Great admirer of your work ! It's always so beautiful !
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • HMS Winchelsea 1764 - Syren Ship Model - 1:48
This is such a fabulous build to follow through. It's what I aspire too. Some true craftsmanship right here...
Ongoing:
If you absolutely have to use lead, please seal it with clear finish. With time and air it will deteriorate to white lead salts. That's ugly! If you can substitute non-lead metal such as pewter, so much the better.
On 2/29/2020 at 6:20 AM, marsalv said:
Thank you guys for all comments and likes.
To No Idea: tilting base is specially designed and "home made" for existing Proxxon vice.
To dvm27: I have visited Sherline web - this maschine is fantastic, I´ve never seen anything like it before.
After about one week all ropes are finished, cca 190 ropes in 14 thickness. Lenght of one ropes is approximately 180 cm.
Amazing work Marsalv!
Can I ask you where do you find the thread you are using to make your ropes? You show two different colours and I guess you can find it in different thicknesses to ned up having 14 sizes.
Thank you,
Alexandru
For all my builds please visit my site at: http://www.AlexShipModels.com
Previous builds
To Druxey - thanks for informations, I discussed this situation with my friend who had the same problem. I cover these lead items with clear varnish and the whole hull is then preserved with the wax. I hope that it will be OK.
To Alexandru - I am using the french Sajou thread for the ropes (https://sajou.fr/en/339-fil-au-chinois-gloving-thread-1000m-cones). Unfortunately this thread is only in one thicknesess.
Completed ceiling.
Wonderful job ! Having read the log again, I was wondering about the species of wood used for the deck planking: I suppose pear but for the lighter wood ? Mapple ?
Are the moldings done manually using the scrapper technique or were they made using the mill ?
The model is really beautiful. Thank you for sharing your great work.
Jean-Paul
Current builds :
Finished build :
Next on list :
Marsalv, As others have already mentioned your workmanship is superb and of the highest calibre. You mentioned that the moldings were done on the milling machine, Are you using a combination of different shapes on the one molding or are you making the cutters as a single cutter yourself, also what speed are you using to obtain such a fine surface finish.
Regards Michael
Hi Michael,
moldings are made on CNC milling maschine. I am using VCarve software for this purpose. You have to create only curve (cross section) of molding and maschine does the work itself🙂. You can see in this example that my workmanship is not so superb as you noted🙂.
Preparation of deck beams for forecastle and quarter deck.
Beautiful work, I hope you are using Aluminum and NOT lead.
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
To say your modeling skill is next level would imply there is another level beyond, there isn’t. Your work is superb.
I may have missed it somewhere, how to you get length for your moldings, a special table or home built mod?  Mine Mill is limited to 5 inches.
Regards,
Glenn
Current Build: HM Flirt
To dowmer - this time I used brass, which is then tinned, and tin foil, which is glued to the deck with double-sided adhesive tape.
To glbarlow - the maximum length I can do on a milling maschine is 28 cm, for longer plank I use "special jig" - see picture. I insert the plank into the groove in the jig, perform the milling of the first part, remove the plank and move it forward and continue milling.
I continue with breast hook, collar beam and bowsprit partner.
Ingenious! If I may ask, how do you keep the moulding strip from sliding in the grove as it’s being milled
Regards,
Glenn
