HMS Bellona by yvesvidal - CAF Model - 1:48
While planks are drying, I started working on the pleasant stuff of Session #2: Some parts of the gun deck and the rear capstan.
The assembly above will be glued to the deck and will provide a sturdy pivot/bearing for the main axle.
The capstan will be rotating. The lower part of it is fixed and is used as pivot for the axle. The upper part and the 10 feet long sticks are rotating and will be coupled with the capstan on the upper deck. It probably won't be easy to see the lower part rotate, but I will know that it is there.
The bars are made of bamboo sticks, for Smores (Publix stores). Each bar is cut at the right length (real bars were 10 feet long) and inserted into the upper part of the drumhead (see pictures below).
The upper part of the capstan rotates smoothly and is a pleasure to operate.
The deck is planked with maple planks of 0.4 mm thick, 8 mm wide (easy to cut with a pair of scissors) and stained with old oak Minwax varnish (very smelly).
Yves
Edited by yvesvidal
Link to comment
Share on other sites
That is one huge and impressive hull.  I hope the rest of the planking goes as well.   What method are you using on bending the cherry planks?
Link to comment
5 hours ago, yvesvidal said:
I completed the wales on the port side. I still have to fix and paint the gun ports on that side, as well as install the upper wale. That one is easy (1.5 mm basswood) compared with the main wales (3 mm x 8 mm cherry wood).
For a change of pace and more self inflicted torture, I decided to start planking that monstrous hull. Each plank is made of 3 mm thick by 8 mm wide poplar/lime wood and is very stiff. I split the hull in three belts, following the recommendations of experts (such as Chuck) and started planking the garboards and the first planks to the keel.
So far, I have installed 4 planks on each side. About 24 planks should go under the wales, on each side.
This is still Session #2 and it is by far the biggest session, with the hull planking, wales, upper hull planking, channels, gun deck and 28 big caliber guns to assemble, not counting two capstans, bitts and numerous grates.
Session #2 also includes the copper tiling of the hull. I have not decided if I will tile the ship and it will depend of the appearance of the hull. Honestly, I have never planked such a big and curvy hull and each plank presents its amount of challenges.
I may be stuck for months on Session #2 and the sanding of that behemoth will require an electric sander, preceeded by a wood scraper.
I have secured all five sessions of the kit (you never know what may happen between the USA and China) and I will be presenting the remaining three sessions at a later time. Crazy stuff for sure and tons of parts to assemble for a life time.
Yves
Yves:  Is Session 5 now available? CAF models website still has it not available. If its available how do you purchase it?
Mike Draper
Mike Draper
Whitehorse, Yukon
Canada
Member, Nautical Research Guild
Link to comment
Mike Draper
ask Tom @cafmodel
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Mike, the cherry wood planks were bent after dipping them in alcohol. Also, for the bow, I sliced them in two parts (a little bit like a two pointed fork) as it helps tremendously the curvature of the wood. Once glued, filled and painted, it is not really visible. All the wales planking is glued with epoxy slow curing two components glue. A must in this case.
Yves
Link to comment
Mike Draper
Mike, yes Session #5 is available and I ordered it directly from CAF Model. With the shipping and handling charge, I think it was close or slightly above $300 for it. Session #5 has tons of interesting things, all 74 brass guns, decals for the hull, and lots of plastic and 3D printed parts. At first, I was disappointed by the presence of plastic parts, but they are very detailed and having them made of wood or cast metal would have been cost prohibitive.
Yves
Link to comment
Yves
Yves; Thanks for the reply and detailing what is in Session 5. When I received session 2 I was surprised by the size of the gun carriages. The gun must be massive! I didnt appreciate how big this kit is. Having the spar deck 12 inches wide at the widest spot was mind boggling. Judging from your post the stern ornamentation and figurehead on the bow is also plastic? Keep up the great build log!
Mike Draper
Mike Draper
Whitehorse, Yukon
Canada
Link to comment
50 minutes ago, PierreM said:
Bonjour Yves
De ce qui précède j’ai cru comprendre que le kit était subdivisé en 5 parties achetées séparément. Est bien cela?
Bravo pour ce qui est déjà achevé.
Pierre, yes the kit is made up of 5 sessions. In my humble opinion, it is not possible to assemble Session #1 without Session #2 and ideally Session #3.
I have provided the dimensions between the top of the futtocks for each bulkhead and that is paramount for the success of this kit.
Session #4 is, for the first time, offering a gorgeous scale 1:1 blueprint (top and side) of the model, with all its details.
