Hello guys and many thanks for warm words!
It's time for update. Have prepared my Unimat to turn and mill the spindle for capstan. The images show the proces.
Have also turned the stantions, as they served also to hold the pump handle, I will complette the pumps as next.
Alex
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
Hi Greg and thanks!
Alex
Hello and thanks marsalv for warm words!
not much to show, only a little update: have worked on chain pump handles, so there the result. The images show main steps from alignment to installing. The axle is from 1mm brass rod, the crank handles from 0,8mm rod, all soldered together.
Alex
beautiful gallow- and chainpump Arrangement Alex,
I love the warm wooden tones and the sharp-chissels work...
Nils
Current builds
-Lightship Elbe 1
Completed
I think "Wow" says it all.  Are you using miniature hardware or simulating it?   I'm seeing nuts/bolts that just add to the detail.
Many thanks for compliments!
Mark, not sure if I have right understand the question... The bolts on wood parts are simulated, on brass parts they work as nails and really holds things...
Alex
Edited by Alex M
Thanks Alex.  You answered my question perfectly.
Hello,
the work continues with the gratings and coamings of the quarter deck, and ladder way to gun deck. In this case the gratings should look like "real" and have proper thickness and shape. Follow images show the process. First the upper edge of the block was shaped on this jig:
then cuts are done on tablesaw:
then strips are glued and the whole was sanded again in the jig:
Coamings are build around gratings, ladder way and coaming added:
All is dry fitted now.
Alex
Perfect, Alex!!!!!!!!!!
Many thanks!!!
Alex
Every once in awhile I begin to stumble during my builds but then I open up a log such as this and  see what can be accomplished ......absolutely marvelous!
JP
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel), Le Renommee (Euromodel)... on hold
Current WIP: Berlin by Corel
On Shelf:  HMS Bounty (Billings),
Very clean and precise work Alex, I am enjoying watching your progress.
Michael
Thank you for warm words!
Greg, no, not rubbing :D that were a task!
"making gratings, day one: rubbing
making gratings, day two: still rubbing"... :D :D :D
I have trimmed the bottom on the circular saw, is much faster...
Alex
Hello,
next update: the lower capstan. I cut a notch in to inner edge of whelps and then filed the edge to pass them to the barrel. The images show the process explanably I hope...
The "metal" is black paper :)
Regards
Alex
Bravo, Alex! Too bad the bearing detail will be hidden soon.... Don't forget a good dose of grease.
Many thanks! Druxey, I will leave a part of quarterdeck unplanked, and the bearing is visible through gun port... :)
Alex
