Indeed rigols - I've seen them made in a few logs on the forums on shipmodelinfo, where they make mostly modern boats, maybe you can find ideas there? Etching or casting would maybe work?
Here is another view: Mariefred alongside quay in Mariefred
I see darker pixels indicating carvings or reliefs inside them, but not more than that - how large would these things be on your model?
Edit: I found a picture where you can see some detail, taken after the fire in 1980 before rebuild (you can search digitalmuseum.se for hundreds of old pics by the way):
https://digitaltmuseum.se/011015402462/fo124957dia/media?i=291&aq=owner%3A"S-SMM"+text%3A"mariefred"
Thanks, Matle.  Those are the best pictures so far, but it's still hard to know exactly what is there.  Is that a flower in the middle and a straight line to either side of it?
Bob
Current build:  SS_ Mariefred
Hi All,
I have to move away from research for a while to build a little more.  Or I will know everything there is to know about the Mariefred and never build her.  The Mariefred is a very early (1903) steel boat.  So like Nils (Mirabell61), I had to plate her, rivets and all.  Maybe I shouldn’t say so but it was a lot easier that I thought it would be.  The main problem is finding the right foil for the job.  Most of what I found at the hardware store was too thin and doesn’t look right.  There were four or five brands where us non-professionals find what we want.  But walking down to the end of the store where the contractors go, I found the heaver foil that is needed.  I found an old clock gear that I made into a ponce wheel and with just a little practice . . . here’s the results.   I’ll accept it as a first try.  Now paint and on to the rest of the boat.
Bob
Wow !!
very nice plating job Bob, I like it that you even tried to get the vertical rivet rows of the plate-edge in staggered arrangement. Well done   ;)
Nils
Current builds
-Lightship Elbe 1
Completed
Bob,
What about the aluminum foil sold in groceries stores? There is a variety which is very thick, while still being soft enough to accommodate all shapes and curves.
Once glued to the wooden hull, it could have been perhaps easier to install.
Anyway, you did a fantastic job and your rivets are just perfect and very realistic of the era.
Yves
Coming along well Bob. I must try plating some time - your first attempt seem to have gone pretty well.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thanks Nils, Yves and Keith,
I referred to the aluminum as foil.  Really it is an Aluminum tape used to tape the duct work in heating systems. Sorry about that.
Bob
Ah, Lawrence, I wish I could take credit for the plating but I am only doing what I see Nils doing oh his "SS Kaiser Wilhelm der Grosse".
Bob
Thanks John.  It was an enjoyable learning experience.
Bob
Thanks Patrick, it was a fun learning experience.  So I guess I'm not too old to learn yet.
Bob
is it self sticking?    super job with it.......came out really well :)   so,  you did along the bulwarks first,  and went from the keel up......is that how I'm reading the layering?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Yes, the tape is self sticking with a waxed paper backing.  As for the plating, there was two was it was done.  One was to start at the keel and lay the above panel overlapping the one below.  The other method was to lay every other row of plating (1-3-5-7), then go back and lay the other rows (2-4-6) overlapping both the row below and above.  According to the plans the Mariefred was plated by the second method.
Bob
Nice work Bob.
Michael
John,
The Tassies' are common on Swedish water, there are many of them commanding ships like these.
So I think you have to let this one go, at least for the moment.:):D
Respectfully
Hi Bob
Missed your build while my break, WELL DONE! I like the plating, cant wait to see that painted!
Regards
Gerhard
Problems just mean: solutions not yet found
Models in progress
SMS DANZIG
http://modelshipworld.com/index.php/topic/12842-sms-danzig-1851-by-gerhardvienna-radio-150-scale/
USS CAIRO
http://modelshipworld.com/index.php/topic/13282-uss-cairo-by-gerhardvienna-live-steam-radio/
Baby Bootlegger 1/10
http://modelshipworld.com/index.php/topic/13625-baby-bootlegger-110-radio-by-gerhardvienna/
Swiss paddlesteamer RIGI 1848 1:50, after plans from the Verkehrshaus Zürich, rescaled to original length
Anchor tugboat BISON, 1:50, plans from VTH, scratch
Finished models
See-Ewer ELBE, Constructo kit 1:48
German fastboat after plans from german Reichskriegsmarine measure unknown (too ugly to show up!)
German traffic boat for battleships WW2, 1:50, after plans from Jürgen Eichardt, scratch
German Schnellboot TIGER P6141 VTH plans, scratch
Calling Captain Bob. Calling Captain Bob!
Hi Bob.  I've become a bit concerned that you haven't been posting for quite a while. I've sent you a PM a while back, to check to see if you were ok, but I've not had any response so far.
I hope all's well with you and your Admiral and that you're able to rejoin MSW soon.
All the best!
Patrick
Unfortunately Captain Bob passed away before completing his model. He will be missed by all who knew him.
Danny
Cheers, Danny
Very sad news. Bob was such a friendly soul. He will be sadly missed.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Danny
Just spechless.............
My prayers to his family and friends!
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
I'm so sorry to be missing his support, advice, but most of all his presence. For me he has been one of the people whom make MSW a home from home... I hope he didn't suffer, and wish his family and friends lots of strength to cope with this great loss ... I will remember him as a dear friend
Carl
This was a shock, I enjoyed his council and forum friendship, I will miss him for sure.
My condolences to Bob's wife and Family.
Michael
