Thanks Ragove and Sam,
Sam - the hinges and stays came from MACK products (http://www.mackproductsrc.com) ; the screws are from Jim Morris company (https://jimorrisco.com).
super looking hatch Grant......do the inner guides fold away from the wiring?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Popeye,
Good pick-up. Yes, it's a tight squeeze in there. I had to re-locate the position of the receiver on the port side so that the hatch stay cleared it as it went down. Starboard side is okay, but still tight.
Hi Grant:
Late to the party here - this is some really incredible and exacting work - the metal work is especially impressive to me!
hamilton
Thanks Hamilton and welcome to the build - never too late for this party!
Another minor update of sorts. I had to re-visit the installation of the Engine Hatches as the hinge mounting failed. The hinges were initially epoxied to the hatches and then attached to the hatch frame with attachment tape (a type of double sided tape). The tape gave way, so I had to reconsider the whole setup. In the end, I made two shims from some scrap 3/64” thick Red-heart and epoxied these to the outboard side of the hinge flap. The shims were then epoxied to the hatch frame and held in place with map pins while the glue set. Once the pins were removed, I filled the holes with a few brass nails. Of course, the shims added just enough width to the hatch assemblies to prevent them from closing properly, so I then had to sand down the mating faces until the hatch would open and close properly. The photo below shows the completed “fix”, although touch up painting is still required.
I was then able to drill the holes for the 000-120 screws, which were then individually epoxied in place…..all 130 of them.  The heads of the screws were also aligned to the long axis of the trim piece, so that fore/aft trim pieces had screw heads aligned fore/aft, and athwartships trim pieces had screw heads aligned athwartships. It’s a little hard to see in the photo, but trust me…they are aligned!
And here’s an overall shot for perspective:
I wouldn't doubt it for a minute Grant :D.
:cheers:  Danny
Cheers, Danny
sweet look'in boat Grant :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks for all the kind comments and likes folks.
It seems a long time since the last update, but progress has been steady with all of the final fittings. I re-made a number of the fittings: The Exhaust, Gas Cap, Rear Flag Pole Base, and Hatch Cover Handles. With all of these, the castings were useable, but the time and effort to clean up the flash and then polish and potentially re-plate them meant that it was easier to re-make them. All were made from brass and chrome plated on completion. I added some knurling to the lid of the Gas Cap just for some extra interest (and because I hadn’t used the knurling tool on my lathe yet;)).
The Fwd and Aft Flagpoles were turned on the lathe from walnut stock, after first drilling them to receive lighting wires and/or brass locator pins. Another fairly straight forward exercise that posed no particular problems. Both the flagpoles have been made removable to provide some protection during transit to and from the lake.
I had ordered some replacement cloth flags from BECC but was a little disappointed in the product when they arrived – they are only printed on one side. So I used the kit provided flags instead and the “client” is happy with these.
Once the final soldering of the lighting wires was completed and tested, it was time to present the completed boat to the “client” for provisional acceptance. She was delighted with the final product. All that remains now is sea trials prior to final acceptance. Given that a successful float test has already been completed in the domestic testing facility, sea trials may need to wait until the weather warms up a bit as the manual recovery system says he doesn’t wasn’t to go swimming just yet! :P
With that, I’m calling DONE! :):):):dancetl6::dancetl6::dancetl6:
Here are a few glam shots of the final product.
Absolutely wonderful Grant, you can feel really chuffed about the final product :). Are you going to enter her in the Canberra Model Show this year? I'm tipping "Best in Show" ;).
:cheers:  Danny
Cheers, Danny
Thanks very much Danny. Hadn't thought about the show. Hmmmmmmmm........ maybe..........
Beautiful work Grant.  Hope you show some photos of the 'sea trials'
Cheers
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
 Sweet, Grant.  She's a stunning model and yes.. she should be entered in a show.   I hope the sea trials go well with no problems.
Thanks very much Slog, Bob, Don, Ken, Sjors and Mark, and all the "likes". I hope to take a short video when we do eventually get to sea trials.
Hi Grant,
Simply stunning mate.
Dan is right, take her to the Canberra show and recieve and accept the plaudits owed to you.
She really is a work of art.
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Hey Mobbsie - nice to see you back here my friend, and thanks for the kind comments.
'bout time we saw some more sawdust from you ain't it? 😉
Congrats Grant,
to your elegant runabout beauty, a lovely boat...
nils
Current builds
-Lightship Elbe 1
Completed
