Thanks Ben and Sjors. Only two coats of paint and when viewed up close you can see the differences
in the coverage. Several more will be needed.
Well this is the start of Chapter 5, planking the hull below the wales.
Chuck describes how to plank the hull with no drop planks at the bow and no stealers at the stern.
This is something I have never been able to accomplish. The description is very detailed and I'm
hoping to duplicate it.
First a paper tick strip was to be made and divide it into 5/32” increments. To keep as many errors
out of this process as possible I made my tick strip from 5/32" graph paper printed on card stock
instead of using a ruler and  pencil and transferring the marks to card stock.
Next I positioned the strip along bulkheads “1” and “A” and marked the increments. There are a
total of 24 planks so there will be 4 "belts" of 7 planks each.
Chuck wrote;
"We will have to determine the exact width of each strake at each bulkhead.  To do this, the hull is
lined off with graphic art tape into the four belts first."
I had some yellow pinstripe tape so I used that to mark off the hull belts. After applying the tape and
tweaking to get a smooth even run I sent these pictures to Chuck.
His sharp eye caught some runs that weren't the best and sent this back which I used to adjust
the belts run.
Now I'm off to do the starboard side.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
It's really great to have Chuck chiming in.  He's got some eye for these things.  Frankly, I would not be able to see this myself.  No drops or stealers  ...  I'll be rooting for you Rusty!
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Rusty,
Nice pre-work for putting on a well thought through planking.
The Winchelsea has wonderful lines, and ship is beautiful built so far..
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks all for stopping by.
Yes Augie it's great to have access to Chuck and all his talents.
Thanks Nils.
Don't look too closely Sjors!
Hey Ben good catch. Only thing worse then my math is my typing so I was in trouble no matter what!  :D
Rusty
Ok...no math, no typing...just planking.  You'll be in fine shape. :)
Hi All,
Well in case you didn't notice I've been AWOL for a while now. August and the first week of September is really busy at work. 80 hours work weeks with no days off blah, blah blah. Boy that was no fun. I used to be able to do it no problem but now it kicks my butt. So it was work, sleep, dream of working on the Winnie and then back to work.  Once that was over  it was another week or so to catch up around the house with all the things that needed my attention.
So I've now looked at MSW and found 11 unread pages in the Kit Build Logs and 4 pages in the Scratch Build Logs. Not to mention, oops I just did, all the other topics!
So to all my friends out there I'm sorry I missed posting to your logs for the past 6 weeks and it may take another 6 weeks just to catch up.
Now that I've got my whining out of the way here is where I'm at.
I have not completed marking all of the bulkheads with the plank locations. That was over 1400 little pencil marks. I'm seeing little dashes in my sleep know.
I've now started on the planking and here you see my first attempt at spiling a plank. You can see the curve compared to a piece of strip wood.
Well I've now started the planking and will let you know how it goes.
Rusty
Once you get into a groove with this you will never go back to planking any other way!!!   Enjoy the process.  :)
Chuck:  Which method of planking are you referring.  Do you know which post number you talk about your method, within your build?  Thanks, Bill
Hey Rusty, welcome back and a very nice start - I am sure you will get into the 'groove' of it fairly quickly as Chuck suggests.  I will follow along with interest .
cheers
Pat
Hey Rusty, great to see you back at it. This is going to be a great planking job to follow.
Thanks to all for stopping by and all the likes,
Hi Chuck, I am enjoying it. It's a little different to cut out but they lay down sooooo nice! B)
Thanks Jason.
Hi Ben, It' s good old boxwood. I've got to stop by and see how you are doing on the Pegasus.
Hi Pat, Good to be back, We'll see what kinda groove I get into here! :huh:
Hi Grant. Time will tell.
Hi Bob, I hope so and I've got to catch up with you as well as everyone else too! :)
Rusty
Hi Joe, Good to hear from you!
Sjors, Look as close as you would like. Just watch out for splinters.
Some planks had been placed, trashed and broken but progress has been made. At the bow I have fit and glued
the first 7 rows which is the first belt. I am working my way to the stern and will finish up the entire belt before
I move onward.
Here is a demonstration picture of marking off the plank to be cut. The tape is placed on the hull and then using a
pencil you mark the edge of the plank where it meets the existing plank. Then I marked the bulkheads. At each
bulkhead I then mark the height that was already placed on the bulkhead. The tape is taken off and placed on the
wood to be cut out and using a French curve the top marks are connected giving you the shape of the plank. Because
the pencil lines are hard to see on the camera I traced over them with a sharpie so you can see them better.
I won't use this piece as my tracing was a little to inaccurate.
For a much better description follow check's link above!
Rusty
Some day I am going to have to take a course in "The French Curve".  I can never seem to get the right curves matched up.
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
The planking is looking great Rusty.
Michael
Floyd,
http://www.amazon.com/C-Thru-Ship-Curve-Set-6/dp/B000HEOHVC
and
http://www.draftingsteals.com/21270.html
There's piles of listings.. Google:  "ship's curves set".
Hi All,
When starting the planking I wondered about the waste, or maybe better put, the amount of wood needed
to plank the hull in this manner. I started with a 2" x 18" piece of wood and I was able to cut all the spilied
planks for both sides and still had wood left over. I was very pleased with this.
Now onto my impression of this style of planking a hull. In the words of my sweet granddaughter
.......OMG........ though time consuming it was soooooo much easier to lay the planks. No twisting and
bending and forcing them into place.
Here are pictures of both side rough sanded. Once the entire hull has been planked I will progressively
sand it down to 400 grit and then seal with wipe on poly.
On to the second belts!
Rusty
