I know this subject has been covered elsewhere, but I was wondering about a specific comparison between the Proxxon DSH/E scroll saw and the Makita SJ401....
I'm in the market for a scroll saw and was looking for something in the $200 range...but then I came into a windfall and am thinking I can rationalise the Proxxon, which I can get for around $400....if there's no significant difference between the Makita and the Proxxon, then I'll save my money but from what I've read about Proxxon products in general the extra expense might be worth it....any advice would be appreciated! Thanks in advance
hamilton
Hamilton,
I looked at Amazon and found the Proxxon was a little higher rated in reviews than the Makita. However, it was based on very few reviews as well.
Try to find local hardware stores carrying them to compare.
Also, check out this website for more info.
http://scrollsawreviews.com/
Don't know if it will help but at least something more to go on.
Respectfully
Thanks Per:
I read through these reviews and they are quite helpful - don't see the Makita there, though I have read some negative reviews....thanks again!
hamilton
Hamilton.
I have a total of 10 different Proxxon Tools including one of their Scroll Saws. All have a small footprint and are reliable and accurate. You won't go wrong if you buy one of these. I also ave about 8 different Makita tools in my 'big shed' - not the scroll saw though. Can't fault any of them either. If it were me, I would probably go the Proxxon. It is a very quiet saw.
Edited by hornet
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
Thanks Hornet - definitely the way I'm leaning after reading up more.....
hamilton
Go to Home Depot or Lowes and check out the saws available there.  Most of the scroll saws sold under the major trade names are all made in China and are more or less the same machine.  Another low cost alternative is the older Dremel scroll saws.  They show up on eBay all the time.  I picked one up for $15 and am pretty happy with it.  Ebay is a good place to look for used saws in general.  There are usually several available ranging from really poor quaility ones to high end machines.
My advice and comments are always worth what you paid for them.
The issues is that I want to use a Home Depot gift card for the purchase, but Home Depot Canada only carries the Makita and Proxxon saws....The exchange rate being what it is, I would rather buy in Canada at the moment....long and short, I think I'm going to go for the Proxxon. It's a very exciting time....Happy holidays to all
hamilton
hamilton
FYI, I ordered some Proxxon tools through Home Depot online, but they cancelled the order - no reason given, but I suspect their prices haven't been revised since before the Canada/US exchange rate made the big shift last year.    Check Proxxon's site - they have sale now for many of their items, including the scroll saw
http://shop.prox-tech.com/c/bench-top-units-and-related-accessories_scroll-saw-ds-115-e  $US153.
Bruce
Bruce
Stay Sharp - Stay Safe
Judgement comes from experience:  experience comes from poor judgement.
  • USS Constitution: Scratch build solid hull 1:96 scale
Hi Bruce:
That's weird! Did you call their customer service? How long ago was this? I imagine it must have been pretty disappointing....The saw I want is the DSH/E - a larger saw than the one in the link with a tilting table for mitre cuts....This one seems to have pretty universally good reviews....I'm going to take my chances with Home Depot, and we'll see how it goes - can't say I'm too encouraged by your story!
hamilton
hamilton
I believe that HD will order other brands for you, if you ask.  I've heard good things about DeWalts; look here:
http://www.spiralsbysteve.com/shells.php
As I recall, the 'Rolls-Royce' of scrollsaws is a Hegner.  Have look at them, and see if you can find a used one.
I want a compact saw that will cut bulkheads/ keels (from ply, the thickest I expect to use about 5 mm) Also capable of ripping 5mm hardwoods into 1 mm strips for planking. I've read all the reviews. Size and price is an important issue, Proxxon and Dremel seem to be favoured, but I'm no nearer making a choice. Please help, Bob.
If you want a saw for ripping hardwoods a scroll saw may not be your best choice.  A small bandsaw would do as well for cutting out bulkheads and be a much better choice for ripping lumber into strips.
My first cheap scroll saw was a Delta. It shook so hard and broke so many blades, I called it "The Delta Saw of Death."  Since then , I picked up a used  Hegner Scroll Saw, from Switzerland, or Germany, or somewhere mountainous and cold, I forget. It is very expensive, especially if new, but it was used a lot by jewelers, and it is smooth and almost vibration free. Roman Barzana, the Tampa-based discoverer of Loquat Wood [snap! :)  ], turned me on to the bright-orange Hegner saws.
Edited by uss frolick
Hegner (Swiss, I believe) are the Rolls-Royce of scroll saws, and commensurately expensive. Frolick is a fortunate fellow to own one. Almost as good, but much less expensive, is the DeWalt 778. I've used this saw for 15 years. It works beautifully and vibration-free.
