BANYAN
SPECIAL CONTRIBUTOR
Everything posted by BANYAN
  1. Following along on this very interesting build. It is also great to see the various types of new/newer technologies being considered for this build. cheers Pat
  2. Denis, WRT hatch covers I would say it depends on how you wish to depict her. If you are fitting sails (at sea) then the hatch covers (canvas) would have been fitted. If in harbour, just arrived or ready to sail) you could go either way (canvas on or off), but if depicted as in port at anchor/alongside then the canvas would have been off in most circumstances with some of the hatch covers open for loading/unloading? I would also go with the flat bar handles as John has shown if you do not fit canvas sea coverings (to protect the cargo) More decisions sorry mate. cheers Pat
  3. Stunning work yet again Alexander, those look superb. cheers Pat
  4. If you are worried about the varnish reacting with the balloon try another forming method such as a sand filled bag. Get the sand bag into the shape you want, drape the sail over it and spray on the varnish. Just be sure to be using a colour fast fabric for the bag, or put a layer of glad/cling wrap over the bag between it and the sail to be sure. cheers Pat
  5. Congrats Elijah, one down and many more to build. As RC stated above, a major achievement in completing your first build, many lose patience or confidence in their skills. Good luck with Philadelphia. cheers Pat
  6. I am with John on that one denis; the only thing I think to really consider (which it appears you have) is that the colour combinations need to be high contrast so as to make them more easily visible on the sea surface. cheers pat
  7. Looks very good Russ; nice trimming work. Great decision on the wood grain, always pays to have the strength of the wood working for you. cheers Pat
  8. Mark, you have rebuilt so much of this model that you could have two ships That said, I very much like your attitude that near enough is not good enough; and it will pay dividends in the long run as you say. That deck planking is coming on very nicely. cheers Pat
  9. Believe in learning the hard way do you mate? - ouch they looked pretty good too which makes it worse cheers Pat
  10. very nice job on the boats Dave; they look terrific. The 3D printed parts look excellent also, glad to see you persisted. I am assuming the ironwork for the masts etc are also 3D printed? cheers Pat
  11. Great to see you back at the build table Denis; hopefully all is good now? cheers Pat
  12. very effective technique; many thanks for sharing it. A great explanation of the steps etc. cheers Pat
  13. Great progress greg; hopefully the book will not expose too much difference. You have certainly made some major improvements to the base kit. cheers Pat
  14. Hi folks, have not updated this build for awhile as I have been busy researching all the fitting necessary to be fixed to the bulwarks as once deck furniture is added there will be little or very restricted access to the bulwarks. I am currently determining the rigging/belaying plan to determine where cleats, eyebolts, belaying pin racks/rails and leads/blocks need to be fitted. I am also continuing to research the armaments: see following which has been resolved. cheers Pat
  15. Hi Denis - found you I was wondering why your trawler was mothballed An interesting build with very good progress. I have bolted my chair to the floor so I can't be pushed aside I think the purpose of the Like button, as used now, is to allow readers to acknowledge posts and a like means they like what you have said or done - which to me is a sensible implementation. cheers Pat
  16. Thanks for showing your process and build sequence for the frames Gaetan. It is very informative and shows how important it is to have a well thought through process in the mass production of frames. It seems you have found efficiencies in this process rather than manufacturing one frame at a time. cheers Pat
  17. Les, I recommend having another look at that diagram. Marquardt shows the overall pump and it is correct for an Elm Tree pump style. All pumps went all the way down to the bilges. What is shown below decks is the pump chamber/suction pipe (trunk). the bit above deck is the exposed bit seen on almost all drawing s of ship using this design. Sometimes they were on the upper/weather deck as for Endeavour, sometimes on the gun deck for multiple gun deck vessels, and sometimes a couple on one deck, and a couple on the other. What is different with Marquardt's depiction is the height of the trunk (raising pipe as he calls it) protruding above the deck. Whether the amount protruding that he shows is correct or not I cannot say, but the concept/style of pump is correct. Also note the scale of the drawing as the height would be a little more than perhaps perceived at first glance; but it is depicted as a shorter exposed trunk than normally seen for this style of pump. cheers Pat
  18. Thanks Per, just found this post of yours - a very handy link cheers Pat
  19. Nice job Dave; they look very good, and makes me wonder why I didn't consider yellow/ochre for the thwarts etc - looks good against the white. cheers Pat
  20. Great pictorial description of the process and jigs Michael. A masterclass in micro metal-smithing. cheers Pat
  21. I have workshop envy; any cures? That is a very organised way of working Gaetan; you obviously have a very well thought through process of construction. cheers Pat
  22. Late to the party Gaetan, but I hope I can find some standing room somewhere? I will enjoy this build; I have followed all your others so this will be a masterpiece with all that practice cheers Pat