Yves
Link to comment
Yves
Yves: That is good news about the 1:1 blueprint of the model being in session #4. That will be a useful to have especially with the size and complexity of the hull construction. I noticed that was missing in session #1 and 2 when I opened up and inspected what I have received.
MIKE
Mike Draper
Whitehorse, Yukon
Canada
Link to comment
SESSION #5
This is the richest session and heaviest box:
I am planning to follow the sessions independently. Every time I start a new session, I will describe the contents of the box, in greater details.
Yves
Link to comment
Some progress on the planking. I almost finished one quadrant of the ship:
Most of the planks were placed in this crude jig: A little dipping in pure alcohol and then placed between the nails -
Four planks can fit nicely, while drying in shape. When released, they rebound a little bit, but are more willing to comply to the difficult shape of that hull.
Now, I just have to do the other side, with more than 24 planks....
A first pass of "scraper" and some rough sanding took place. I am still debating if I will paint the hull (anti-worms white) or copper plate it. I would love to do the copper plating but need to learn about that process. Non-covered section of the hull may require a second planking made with 0.4 mm thick maple planks, provided in the kit.
I still have plenty of time to think about it....
Yves
Link to comment
Second quadrant completed. Of course, lots of sanding remains to be done.... but the overall shapes are there:
I am leaning very strongly in favor of a coppered hull. Copper tiling has always been a fascination for me (the glittering of the metal...) and since Bellona was tiled later in its existence, it makes sense to try to do it. Besides my planking is far from being presentable as such and will require a second planking in the non-tiled sections (above the water line). I also suspect that the bow is going to be even more difficult to plank than the stern...
Therefore, I am learning about the tiling process by reading what the members of this forum have done on their models.
The deep blue is the one that matches the best, the English paint used on these period ships.
Inside the hull, I am brushing some acrylic resin on the wood, to seal it and increase the bonding strength of the planks to the bulkheads. There is an enormous amount of pressure and tensions taking place and I do not wish the planks to start coming out, in a few months or years. Planking has been done with Thick and Quick Titebond glue (or is it Quick and Thick?) and I trust them to a certain point. The only glue I trust fully is the two components epoxy, slow curing glue.
Before brushing the resin....
And after ! I noticed that the lime/poplar wood  provided by CAF Model was occasionally splitting. Soaking that wood into resin is probably a good insurance for the long term. Interestingly, no resin seeped through the hull....indicating that it is waterproof.
Just for fun, I could not resist trying the various gun deck pieces:
And the Upper deck and misen mast:
It is getting exciting....
Yves
Edited by yvesvidal
Link to comment
17 minutes ago, yvesvidal said:
they cannot even spell Bellona correctly
This is a shame given that this kit seems to be the flagship model for CAF, and the stand part of how the model is displayed when finished ... Hopefully @cafmodel will pick up on this and fix it for future releases :) It looks good and sturdy, though.
It's fascinating watching you work out all the steps required to construct this complex and large model. Thanks for sharing your progress with us all.
Link to comment
I just glued the rear gun deck section. The hull has been coated with resin and so the deck can be installed permanently:
The figures (AMATI 35 mm) may be a tad too small, although 35 mm is about right for 1/48th scale:
A goofy picture:
Yves
Link to comment
Wow substantial build Yves, excellent work as usual! I love the way you go big. Nothing wrong with that planking.
How is the house addition coming to house your models.
Tim Moore
Perfect is the enemy of good
In progress
IJN Pre-Dreadnought Battleship Mikasa, 1:200, Hobby Boss
On Deck
DH.9a Ninak, 1/32, Wingnut Wings
The Blue Sky Company, 1:48, Sierra West Models
Completed
Fiat 806 Grand Prix 1:12, Italeri; Fifie 1:32, Amati Victory Model; HMS Bounty 1:48, Artesania Latina; Endeavour 1:60; Corel; Miss Severn 1:8, Legend Model Boats; Calypso, Billing Boats; Carmen Fishing Trawler, A.L. ; Dallas Revenue Cutter, A.L., Bluenose, A.L.
Link to comment
 very nice
i have never seen a successful planking done like that
lovely work
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Looks great, Yves.   Is the whole hull double planked in the kit or "parts of it"?
Link to comment
 Mike,
Nothing is double planked. The hull is supposed to be copper tiled and that is probably where I am going. Above the water line, I am planning to use the maple planks of 0.4 mm thick (same width as the main limewood planks, 8 mm) and pretend to have a nicer planking arrangement.
We will see how it goes.
Yves
Link to comment
Ah... thanks for the info.  That sounds like a good plan on your part.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
