Beautiful workmanship on the deck planking Danny.
Michael
Thanks again Michael and E&T.
The Treenailing is all finished as far as the decks are concerned. I've filed all the "nails" down with a Riffler File and sanded both decks with 600 grit paper. They have received their first coat of Minwax Wipe-on Poly :
Next will come the Timberheads and Swivel Gun Mounts, along with the Caprails and Bulwark Planking. These will add a much more "finished" look to the upper hull.
:cheers:  Danny
Cheers, Danny
The planking really does look sharp!
Michael
Hi Danny
I just love that model of yours, all the high skill work is presented by non hiding the fabulous wood juctions and fitting out work from beginning on...
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks for looking in, and the kind words John, Michael, Grant, Joe, Nils, Randy, Jeff, Gerty, Ron and Ben - much appreciated :) .
Bulwark Spirketting
I've fitted all the Bulwark Spirketting that I intend to do. The Port side is completely covered, and I've fitted half of them to the Starboard side Quarterdeck to cover an error I made very early in the build - about eight of the frame Toptimbers were a couple of millimetres short. I didn't discover this until WELL after the time had passed to correct them :( .
The piece above the Cathead was rather interesting to make :) :
:cheers:  Danny
Cheers, Danny
Beautiful work, Danny!  I doubt anyone had noticed the couple of millimeters too short you mentioned!  That work around the cathead is amazing!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Thank you Brian and Wayne, and all those who hit the "Like" Button :) .
The majority of the hull and deck planking is now completed. It was a lot of fun, and I got better at it as I went, but it was also very tedious work at times and I'm glad that stage is over with. Now come the more "interesting" parts of the build :D .
Gun Rigging Redo
Before going any further I figured it was about time I re-did the Rigging on the four guns in the waist that are completely visible. You may recall that I mentioned earlier that I wasn't 100% satisfied with the ropes that I'd used at the time. Now that I have the excellent rigging line from Chuck (Syren Ship Models) I'm going ahead with it.
I won't attempt to do the four guns under the forecastle and quarterdeck, as the rigging is barely visible and it would be extremely difficult to do them anyway. What can be seen of the rigging on these guns is quite acceptable to me.
I started by brushing Isopropyl Alcohol on the glue holding the trucks to the deck, and also the eyebolts for the breeching line. All pieces came off the ship easily. Then I did the same for the seizings on both breeching lines and side tackles. I wanted one piece of each intact to use for measurements. Again, everything came apart easily :
:cheers:  Danny
Cheers, Danny
its so much fun watching your build Danny :)
not only showing use amazing craftmanship but teaching us newbs the correct terminology
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
did the deck clean up OK,  or did you need to refinish it?  cannons are very nicely done.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks again John, Adrieke, Popeye and Ron.
Popeye, the deck cleaned up without any problems. The Isopropyl doesn't soften the Minwax finish. The scuff marks you can see is where I'd previously scraped off the Minwax to get good adhesion - the guns will be glued over those spots again.
Ron, I used a needle file to round the blocks.
:cheers:  Danny
Cheers, Danny
I've re-made all the rigging for the four guns, and re-fitted the first one. I'll have to fit the side tackles in a couple of days, as I'm about to head off to work.
The quality of Chuck's line is very apparent in the pics, especially when compared to the line I'd used previously (lower pic is the old one - obviously :D ) :
Even the 0.2mm line for the side tackles is just as good. Great definition, not even a hint of "fluffies", and very easy to work with :) :
I'll definitely be getting the rest of my line from Chuck :) .
:cheers:  Danny
Cheers, Danny
Those are some very neat seizings on the gun tackles Danny.  I also very much like the colour of the rope in one of the photos; is that the actual colour of the rope made by Chuck and a few of the other photos justshowing them a little washed out?  If so, that would be the most realistic rendering of manilla rope I have seen  (sisal would have been to stiff for this application).
cheers
Pat
Edited by BANYAN
Lovely work, Danny.
Thank you Frank, John, Pat, Ben and Mark :) .
Pat, the fourth pic in my previous post is as close to the "real" colour of Chuck's rope as I can get it. The others ARE a little paler due to different lighting angles.
I've finished Re-Rigging all the guns. To hold the rope coils in place I used a Fabric Setting gel used by seamstresses etc to glue down hems before sewing them. I can't vouch for the longevity of the product for this application, as it washes out with water. I may have to use some dilute PVA at a later stage if it looks like the coils will come undone.
The coils are still damp in these pics, and will take a more natural colour when the setting gel dries.
:cheers:  Danny
Cheers, Danny
Those coils certainly look very lifelike at the moment, Danny.  Maybe if the fabric setting gel does leach out of them they'll be 'set' if or when it happens.
John
Danny,
The coils look great.  The only other way, besides PVA, I can think of is fabric glue.  The stuff is supposed to be invisible and water proof or at least resistant.  I used it on my Constellation for the ratlines and then everything else that was "rope".  Seems to do the job.
