37 minutes ago, Surgeonstone said:
It would  be cool if one could purchase a copy of the Geoff Hunt painting.
You're in luck! No affiliation, but Artmarine.co.uk sell limited edition prints as part of their Fighting Sail series for about £60, as well as prints of some alternative paintings by Robert Taylor and John Chancellor.  A search on eBay is currently coming up trumps too.
A very brief update before the weekend one.
The office furniture has been painted by a friend of mine, and here it is. The round table will not be included with Indy, but the other table will, along with a couple of chairs. Here you can see a couple of incarnations of the furniture, 3D-printed and painted with oils. My friend also added the navigation charts for some extra effect!
These items, including the round table are available already though. https://vanguardmodels.co.uk/product/cabin-furniture/
Ongoing:
Wow, I need a friend like that. It went from blue plastic to impeccably real. Where does one get 1/64th maps...
Regards,
Glenn
Current Build: HM Flirt
Those are truly amazing. Do you have any tutorials on how to even approach doing painting like that? And the maps...wow, very impressive. Is your friend accepting applications for new friends 😉?
Agreed on the maps, or maybe suggestions on paper and how to print them even.
Nope! This is why I farm this stuff out as he knows what he's doing, plus I'm still busy with woodwork 😆
Ongoing:
Ok, just an interim update.
I was going to leave this until weekend when the office was installed, but I may as well show the upper deck being fitted and prepped for further work. Indy will be supplied with deck planking material as standard. At the moment, this looks like it will be red alder, which is gorgeous. I have some here that I'll do a couple of stages showing how to present it, assuming the modeller will have a good idea already. Indefatigable isn't marketed at modellers who are novices or intermediate. This is an 'Advanced' level kit in VM's new 5-point kit categorisation. More on that when it's released. What you see here are the standard ply sections which are laser-engraved so you have something as a planking guide.
This is where checking the lay of the deck beams really does pay off. This deck is fitted in halves, unlike the main deck, simply as it's a more complex item. With everything test fitted and dry run several times, the deck beams have glue added to them and the deck is slotted into the outer bulkhead ears. Weights and clamps are then used to hold things down until dry. The 2 inch clamps are perfect for this, especially the cutouts where the front end clamps the joint and the clamp tail holds down the opposite side.
And then the other deck half is fitted in the same way.
There is a little more internal fairing to do, but this is easy enough. This is where the cabin walls will be installed and I need to make sure there's no bumps anywhere.
And while this seems drastic, these frames DO need to now be removed as the next build stages will incorporate engraved inner bulwarks which glue onto the the sides.
The forecastle bulkhead ears are now history too.
More at weekend when I have the painted furniture in hand.
Ongoing:
it just gets better
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
To make a chart for the table in my Sphinx,  I found an appropriate 18th century one on the Internet and then just reduced its size by photocopying several times until it was about 10mm wide.   It looks OK but I hope when I've finished it will be as good as the one produced by Jim's friend!
Nipper
Current build:  HMS Sphinx 1775 - 1/64 - Vanguard Models
On the drawing board:  Dutch brig "Irene" 1815 - 1/64 - based on HMS Cruiser - Caldercraft
Completed build:  HM Cutter Alert 1777 - 1/64 - Vanguard Models
This is my weekend update time as I'll be working flat out from this stage to get the upper deck work done. Getting the cabin built and fitted out seemed like a good time to post.
The first thing that's to be done is to fit the vertical face for the benching in rear of captain's office.
With that fitted, the parquet floor is added. This is supplied in card and it looks nicer than the maple version, and a cool contrast. Titebond is used to fit this. The remainder of the rudder housing boxing is then completed.
The bulkhead screens are supplied in two 0.6mm engraved laminates. Instead of using wood-curling white glue, 3M Spray Mount is used. The parts are lovely and glass flat.
The outer bulkhead screen is fitted with laser-engraved columns.
The inner bulkhead screen and the partition wall are temporarily fitted so that the engraved maple floor sections in that area can be trimmed to size. Once they are done, the floor sections are glued into place and the screen and partition removed until later.
This picture will give a good idea about the post design process that I am engaged in when building the production prototype. I will invariably find a small number of things which needed amending. This is either because it was missed during the initial cut build, or because something in the design was changed and a small number of affected areas may have missed an update. Here you see the cabin side wall and the changes made from the initial part. That includes shifting details by 2mm to align gun ports and also packing out the rear to cater to the lowered cabin shelf. Hey, at least we can show you how we do this as a tag-team!
