Le Gros Ventre by marsalv - FINISHED - 1:48 - POF
Superb work as always !
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • Santa Maria boat - Korabel (Ukraine) - 1:24
Link to comment
Share on other sites
Hi Marsalv, beautiful work! Can you tell me which cnc Milling machine you are Using?
JJ
Current Builds: HMS Winchelsea 1764 1:48 - 5th rate 32 gun frigate (on hold for now)
Link to comment
Very impressive work.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Be interesting to see what you will be able to do with the Mini CNC, will be following your use along with the rest of your build. I have been a little hesitant in purchasing one because of the cost and learning curve. The prices are comming down but I am getting older making the learning curve harder!
Cheers, Guy
The Learner
Current Member NRG,SMA
Current Build: HMS Triton 1:48 on line
Link to comment
To the learner - The basis is a wooden plate into which depressions are milled and holes for nails are drilled. A cotton pad (a make-up cotton pad that I borrowed from my wife) is glued to the plate prepared in this way. Push the cotton into the recess with the end of the brush nozzle. Glue any suitable cloth and push the material into the recess again. Finally, thread the nails with small heads through the cloth and cotton into the holes in the wooden board, glue and cut. Glue the ends of the fabric over the edges of the wooden board and you're done.
Inner bulkheads - continuation part two.
Link to comment
Beautiful work!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Your details are really adding to the beauty of this build.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
