Hey Greg,
I have switched to doing the port sill mortices after the frames have been raised to see if I can do them any better than before. Seems to be a bit faster but no more accurate than I got before.
ben
Thanks for all the likes and comments.
Druxey - the counter timbers were from the original framing, they got knocked off during the house move 18 months ago. I will be making brand new ones but I had those old ones out to look at the shape.
ben
So the final section of eight frames has been made and installed between F and J stations.  I need to pull the hull off the build board to do the rough fairing around this new section.
Only 5 months ago since I started rebuilding the hull and it is now closed up, I had managed to save 37 frames from the original build, and I had to remake 43 frames new.
All of the new framing has a set of floor fillers missing every eight frames, and every filler is only glued to the aft or fore frame depending, so as to allow for wood movement - I don't want to get into the same issues as last time.
The workshop is undergoing a full cleaning and switch around for other work while summer is here and I have no control over the humidity. Modeling will begin again in the fall.
see you later in the year
ben
She's loooking great again! Hope all goes well with the new framing.
I know I shouldn't say this but I can't wait for the fall. Enjoy your summer!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Nice work Ben, hopefully the new gluing arrangement of the frames will prevent further issues.  I like the vast expanses of the workshop too :)  Lucky you!
cheers
Pat
Nice progress, Ben.  I'm sorry the humidity there is that high (and even in your basement!).  I've spent some time in Saratoga (I got married there), and am always surprised by the warm summers.  Somehow I think that if I just leave Oklahoma, the weather will be cool.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
  • 5 months later...
Hi,
So work on Pegasus we be starting again now I have humidity back to normal control, and summer projects put back to bed.
Old counter framing was broken on last house move so it has to be remade.
First order of business was to make a jig to attach to my gantry for the correct alignment and position of new side counter timbers, made out of some poplar and sized so top corners are the correct height from the keel to toptimber level, and width to correspond for correct gap 12'3" ( 3 1/16" full size ).
New side counter timbers were shaped out of 15" thick stock as per TFFM, glued into correct position on wing transom, and pinned through with 20ga copper wire / 5 min epoxy for strength.
Distance between side counter timbers at the upper counter knuckle was checked as well, pretty confident these are in the correct place.
Now to start on the filling timbers and QB light port.
ben
Great to see you back at work.  Getting those counter frames correct was one of the more difficult parts of the hull construction.
Toni
Member IPMS
                           Utrecht-1742
Hi Ben,
Welcome back and I'm both glad to see your work resume and the model surviving the summer!
Rusty
Here is what the framing in this area should look like according to the DOF plan of the Cygnet ( only swan DOF available from NMM ). I have machined some 8 inch stock down and have installed  frame backers along the toptimber line to support the new framing on both sides.
ben
