Echo cross-section by dvm27 - Finished
Our Echo cross-section is now complete. I have modeled her with the port side in frame and the starboard side completely fitted out. Finish is dilute sanding sealer. She is made of boxwood and holly. Dyed holly is used for the black portions. Conveniently, Admiralty Models sells both a framing package and a fitting out package so that you may choose your own style of display. The new fitting out package, milled by MSW vendor Crown Timberyard, includes sufficient boxwood and holly to finish the entire hull with plenty of extra for redo's. The price will be $275, postage additional. if you would like to reserve an Echo fitting out timbering package please send an email to me at dvm27@comcast.net.
Edited by dvm27
Link to comment
Share on other sites
Sweet, Greg. But why only one rum barrel? Seriously, though, your model is terrific.
Why, that's silly Druxey. My ship only carries one crew member (the Lieutenant). At the Admiralty prescribed ration of 1/2 gallon of rum/day in home waters I felt the one barrel was plenty. Plus, I had it left over from another build (the real reason it's there).
Beautiful Greg.  I cannot find a cross section plan for the aft end of the model.  Do you have one?
Maury
The cross-section was sliced from the Echo sheer plan from Admiralty Models. The same could be done for the aft section.
Thanks for the kind words Richard, Alan, Grant and Duff! By the way, the crew member is not part of the timbering package!
Link to comment
Greg,
Does the $275 price for the fitting out package also include the framing package?  Or is the $275 in addition to the $195 needed for the framing package?  Is the lumber for this basic sheet stock with the dimensional strips to be milled by the modeler?  Or does the lumber in these packages include the milled dimensional strips?
I'm trying to figure out what to do for my second build.  It's either something like this, or Chuck's Cheerful.
Thanks!
Erik
Link to comment
Semi-offtopic: am I banned in Google, or there are really no build logs for the fully framed Echo model (not cross section) based on Admirality Models plans?
Lines of the cross section look interesting, was curious how does the full model looks like :)
While we have sold many Echo plans I have not seen a finished model yet. I suspect the complete resource material available for our Swan set of plans makes this the more popular project. But Echo, with it's French influence, does have beautiful lines and would make a lovely model.
Link to comment
Greg,
Thanks!
Erik
Greg,
I'm interested in knowing this as well. I'm itching to do a cross section and this one has been highly recommended to me from a thread I started in another place on this site
Link to comment
The Echo cross-section consists of two parts. The first is the historicallly correct framing of a sixth rate ship. For many builders this is the end goal, and the cost of the timbering package is $195, plus postage. Others have requested an additional package to completely fit out their cross section, so we prepared a second timbering package which is much more extensive in terms of milled wood. The cost of this fitting out package is $275.
From my point of view, it seemed a bit academic to complete an accurately framed hull and then cover it up so I have taken the approach represented above. The starboard side of the hull is fitted out while the port side remains in frame. I believe this makes an interesting presentation.
I have also also completed a Swan class cross-section http://modelshipworld.com/index.php?/gallery/album/139-hmn-swan-class-sloop-pegasus-cross-section-by-greg-herbert/ which is fully fitted out port and starboard. It was simply framed using 1/4" plywood and the frame patterns sold by Admiralty Models. If you already have Swan plans and David's books you can lift any section of the ship and model it.
So many choices!
Link to comment
Very nice Greg, and I really like how it is attached directly attached to the base a real different approach(at least to me bolts through the keel and riding  wood
Drilling and tapping the keel and rising wood for 4-40 (or smaller, depending on the scale) threaded bolts gives a very secure way of mounting the ship to the building bord. It also allows many options for the final display.
Greg, the figure really sets off the scale perfectly.  Where did you find old naval figures at 1:48 or did you carve him yourself?
Maury
Those figures are done for me by Joe of Dynamic Dioramas http://www.dynamicdioramas.org/modelindex.html. His work is fabulous. Check it out!
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