Edited by druxey
I concur with grsjax.  Sounds like a small bandsaw would be a much better all-around choice.  My Excalibur does a great job on curves, but I wouldn't use it for milling lumber.  A small bandsaw would do both jobs for you.
My plan is for a new Excalibur scroll saw, next. No more 'cheap' scroll saws for me. They have only brought me aggravation and very low quality work.
They're loud, they shake, and cannot make accurate cuts. I am ready to throw the el-cheapo scroll saw I own in a dumpster or give it to the scrap man. I'm better off cutting by hand rather than using this cheap, under-performing saw.
Hegner is selling in US.
Vibration free, it can cut  as thin a paper layer and it very easy to cut in straight line.
It can cut as thick as 1''... and at 90 degrees.
Scroll saw blades are very effective also and are offered by many companies.
Gaetan
How easy is it to change the blade on the Hegner saw? I watched a YouTube video for the Excalibur saw, and really liked the fact that the saw frame is hinged, so it raises to change the blade quickly. In the video, the owner has a cup of coffee sitting on the cutting table while the saw is running full speed. There is no vibration whatsoever showing on the cup of coffee.  :rolleyes:
Craig
I bought the Dewalt that people recommend off of someone on Craigslist, basically brand new, stand, light and extra blades, for less than half of what it was retail.  I saw a lot of scroll saws on Craigslist when I was looking - I think lots of dads out there buy them to do a project with their kids, then have no other use for them.
Hi Craig,
Excalibur and Hegner are 2 good  scroll saw. Which one is the best I do not know. There are some video on U-Tube showing  how to change a blade. They are not all using  the last version of the saw.
Depending how you do it, the blade can be change in less than 30 seconds.
I use mainly 2 blades 1 for thin and 1 for thick material. Each blade has a top and bottom holder to fix in the saw.
I found a used Henger MultiMax 18 v, variable speed 18" with stand on ebay.
But when I saw the asking price 1000 dollars I wondered, are they as good as the money claims?
Respectfully
I think a lot of people who buy those expensive saws are using them professionally and making a living with them.  No one appreciates quality tools like me, but for our purposes, and how much we'll actually use them, I myself can't justify spending $1,000 - $1500 plus, on one, -- --  at least not yet!  :P
GEORGE
Hi to all.
Karl :10_1_10:
Hamilton,
     You mentioned Home Depot. They carry the Dewalt 788 20in. saw. Just under 500.00.  But they also carry the 20in. Delta saw. For a little more then 100.00 less. If you delve into a little more research you find that Dewalt and Delta scroll saws are made from the same manufacturer.
   So for me I went with the Delta. A damn good machine. My buddy has the Dewalt. Performance to both of us was the same. We could not tell the difference. If there is, it's not much. If you take a close look they have a lot of similarities. I think Delta is a Oakland Raiders fan so they go with silver n black. :D
good luck
mario
Thank You all...
Mario
:piratetongueor4:  :piratetongueor4:
"Each of us is a mixture of some good and some not so good qualities. In considering one's fellow man it's important to remember the good things ... We should refrain from making judgments just because a fella happens to be a dirty, rotten SOB(biscuit) ;) "
My Builds....
BETTEAU WAR OF 1812     BOUNTY LAUNCH(bashed)    CHESAPEAKE BAY FLATTIE
THE SEA of GALILEE BOAT   VICTORIAN STEAM LAUNCH(bashed)    HOWARD CHAPELLE's CRABBING SKIFF
LADY KATHRINE 1812 SCHOONER
By the way, I have my cheapo Ryobi placed on a dense 1" foam mat to reduce vibration.  Also, it occurred to me that waxing the blade from time to time might help, because It certainly does ease cutting with handsaws and planes.   But most of the time, the scroll saw sits on a shelf unless I need to cut from inside a hole.  I always go to my 12" or 14" bandsaw first.
I understand that one may prefer one tool over another for reasonable reasons, but really, a 12" bandsaw is a much better buy in my opinion.  As for the occasional internal hole cut, just use a jeweler's or coping saw.
Edited by Bob Blarney
So would it be better to invest in a small bandsaw? From what Bob just said it seems that apart from inside cuts the bandsaw does the same work....? But what is the advantage of the band saw over scroll saw where they overlap in utility?
hamilton
Hi Hamilton, I have both a Proxxon Band Saw and Scroll saw.
Both tools are very nice but I have used my scroll saw far more than the band saw.
I suppose it depends  how much work you are likely to do and of what type. In my model projects the scroll saw has proven more useful, particularly in relation to cutting the frames for my1:64 Pegasus  Pinnace and Longboat; The Band saw  simply couldn't get around the  small and intricate curves, and the much finer scroll saw blade was more suited to the task.
Cheers,
B.E.
