Licorne 1755 by mtaylor - 3/16" scale - French Frigate - from Hahn plans - Version 2.0 - TERMINATED
moving along quite nicely Mark........planking is looking sweet!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Share on other sites
Thanks for the comments and "likes".
Just a small (by MSW standards) but a big one for me.  Sadly, I forgot to take pictures during this process as my mind was on the process and not much else.
I lined off the hull starting a frame 20 (dead flat) and then went fore and aft from there at every 4th frame.  At the dead flat, I needed 27 strakes to cover the hull, at the sternpost, 27 also with a dip to 25 a couple frames in front of the stern post.  At the bow... 18.  Note that these are "full width" measurements.   I grabbed the planking fan and began lining it off bow to sternpost based on "27 planks" and realized I should be able to plank without stealers or drop planks..  Happy dance...post-76-0-93100200-1438726269.gif
My next step was to lay some battens (3 on each side) and check the run... looks good but I needed to tweak the lining off a bit.
I've since pulled off the battens and the garboard plank and started planking.  I'm working from the wales toward the garboard.  I made this choice based my feelings that I can use the wiggle room provided by the extra-wide garboard for adjustment if my planking doesn't quite match the lines.
Back to sawdust, planking and trying not to overthink this too much.
Link to comment
Hi Mark,
Been following along from afar and enjoying hitting the like button.  Your Licorne is looking just wonderful...the patience and dedication that goes into these expert, fully framed scratch builds simply astonishes me.
Great news that you may not need any drops or stealers, though if they end up being required, I think they also make a nice detail.
One question, are you planning to fully plank the hull on both sides or leave some of your beautiful framing details visible? Just wondering as you mentioned you placed battens on both sides to check the runs.
Cheers,
Nigel.
Edited by UpstateNY
Current Build Logs: H.M.S. Triton Cross SectionUSF Confederacy Model Shipways
Completed Log: Red Dragon Artesania Latina
Gallery: Red Dragon: Artesania Latina
Member:  Nautical Research Guild
Link to comment
Hi Mark,
Cheers,
Nigel.
Hi Nigel,
Fully planked both sides.  Admiralty orders.   :)   The battens have been removed and planking is progressing.
Pictures are proof ... Hmmm, I wonder ... did he or didn't he do it ... did he just buy time ... ;):P
Carl...  oh yeah...he did it.  A lot of fussing and agonizing going on as well as some real-world distractions.
Stay tuned.... we'll see where this goes.
Link to comment
But we know it's there.  And perhaps kept some photos.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Link to comment
You know mark it's such a shame to cover up such beautiful detail but to have an open sided ship also to me looks strange the knowledge of knowing the ship is built with such love and detail will spur your heart on to make grander undertakings She looks great best of luck to you
Link to comment
Fantastic workmanship.I love to see all the models  posted here.
SOS
New Bedford Whaleboat build. Kit by Model Shipways
I've been making progress on my model and according to the instruction booklet I should be painting it, at least parts of it.
Are acrylic's ok ? I did apply a sanding sealer. but I want to stain the untreated floor boards which are walnut.
Thanks
S.O.S.
Link to comment
A minor milepost in the overall build but a major one for me...
Six strakes have been added and to check how the tuck planking went, I taped the sternpost into position and took a few extra shots.   Roughly sanded (sorry about the sawdust) and there's some gaps need filling.  Overall, I'm feeling pretty good at this point.  At the stern area, I'm off by about 3" (scale) which could be tolerance buildup or one side was of the transoms was off by that much.  I'm thinking it has more to do with some tolerance buildup and the angle the planks came into tuck.  The bow is about 2" (scale) off.
I do like the way the lines are shaping up with planking.
I need to re-mark off the hull and re-check the measurements and then do a few more strakes before putting the garboard back on.  And sand, sand, sand.... <cough><cough>:  Luckily the air filter system I've added to the workshop is doing it's job.
Comments, questions, abuse is always allowed.  Ok.. maybe not the abuse part...  ;)
Edited by mtaylor
Link to comment
beautiful lines Mark,
trust These full curves are characteristic for the French design of that period
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Link to comment
She start talking, Mark !
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Link to comment
Coming along nicely, Mark. Try to resist doing too much sanding until planking is complete.
What do you mean by '3" off'? Do you mean creep or cumulative error compared to your lining off of the planking runs? You can easily correct this by either making remaining strakes fractionally wider or narrower to compensate. Just don't let this become a big issue when it comes down to the last strake!
Link to comment
Nice work, Mark.  You are really getting the hang of planking and spiling.
I completely agree with Druxey - go slow when correcting plank runs.  Take at least three strakes to fill in a dip or level a hump.  No one will be able to see the incremental difference, which they could if you try to fix a problem all at once.
Congrats, again.
Dan
Current build -SS Mayaguez (c.1975) scale 1/16" = 1' (1:192) by Dan Pariser
Prior scratch builds - Royal yacht Henrietta, USS Monitor, USS Maine, HMS Pelican, SS America, SS Rex, SS Uruguay, Viking knarr, Gokstad ship, Thames River Skiff , USS OneidaSwan 42 racing yacht  Queen Anne's Revenge (1710) SS Andrea Doria (1952), SS Michelangelo (1962) , Queen Anne's Revenge (2nd model) USS/SS Leviathan (1914),  James B Colgate (1892),  POW bone model (circa 1800) restoration
Link to comment
Thanks for the "likes" and comments.   It's still fun...
Congrats, again.
Dan
I'm thinking it's more creep than anything else at this point, Druxey.  At the sternpost, the right side plank is higher then the left.  I'm taking yours advise on adjusting.
The sanding is/was very rough only to see if things were close.  I made a newbie's mistake early on in this and grab some planking that was too thin. For a strake.  Didn't notice it until I ran some sandpaper to clean a rough edge.  If I find one too low, after the light touch now, I can still fix it.
Thanks Dan, good advice from both you and Druxey.
Edited by mtaylor
Link to comment
Just catching up..... looking at the bow and stern of your ship, I don't think you could have gotten such a great run of the planks if you didn't spil them... Nice work Mark ....she' s going to be a real "looker".... ;)
frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Link to comment
I poke into a number of logs here and am continually marveled by the workmanship seen here. It is an inspiration to do better but some time trying to achieve perfection can be a burden. So I try to do my best get on with the model and hope others don't notice my mistakes. ;)   or make allowances.
SOS
Thanks
S.O.S.
Link to comment
Very nice indeed!  Love the stern tuck, looks very symmetrical.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
