Hi Carl,
thanks for the kind words.
All the others thanks for the LIKES.
In the meantime, I am making the ratlines on the port side of the main mast.
This is also a question of discipline, regularly two ratlines every day ... 😁
absolutely amazing - beautiful work!  The simulated splices look great.
Current builds: Model Shipways 1/48 LongboatEduard 1/48 F4F-3 and F4F-4
Completed ships and boats: Kitbashed Model Shipways 1/24 Grand Banks Dory, 1/16 East Coast Oyster Sharpie,1/48 Echo Cross Section, 1/48 Scratchbuilt Hannah from Hahn plans, 1/64 Kitbashed Rattlesnake from Bob Hunt practicum, 1/64 Brig Supply
@druxey
@davec
Hi,
thanks for the positive feedback, and also all the others for the LIKES.
Slowly I work my way up the shrouds of the main mast with the ratlines.
Today I want to give some details about the ratlines. Often pictures show more than words can describe.
I hope that it is the same in this case. Enjoy the pictures:
@Louie da fly
Thanks for the kind words. That motivates again and again.
Thanks to the others for the LIKES.
I am currently preparing the futtock shrouds.
The front futtock shrouds were served. The others only in the area of the splices.
Source: Atlas du Génie Maritime
The attention to detail is incredible, Johann.  Your logs are an instruction manual.
As can be seen in the Parisian model of La Créole, Petrejus' "The Model of the Brig Irene" shows that the futtock shrouds, coming from above, run upwards around the lower shrouds and downwards again in front of the futtock shrouds. In La Créole, the ends of the futtock shrouds run over three ratlines and are fastened with three tapes. It is also interesting that the ratlines in this area are under the futtock shrouds.
727792688_E.W.Petrejus_DasModellderBriggIreneS_192.jpg.87f1b6a18299c7222f10a67fdee603e7.jpg
Source: E.W. Petrejus "The Model of Brig Irene" p. 192
At first sight one could assume a mistake of the model maker. However, after extensive research I can state for myself that obviously both types of design must have existed here, at least continental.
Therefore I orientate myself also with this detail at the Paris model.
In connection with the catharpins, the futtock shrouds were placed alternately on both sides and only attached as an aid to make corrections.
