Hey Druxey,
At the moment I am just laying in store and I havent totally decided yet, as you know I have been working in CAD on my own plans of Indefatigable but they are still a long way from completion, Maybe a different Frigate before tackling the Indy.
Sorry Remco :P
ben
Thanks Guys,
Druxey - I'm going to spend some time completing fairing the inside of the hull, then align all the toptimbers and get them all to correct height, then remove all of the temp basswood spacers and install new pear ones, that's a good few weeks work for me as I spend a lot of time traveling for work these days, that's the plan anyway.
Ben
Splice the main brace, Ben.  That is an impressive milestone.
Congratulations on reaching such a significant milestone Ben. You must be feeling very pleased - your work is excellent!
Double rum rations all round :)
Congratulations Ben, this is a big milestone. You probably thought there would be no end to adding frames ;)
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Thanks for all the likes.
I thought I'd take practice run at the knee of the head, here is my first attempt, some of the joints are not as tight as I would like so another one will be made.
Ben
Bob is dead accurate with his statement....
Hi Ben,
I've just caught up with what you've been up to. Well done and congratulations on getting that last frame in.
Following Remco's advise/motto is never a bad thing either!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Ben,
really nice practice.
Regards Christian
I'm the newbie here, so all I can say is WOW. Your workmanship and perseverance is superb. My hat's off to you. Cheers! :cheers:
Ken
Started: MS Bounty Longboat,
Another addition to the wood stock pile, a couple of billets of nice white Holly stacked on top of my boxwood,
Holly is getting really difficult to obtain here in US, So I get whatever I can when the chances arise.
I may have some updates to show on Pegasus next week - Ive been working away a lot lately and the sanding
and fairing of the inside hull is taking quite a bit of time to get really good.
ben
Hey all,
Well the internal fairing is pretty much completed so I released the hull from the build board, so I can start external fairing and will also help to complete the internal as I can hold the hull in my lap and be able to access parts that the buildboard made difficult.
I see a lot of sanding in my future!
Ben
Looking good, Ben. I see you have included the fillings up to the floor heads. Nice.
Thanks Everyone for the likes.
Druxey - Yep the fillers were added at the same time as the square frames, I do see some small gaps here and there which will need to be filled.
Greg - the pencil method is what I used for internal fairing and it worked well so I will use it for doing the external.
Ben