I temporarily fit the cabin walls and the screens so that I can draw a demarcation line to guide me for painting the cabin interior.
Ongoing:
The cabin walls and internal cabin screen are now painted, and the screens fitted out.
I can finally glue into place the cabin walls, screens and partition. Note the eyelets are added to the ports and floor.
Did I say this came with a cabinet? No? Well, it does, and this is now fitted into place.
The carronades in this area differ from the others as they will retract into hull during the hull painting process. They can be rolled out into position when that job is complete. These are now fitted to the cabins area.
Time for some furniture and maps too.
Hope you like the work so far. Onwards!!
Ongoing:
It looks fantastic!
Current Build Hayling Hoy 1760 - First POF scratch build
Completed HMB Endeavour's Longboat by Artesania Latina
Completed HM Armed Cutter Alert by Vanguard Models
Completed 18ft cutter and 34ft launch by Vanguard Models
Completed Pen Duick by Artesania Latina
42 minutes ago, yvesvidal said:
That is gorgeous !!! I wish my Bellona had such details...... 😞
Yves
We look forward to your purchase 😘
Ongoing:
I re-took the photo of the cabin area as there was too much glare on the deck and the background was dirty.
Ongoing:
This shows just how right Chris was to make the furniture (as well as his figures) - the additional detail and accuracy brings to life what is a stunning model.
Nipper
brilliant
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
1 hour ago, yvesvidal said:
Nobody will want to build the quarter deck and hide this beautiful cabin from the view. Maybe Chris will design a removable deck to show the interior....
Yves
It'll be a little difficult on a fully rigged ship.
You can open things up more if you wanted though.
Ongoing:
What a fantastic build.  That internal detail would benefit from some cabin lights. Lots of options these days with the LED's now available. But very early planning required.
regards
Malcolm
Completed builds; Caldercraft Mars; Vanguard Alert, Amati Revenge
On the shelf; Vanguard DOK & the Sphinx
I would never imagine there would be cannons right inside the command and control room with all the furniture and neat floor and stuff. Did they really fire them? Amazing.
Current :
HMS Sphinx by Vanguard
Completed:
Orient Express Sleeping Car by Amati
Bluenose II (Artesania Latina)
Istanbul Tram - Occre
Bluenose II - Artesania Latina
Bosphorus Sandal Fishing Boat
Riva Aquarama - Amati
Titanic - Mantua
Bosphorus Fishing Boat - Tersane Model
San Juan Nepomuceno - Artesania Latina
Bluenose - Billing Boats
I have never seen cannon in the captains cabin in any TV show or movie. If they were really in there, space and smell must have been terrible. The movies left them out for affect more than likely.
Dave
Current builds: Rattlesnake, Curtis P-40 Warhawk - 1/33 Card
Completed builds: Lady Nelson
On the shelf: NRG Half Hull Project, Various metal, plastic and paper models
Here's HMS Victory's cabin:
Ongoing:
Probably most of them ... but "Master and Commander: The Fas Side of the World" kept the cannons in the captain's cabin. The cannons can be seen in several scenes in the captain's cabin. I think even during the dinner's scene in the cabin, with so many people in the room, I think the cannons are still inside.
Working on 3D models for the naval sailing simulation "The Weather Gage" / The Weather Gage on Steam
The epic film, “Master & Commander” is still a touchstone for a realistic depiction of fighting sail at the end of the 17th-early 18th-century. Personally, I return to watch it every so often for an immersion in history related to our hobby (and the era) I love. The current Vic’s captain’s quarters in Portsmouth looks very “sanitary” by comparison. This First Rate’s spacious quarters looks like a high school cafeteria space compared with the stingy and head-banging spaces of most other fighting ships in the Age of Sail.
Ron
Former Director, Nautical Research Guild, 2021-2025
@modelshipdood on Instagram
Current Build: HMS Diana Update
Completed Builds: HM Gunbrig Cracker #13 (HM Adder Gunbrig)Grace & Peace (Wyoming, 6-masted Schooner), HMS GrecianHMS Sphinx (as HMS CamillaOngakuka Maru, (Higaki Kaisen, It Takes A Village), Le Tigre Privateer, HMS Swan, HMS Godspeed, HMS Ardent, HMS Diana, Russian brig Mercury, Elizabethan Warship Revenge, Xebec Syf'Allah, USF Confederacy, HMS Granado, USS Brig Syren
