The Great Great grandchild of the 10 ton Mack AC... And the last of the chain drive trucks with narrow panel cabs....
From this they designed and build the 10 ton Mack NO's of WWII fame... The original haul anything anywhere trucks...
Beautiful rendition my friend... She looks great...
Quote:
 Gary, awesome!
 In this photo the fifth wheel plate looks greased. Did you add the "grease" or did the part come that way?
Edited by Keith Black
Very well done, Gary. I like the tires in this kill. I have several Sylvan fire truck kits and the have rubber tires with plenty of flash to remove. I like the Gallery Glass idea. Have to look them up to enhance my vehicles.
Ken
Started: MS Bounty Longboat,
On 2/9/2023 at 3:00 PM, rookie said:
I was intrigued by the powder pigments you use so I googled it
looks like something I will try on plastic models that I have on my shelf
Hello Colin. I use pigment powders quite often and they work great, but they do have their limitations.  They will not stick to smooth surfaces without some sort of carrier.  Also, the powder is ground very fine, much finer than chalk or pastels and they are crazy messy.  Be sure to check out some of the many great YouTube videos on how to use them and the different ways in which they can be worked before you take the plunge – they are not for everyone and I know people who hate them.  Thanks for stopping and the nice words.
On 2/9/2023 at 3:03 PM, mtaylor said:
An amazing amount of detail and implied detail on the truck, Gary.
The manufacturer was able to get some very smooth and crisp details on the parts, especially considering the medium and scale. Thanks Mark.
23 hours ago, pwog said:
Gary, once again - amazing work! I love the obligatory giant glasses shots. They always remind us of the scale you’re working with. You are the master.
Thanks for the kind words Paul.  But I'm far from a master, and I I've picked up many tips and techniques from our fellow builders here at MSW.
Any progress on Mighty Mite?
Hello EG, and thanks. There is just something about an old Mack truck that's special.
Here's a gentleman who restored a tandem wheel FK.  In part one he talks about the restoration.  In part two he drives it around town, but it's difficult to make out what he's saying over the engine.  A beast of a truck.
Hello Keith. Yes, I added the grease and here's a closer look at the plate.  I painted the plate acrylic flat black and added rust-colored pigments while it was still wet.  Once dry I gobbed ivory black oil paint on top.  I've not found anything that looks more like grease than black oil – after all, it is oil paint. Thanks Keith.
22 hours ago, FlyingFish said:
Lovely stuff - some grease on the tow plate maybe?
Thanks for looking in and for the compliment Andy.  Do you think I need to add more grease?
22 hours ago, Charles Green said:
Up to this point, I have been one of the quiet followers of your fantastic work.
The quality of it has made me reluctant to ask of this:  The tires on your vehicles - Have you considered creating a flat spot on their bottoms' to give the impression they are weighted?
Hello Charles, thanks for following my builds and for the nice comment.  Your question is a good one and I'm glad you asked.  I should have done what you suggested and sanded a slight flat on each tire so (as you stated) it looks like the vehicle has some weight to it.  That's one of those details that is often forgotten about (like I did here) but adds to the model's realism.  I don't know what could be done with resin tires, but I've seen modelers produce very convincing sidewall bulge on injection molded tires by warming up the material and smushing it down a bit.  The wheels on this model are already glued on, but I might try dragging it across a flat piece a sandpaper and see how that goes.
Hello Ken.  Yea the tires in this kit are quite good although they did require some clean up.  There was even some mold rubber stuck between the treads.  I've never made a Sylvan kit, but I see they have quite an extensive product line and I find their early/midcentury cab-over tractors tempting.  Gallery Glass is a pretty handy product and I use their Crystal Clear quite often.  What I don't like about the stuff is that it shrinks as it dries so you often have to apply it a second time to fill in where it has sunk.  And it doesn't dry hard like a clear epoxy does, more like rubber.  Useful stuff just the same and I've been using the same 2oz squeeze bottle for about 5 years.  Thanks for the comment.
Thanks to all for looking and the "likes".
Gary
Completed Scratch Builds
Yes, I am making progress on the Mighty Mite, thanks for asking. I just haven't updated my log yet, so I'll go and do that now.
Paul
On the Ways: Mighty Mite, Harbor Tugboat by pwog - NautiCurso - 1:64
__________________________________________________________________
Completed Builds:
Lobster Boat Red Baron (Bluejacket)
Sardine Carrier Pauline (Bluejacket)
Swampscott Dory (BlueJacket)
Greetings Fellow Modelers,
After a few weeks of being sidetracked, I finally put in the time to finish this shadowbox display.
Because the main door is partially open, a surface that extends beyond the wall to the “outside” is needed.  I decided that surface would be concrete and is made of hydrocal smeared on a piece of basswood.  This extension is 7/8” wide which is all the space available between the display module and the inside of the case.
The doorway needed two doors that swing out from the center.  I drew up what I thought looked appropriate and made them up.
