Euromodel)... on hold
Current WIP: Berlin by Corel
On Shelf:  HMS Bounty (Billings),
First of all, I would like to thank you for your supportive comments and for the LIKES.
Let us remember
LINK
Meanwhile, I got the etched parts for the weather vanes delivered.
I immediately went to work,
and built the weather vane with lightning conductor for the mainmast top of the La Creole.
In this context, I would like to mention this report on the lightning control of sailing ships. There are many parallels to the lightning conduction of the La Creole.
I have also worked on the topgallant masts. Here are the results.
Edited by archjofo
Love that PE work, Johann. Did you use all 18 weather vanes until you got one right or do you have 17 extras to sell? I'll have to research into British practice regarding lightning strikes.
Edited by dvm27
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
@dvm27
Hi,
the La Creole carried max. 3 weather vanes. These etching parts are extremely filigree.
The soldering of the mounting rings is very difficult, so some of them are damaged.
So I had to produce more than I need.
The etching board with the 18 weather vanes cost only 6 € including shipping in Germany.
Edited by archjofo
Beautiful Johann ... it is a marvell to see the fruits of your work take shape in such a wonderful way
Carl
@cog
Thanks for your nice comment and
@all the others for the LIKES.
Here is another update.
The topgallant masts were equipped with the remaining sheaves and the fids.
Similarly, the trestle trees still received sheaves.
The last picture shows the parts of the masts that have been produced so far.
Edited by archjofo
