Everything posted by mtaylor
Uh-oh... a new reality TV show... Pimp my Carronades!!! They do look super nice, Daniel. Congratulations.
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
Wonderful work, Nenad. For not having any patience, you did fantastic.- 4,152 replies
- cutty sark
- tehnodidakta
Metal - brass or Ali - turnbuckles
mtaylor replied to Tallshiptragic's topic in Metal Work, Soldering and Metal Fittings
Anton, Have you considered just using brass rod and tubing and making some (without the threads)? They would be none functional, of course. -
Now that is a find looking carronade. The pivot would have a slide on it as I recall. The advantage of the piviot is field of fire. So this is secondary armament then?
Smoothing sailing all the way, Popeye. She's coming together very well.
- 956 replies
- andrea gail
- trawler
My sense is that Steve is right about a mix of guns. The privateers created a market for cannon of all shapes and sizes. As for your cannon questions... You might try asking it here: http://modelshipworld.com/index.php/forum/15-discussion-for-a-ships-deck-furniture-guns-boats-and-other-fittings/ I'm not sure. Are those actual British cannon? or reproductions? Any markings on the trunnions or casabel area?
Matt, Measure the bore of the cannon at the fort. That will tell the size... 4 pdr = 3.0" 6 pdr = 3.4 9 pdr = 4" 12 pdr = 4.4" 18 pdr = 5.0" 24 pdr = 5.5" 32 pdr = 6.1"
Keith, Is there a gap? If so, save the sawdust and make a slurry of 50/50 white (not PVA) school glue and water and the sawdust. Pack this into the gap and when it drys, sand. Repeat as necessary. If the gap isn't very big, brush some of that 50/50 mix into the gap and sand while wet. The sawdust will stick to the glue and the gap should disappear. However, repeat as needed.
]Andy, Let me see if I can help.... See the attached file....(not to scale). I've not built this vessel so there is somewhat of a guess here.... If I look at the other logs, the wales (they stand proud of the planking) seem to be single strips. So I'm assuming this is the first three strakes of planking. What I've done is overdrawn in red the way the wales (planks) should sit, I believe. 1) Don't worry about the step on the outside... that will disappear when you sand. 2) The inside of the plank should sit on the bulkhead with out any space (not always achievable, but we all try anyway). 3) The green arrows show where you need to bevel the planks Not much there. 4) IF a gap opens up when sanding the exterior, save the sawdust, mix sawdust with a 50/50 solution of white glue (not PVA) and water into a slurry. Fill the gap and when dry, continue sanding. Repeat as needed. There's two ways to do this, sand and bevel what's against the bulkhead or sand and bevel the plank such that it sits flush next to the first one (green arrow area). I think it's easier to lay the plank on the bulkhead and bevel the edges to fit the previously laid plank. There's 3 logs you probably should look at... http://modelshipworld.com/index.php/topic/6794-pride-of-baltimore-ii-by-blue-pilot-model-shipways-scale-164/?hl=Baltimore http://modelshipworld.com/index.php/topic/6631-pride-of-baltimore-2-by-phebe-ms-scale-164/?hl=Baltimore http://modelshipworld.com/index.php/topic/1025-pride-of-baltimore-ii-by-jcoby-model-shipways-scale-164/?hl=Baltimore And also this (there's some good tutorials in there): http://modelshipworldforum.com/ship-model-framing-and-planking-articles.php I'm attaching the cross-section from my current build. If you'll notice the inner and outer are roughly parallel but not completely as sanding the exterior changes that shape. The edges where they touch the next plank are not 90 degrees from the inside or outside of the plank. I hope this helps a bit.....
Popeye, You should be pleased. Very nicely done... I love the map! I guess you'll have tell the Admiral to keep pushing you....
- 956 replies
- andrea gail
- trawler
Beautiful work, Augie. Coming along nicely. Don't you know that when it gets hot, some of us get to stay in the air conditioning...and.... SHOP TIME!!!!!!!!
- 2,191 replies
- confederacy
- Model Shipways
Thanks for the likes and the comments. Gianpiero, You are quite right. I haven't sanded nor shaped the ebony strip and the thick strip above it (in the picture). This will be taken care of next as I want to have the planking at the gunports done and finish applied to protect them on both sides first. Thanks for being another set of eyes... Edit: I've studied it again on the ship. If I can't fix it, I'll rip it off and re-do it but right now, it looks fixable since it's still rough.
Excellent work, Popeye. I guess a little down time just makes the next time in the shop better.
- 956 replies
- andrea gail
- trawler
