Work continues on the internal framing and mast steps. Im using a flexible Holly battern for marking out the height of the lower deck beam clamp in the picture.
Im not going to follow the exact planking expansion for all the internal stuff that will disappear when the lower deck framing is installed - captains choice for a simpler and cleaner look to show more framing.
ben
Very nice Ben. I agree with the captain!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Lovely work, Ben. You'll be happy to know that your meticulous work will be only partially visible once the lower deck is in place and invisible after the upper deck is framed in (even if unplanked. But if you're of the mindset that every joint should be perfect (you obviously are) even if the detail will be hidden later on your model will be stunning.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Nice joinery Ben, your attention to detail is obvious - as Greg says, pity this work will be mostly unseen in the future - but we know it is there :)
cheers
Pat
That platform really is amazing.  Am looking forward to how all the other decks are going to turn out.  If this small area which will not really be seen is any indication they are really going to be something to see.
Ben-
You should be in the Bronx rather than Queensbury.........you continue to knock it out of the park.
Best,
John
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
Nice work as usual Ben; I love the colour combination of the woods.
cheers
Pat
Edited by BANYAN
typo
Here are the lower deck beams cut and shaped to length and temporarily installed so as to check positioning. I may remake a couple of them to get a better fit against the hull.
You may also be able to spot the transom sleepers at the far end of the picture which still need their bolts to be complete.
Happy Holidays to MSW.
ben
Fantastic work Ben!
Rusty
Thanks for all the likes.
Im thinking of maybe including the well so I decided to do a size and position check using the TFFM example shown in the book, seems to be a good fit in my hull.
ben
Beautiful clean workmanship Ben.
Michael