The outside lights are white 5050 surface mount LEDs.  I started out thinking four would be enough, but then added two more and then another two.
They were mounted to a rectangle of styrene which was then bend downward over the doorway.  I lowered the lights up the point where they could almost be seen by the viewer looking out the doorway.  The two sticks of basswood were glued together at their crossing once the optimum downward bend was found.
The doors were positioned to minimize what could be viewed beyond the doorway. I don't want the inside of the shadowbox to be seen.
The rear window presented some difficulties due to the background image being so close to the window.  In fact, the image is 1/8” (3mm) from the back of the window.  I boxed off the window with 1/8” basswood strips and painted the surrounding area with a silver chrome for added reflectivity.  I then positioned five 5730 LEDs around the perimeter of the window with the side LEDs pointing inward toward the center.  Back when I installed the window, I had placed a grating over it and dirtied up the glazing so the view through it would be obscured.  This didn't work and just looked muddy and grubby, so I removed both and replaced it with clean clear acetate.
A background image was attached to a piece of styrene and the window box was closed up.
I placed clips inside the box to hold the display in and to make it easier to remove for swapping out the vehicle in the future.  Also, an image was glued to the inside wall of the box outside the doorway.
I spent considerable time balancing the lighting to get the look I was after.  Not a complete success by any stretch, but I'm satisfied with the result just the same.
The first three photos are with both interior and exterior lights on.
Then the exterior lights only.
The problem with having the interior lights only on, is that you can see the shadow cast by the window muntins on the background image. This is because the image is so close.  My other displays don't have this problem because the images are set back much further.
And that's it.
Thanks to everyone for taking a look and for all the likes.  And a special thank you to those who left comments of support and encouragement – I appreciate it very much.
Be safe and stay well.
Gary
I think this looks very convincing - the work of a stage and lighting director ;)
The problem of shadows on the backdrop occurs also in table-top photography. I have tried to circumvent this with back-lit translucent backdrops. However, this may not work for night scenes either.
I like the character of the mechanic crawling halfway under the lorry, very well animated. Did you do this or is it a commercial figure?
Edited by wefalck
 What an incredible little world, it's perfect.
True craftsmanship!  A truly outstanding display.
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Marvelous work, Gary.  It's just amazing how much detail you pack into a such a small display.
Bravo Gary! You’ve done it again. I look forward to your builds so much. So amazing. Your attention to detail makes everything look so real. Thanks for sharing with us.
Paul
Completed Builds:
Superb work, Gary. The mechanic under the truck is spot on. And your backdrop industrial picturs are the frosting on this display. 👍👍
Ken
Outstanding work Gary ! 👏  very inspiring work!  I am sitting here trying to imagine how I could adapt your technigues to an N scale railroad scene or maybe 1:35 scale armor. Hmmmm?
Jack
Current buildUS Constellation
12 minutes ago, Landlubber Mike said:
Insanely good work, wow!  Could swear I was looking at the real thing.  Great job!
What Mike said, truly outstanding craftsmanship! 🤯😱
Andrew
Completed (Kits):-
Thanks for the nice comment Wefalck.  Yes, shadows can be a problem, but it was one that I didn't consider until I saw it.  I too like the "looking under" figure, but no I didn't make it - it is from Preiser #28156.
Thank you CDW, Keith, Kurt, Mark, Edward, Paul and Ken for your wonderful comments.  It is always so truly appreciated.
Thank you for the nice words, Jack.  An N scale scene would be very cool I think, maybe a steam locomotive taking on water at a tower/tank or sitting in front of a station.  Limitless possibilities.  You better get started so we can all follow along!
Mike and Andrew - thank you so much.
And thanks to everyone for the "likes" and for taking a look.
Gary
Well brother, another micro masterpiece....
Well done, Very well done...
(in my best Darth Vader voice)   "Your skills are complete, You are POWERFUL.... YOU are the MASTER"
Quote:
You are a wizard and your magic is amazing. To me, the illusion of the lights and of a outdoor world works perfectly.
Bravo,
Dan
Can't wait to see  the  next  one
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
7 hours ago, CDW said:
My poor wife has been inundated with my model building habits over the past decades, but even she was very impressed with this
I'm glad she liked it and it's always good to hear what non-builders think.  My wife is also tolerant and supportive of my interests, as I am of hers.  There's something about model building that just relaxes the mind.  I put my magnifying visor on and push my face into the model and forget about everything else.  Thanks for the comment, Craig.
2 hours ago, Javlin said:
@62 and still do not own one.........cellphone
Oh good, I'm not the only one.  People used to look at me in the most peculiar way when they asked for my mobile number, and I would tell them I didn't have one.  So now I do have one, but I can never remember what the number is because I never turn the phone on.  Heavy sigh.  Thanks for the nice words on the model Javlin.
Gary
Yep same here ! Same for my Admiral. Kids complain they can't reach us ! 😈
Jack
