My model building experience started with an AJ Fisher kit in the 1980's. It was the Bluenose. I bought a number of others, both foreign and domestic pre Syren. They may never be built. Your products have been successful for so many reasons for the "average" model ship builder that they have displaced them. Product design/engineering, material quality, instruction sets and customer support are the bedrock of your enterprise. Add to that the models you build so skillfully are so inspiring! Who else delivers such a complete product?
Joe
Thanks
Hoping to have chapter 11 available really soon guys.  Sorry for the delay.  Lots going on here in NJ.   Daughter starting Med School, Selling my Aunts house after moving her to a nursing home...Spring house duties....Vacation starting next week.
When I return from vacation all should be back to normal.   Heading to the beach in Rhode Island and then up to Maine.  All 12 of us including the kids significant others.   LOL...need a break.  Although with that many young people it may be tough to relax.
I'm sure you'll enjoy your holiday, have fun with the family!
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
I have completed the prototype for the cathead support knee.  This knee is directly under the cathead and is quite complex.  It twists and turns while tapering thinner as it gracefully extends down and connects with the lower rail.  The frieze follows the same look and feel as the contemporary model.   This piece is kind of assembled like you guys did for the cheeks and hair brackets...if you are wondering.
This will be built in two lengths.   Each length is of course made up of many pieces.  I will detail the assembly process soon when I make it for the other side.  There will be templates laser cut to help you and assist in the shaping and positioning.   Once the other side is finished I will make the fourth "half" head timber that is positioned between this and the main rail.
Here are a couple of pics of the cathead support knee on the port side.  I am happy with the results considering that the pieces were all laser cut.   I have made these from scratch before and these seemed to come out just as good.   Its the first time I tried out this concept and laser cut approach.   I believe you can now start to see how the finished headwork will look.  Hopefully you will agree that it doesnt look like any kit you have ever seen before.
Those look outstanding Chuck! I’ve been really focusing on this part lately and how to design it, pouring over contemporary examples and drawings, those look spot on with everything I’ve seen. Simply excellent results there. Not even close to resembling a kit.
Stunningly superb Chuck!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Looked at ordering the Scotch Spray Mount on Amazon Prime yesterday and they wanted $41. That’s nuts! Got a different spray adhesive for $12.
Regards,
Jim Rogers
Damn the Torpedoes , Full speed ahead.   Adm David Farragut.
Chuck do the channels attach to the molding or is the molding cut away and the channels are connected directly to the hull?
Regards,
Jim Rogers
I had no problems with the 5mm deadeye strops, the 6mm keep breaking when inserting them in the channel. I am enlarging the slot but what a PITA.
Regards,
Jim Rogers
Figured out the deadeye issue. I purchased 5mm and 6mm ebony deadeyes. The 5mm deadeye groove is deep enough to fit the strop properly, the 6mm has a extremely shallow groove. I found a pair of wire bending pliers that locked the deadeye in place and used my Dremel with a cutting wheel and deepened the groove. Problem solved.
Regards,
Jim Rogers
I am a new jack and looking for a future big project. What tools are needed for this build? How hard is this ship to build? How difficult to make the parts not supplied with the laser cut parts you can buy? How much are the installment sets?
Andrew
Andrew
Andrew because of Winchelsea’ s scale and Chuck’s instructions she is not a real difficult build. The build is completed via chapters and with each chapter you will learn a lot. The chapter on planking for example is some of the finest instruction you will get on the subject, ever. You will need a hobby saw like a Byrnes or the one MicroMart sells to cut your wood strips although if you can’t afford a saw there are places you can order strips by sizes required, required sizes also part of Chuck’s instruction. You will need hobby knives, #11 blades, tweezers, clamps for keeping planks in place, small machinist squares, magnifying lenses if you are an old fart like me and a big box of patience. Best part, unlike many Model Manufacturers, if you don’t understand something Chuck is always there to ask. All the laser cut parts are sold as Chapters. They run under $100. This is a great experience and you will have beautiful model that you will be proud of in the end. Most definitely do it.
Regards,
Jim Rogers
That depends on your skill level with regard to scratch building.
There is a lot of information here:
The 32 Gun Frigate Winchelsea (1764)
You can look at the illustrations and ask yourself  " Can I make that ? "
The store is closed right now so the prices are not available.
If you are planning on milling your own wood strips you will need a good small table saw  such as the Byrnes Saw..
An alternative will be to buy the timbering set from Modeler's Sawmill
As well as this forum with all the build logs.  Member Build logs for the HMS Winchelsea
― Jimmy Buffett
On Hold:    Rattlesnake
Has anyone used adhesive paper for the friezes, like that used for mailing labels?  In theory it seems like a good idea…
Regards,
Glenn
Current Build: HM Flirt
Yes...they work great BUT.....BUT,  the adhesive is very strong and it isnt easy to reposition and slide them into place nicely.  Thats why I prefer to use a glue stick which has an open time and lets you slide them around.
Chuck
Speaking of the friezes; should they be printed by ink jet or laser printer?
Any special paper weight or finish?
Thanks,
Gary
Current Build - Rainbow 1934
Prior Builds:  Lucia A. Simpson (Great Lakes Schooner 1875)
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
I use either regular copy paper with my ink jet or when I want to go really thin so you cant see the paper at all I use tissue paper.
Chuck
