stern framing looks excellent Augie!  your skills are really shinning with this build  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Haven't really made enough progress for a proper update but there's something important I need to point out ... and now is the time.
The bulkhead beakhead doors were made the usual way by laminating 3 sections together, thinning them down, applying the finish and hardware.  They required only minor adjustments to fit the openings properly.  The two outermost doors will be covered by the roundhouses down the road.
Next, we fabricated the bowsprit step out of 3/16 and 1/4" strips.  After painting, it was securely pinned to the deck:
OK, here's what I wanted to discuss.  The bowsprit hole in the beakhead is quite a bit undersized for the bowsprit.  The bowsprit will be tapered but the hole still needs to be enlarged.  With the stem already in place, getting the proper angle and size on that hole is somewhat problematic.  Also, the next steps will include installing additional deck fittings as well as forecastle deck beams which will largely cover the bowsprit step.  I could visualize painting myself into a corner and being unable to properly fit the bowsprit 6 months from now.  So I fabricated and aligned this NOW and I'd strongly suggest you do something similar.  If you check Rusty's great Confed log you'll see that he left off the upper part of the stem (that which holds the figurehead) at this point ----that would give you room to work.  But I didn't think that far ahead.
I don't like breaking out my dad's old Craftsman 1/2" drill for work on a 1:64 ship model.  So I slowly enlarged the hole using slightly tapered sticks (old paint brush handles) wrapped in sandpaper.  Yes, it's just this side of Neanderthal (and slow) but it works..... and nothing got destroyed in the process.  Here's what we have:
The bowsprit has a tenon cut in to sit nicely in the step.  That will need to be painted red just prior to final installation.
Didn't mean to bore anyone with this as I'm sure you all know it's good to think ahead.  But now my conscience is clear.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Always good to plan ahead! Nice job Augie!  ;)
Cheers  :cheers:
GEORGE
I think the only thing that got "bored" was the hole for the bowsprit, Augie! :P
Great forward planning, masterfully executed.
Awesome pictures and info Augie. As far as I'm concerned, the more the better....    :)  :)  :)
Regards,
Larry
Current Build
US Brig Niagara
Completed Builds
George W Washburn - 1890 Tugboat
Future Builds
18th Century Longboat by MS
HM Cutter Cheerful
Wappen Von Hamburg by Corel
If your not making mistakes, your not challenging yourself – my life has been full of challenges :)
Hi Augie,
I have a friend who is building a Hahn style version of the Confederacy. He is currently researching a number of specifications, one of which is stern lanterns. He has not seen any models showing stern lanterns and has difficulty believing they were not on the ship. Has this item come to your attention and if so, do you plan on adding them to your build.
Regards,
Larry
Current Build
US Brig Niagara
Completed Builds
Future Builds
HM Cutter Cheerful
Augie, That looks lovely!!!  And a nice way to think ahead on enlarging that hole now.   Very nice.  :)
As far as a stern lantern goes.  I would say it is very plausible that this frigate had one.   Just one in the center.... but because the Confederacy was never ever modeled that way,  I did not add one to the prototype.  I would say it is fine either way but would indeed be very interesting to see a model with it.  It would however make it impossible to see that center figure on the stern.   It would cover it up.   Based on its location you might have to drill the hole for the main iron bracket right through the bottom of her torso or near-abouts.  Something I didnt want to to do.
Chuck
very nice work on the bow spirit Augie..........believe me,  it's not a primitive thing to wrap sandpaper around a dowel......this is what I use.
     I have four different sizes.  I use a semi rough paper though to speed the job up a little.   you've done such a wonderful job so far my friend.......it's a true testament to your talent!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I am build this model, but nowhere near Augi's work. I do have a question about the ships design. Why is the windless so far to the rear. I don't see how the ropes could lead to the catheads.
Flying Fish --  MSW
Essex ---  MSW
Constitution  --  MSW
Confederacy -- MSW
Philadelphia -- MSW
Chaperon -- MSW
San Felipe -- Panart
Portland -- Bluejacket
haha....i was thinking the same thing just yesterday.....also would the passage ways need to be hatched over.....and wondered how long the armsor levers were, or whatever they were called...
Edited by yancovitch
The capstan being rearward was/is intentional.  They would use a messenger rope which ran from the manger around the capstan and back to the bow.  The anchor hawse was tied to the messenger when raising the anchor.  As the hawse go to the scuttle for the cable tier, the wraps were untied.  Where the capstan is allowed it also to be used via pulleys to assist with raising/lowering the yards on the main mast, launching and recovering boats, etc.  You have to remember that these ships ARE very labor intensive and so moving gratings, etc. was just part of a day's work.
By the way,  Daniel (Dafi) has covered much of this capstan usage in his Victory build log and other topics where he thought things like this through with the help of MSW members and research.  He also explores other topics including guns, cabins, meals, and others.  It's well worth a look even if you're not building the Victory as it gives insight into how and why many things were done.
thanks.
Flying Fish --  MSW
Essex ---  MSW
Constitution  --  MSW
Confederacy -- MSW
Philadelphia -- MSW
Chaperon -- MSW
Lovely work Augie,
a pleasure to watch this build
NIls
Current builds
-Lightship Elbe 1
Completed
Time in the shipyard has been at a premium these last 2 weeks.  But we do have a small update as we cross the 900 hour mark into the build.
The foresheet bitts (with 'working' sheaves), foremast hoop and  deck beams have been added up in the bow.  In addition, the stove has reached it's final destination:
The last of the forecastle deck beams:
The view from the bow:
Next we'll be putting in the hanging and lodging knees and carlings.
Augie
Previous Builds :
Nice work Augie! Love the detail in your stove. I get the "itch" to start mine every time I stop by!  To self:---Patience grasshopper!  :D
Cheers
GEORGE
Hi Augie,
As always looks great and I especially like the stove with the brass details standing out. I hope a lot of this hard work will be visible in the end given it is an Admiralty model.
This kit looks like it is really a lot of fun to build!
Cheers,
Nigel.
Current Build Logs: H.M.S. Triton Cross SectionUSF Confederacy Model Shipways
Completed Log: Red Dragon Artesania Latina
Gallery: Red Dragon: Artesania Latina
Member:  Nautical Research Guild
Very clean and crisp and that stove is great!!!!
