Ben,  great chock.  Just getting right is a work of art.
Thanks Alan, Druxey and Mark,
I'm embarrassed to say that this was indeed V1.0, it worked out pretty well! Proberbly more luck than skill.
I just followed TFFM on how to make it, broke it down into the steps described by David and on the last step of getting the chock side angles I just took my time taking tiny slivers off each side until I found the angle to match.
I wish the damn hawse timbers had been as straitforward!
Ben
Edited by Trussben
First time on that chock???  You are a master.  post-76-0-10537700-1408222310.gif
Well done Ben - a tricky piece mastered on the first attempt.  I'm impressed! :)
Thanks Guys!
But like I say, I just followed TFFM and was proberbly very lucky! There are not many things on my Pegasus so far that came out correct first time around! Maybe that means I'm getting better at this!
Ben
Impressive work.
That is about the fifth time someone has mentioned TFFM ............... so I just bought the set.
Let us hope it brings me some of your luck
Alan O'Neill
You won't be disappointed Alan.
Lots of gems in the volumes. They will be well thumbed before the year is out.
Alan
Very nice to do the choke in one try, it shows you have patience, a great virtue in this hobby. It will get you a long way ;)
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Great work on the chock.  This entire build is full of "I thought that would be harder" and "That was easier than it should have been".  Be careful of the latter because half the time that means it wasn't done correctly (voice of experience).   :D
Toni
Member IPMS
                           Utrecht-1742
I'm not sure you are reading my log Toni, maybe Remco's! :P :P :P  My log is full of "Had to remake this again" or "Thanks Druxey, I shall pull that part out and re-position again". :huh:
But I do take your warning to not become complacent.
ben
Ahoy Ben :D
The way i see it; Its really just one big repair until its done. With each repair we learn a little more and make room for that information by forgetting what we learned on the last mistake.   :o
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Ahoy Ben :D
I think you just made a major discovery, JPett
Excellent work, Ben. You may wish to fabricate and temporarily fit frames L fore and 14 aft before raising those last cants. In a perfect world, your cant frames will fair right into the first full frames. Having those full frames ready as reference will show you how you have done. I must admit having to rework one cant and full frame to make a smooth flow after beveling. I suspect I had made an error transferring the half-breadth to the building board.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Looking very nice, Ben.
Regards Christian
Hi Ben,
I just had an enjoyable read catching up on your build. Your workmanship and
dedication to "getting it right" are outstanding!
Great work my friend. :)
Rusty
"So Long For Now" B)
Current Builds: Speedwell
